270016
    RUKO
270016 数据手册
Thread-cutting tools Combined machine taps HSS, ground 1.6 Thread: metric DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6 H Surface: bright 1/4" hexagon Shank: Right-hand cutting The combined machine tap is suitable for sheet metal working with right/left handed rotation cordless drilling machines. For tapping drill hole and through thread in unalloyed or low-alloyed steels up to 600 N/mm² strength, malleable cast iron and non-ferrous metals. The thread is cut in one operation, without any tool changing. The tool incorporates a twist drill before the thread-tapping part. The machine tap consists of heavy-duty high-speed steel. In one working stroke: ü Hole drilling ü Thread cutting (tapping) ü Thread deburring ü Thread cleaning D2 Packing unit: Individual plastic pack Nominal thread size Pitch mm M 3 M 4 M 5 M 6 M 8 M 10 0,50 0,70 0,80 1,00 1,25 1,50 L1 mm 36,0 39,0 41,0 44,0 51,0 59,0 S1 mm 5,0 6,0 7,0 8,0 11,0 15,0 L2 mm 6,0 8,0 9,0 11,0 14,0 15,0 D1 mm 2,5 3,3 4,2 5,0 6,8 8,5 D2 mm 7,2 7,2 7,2 7,2 8,8 11,0 Hexagon magnetic holder Article no. Price each € 270 014 270 015 270 016 270 017 270 018 270 019 L1 L2 S1 270 013 D1 Combined machine taps HSS-TiN, ground Thread: metric DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6 H Surface: titanium-nitride coated 1/4" hexagon Shank: Right-hand cutting The combined machine tap is suitable for sheet metal working with right/left handed rotation cordless drilling machines. For tapping drill hole and through thread in unalloyed or low-alloyed steels up to 1000 N/mm² strength, malleable cast iron and non-ferrous metals. The thread is cut in one operation, without any tool changing. The tool incorporates a twist drill before the thread-tapping part. The machine tap consists of heavy-duty high-speed steel. In one working stroke: ü Hole drilling ü Thread cutting (tapping) ü Thread deburring ü Thread cleaning D2 Packing unit: Individual plastic pack Nominal thread size Pitch mm M 3 M 4 M 5 M 6 M 8 M 10 0,50 0,70 0,80 1,00 1,25 1,50 L1 mm 36,0 39,0 41,0 44,0 51,0 59,0 Hexagon magnetic holder S1 mm 5,0 6,0 7,0 8,0 11,0 15,0 L2 mm 6,0 8,0 9,0 11,0 14,0 15,0 D1 mm 2,5 3,3 4,2 5,0 6,8 8,5 D2 mm 7,2 7,2 7,2 7,2 8,8 11,0 Article no. 270 014 T 270 015 T 270 016 T 270 017 T 270 018 T 270 019 T Price each € L1 L2 S1 270 013 D1 - 114 -
270016 价格&库存
很抱歉,暂时无法提供与“270016”相匹配的价格&库存,您可以联系我们找货
