102107E
102107E
    RUKO
102107E 数据手册
Taper and deburring countersinkers Taper and deburring countersinkers DIN 335 type C 90° HSS Co 5 CBN ground for stainless steel Counters. angle: Shank: Cutting edges: Surface: Right-hand cutting 90° cylindrical 3 bright Because of the CBN deep-ground flutes the cutting edges are extremely sharp. Ideal for burr- and chatter-free deburring and countersinking. Applicable for special steel, stainless and acidresistant steel. Best results at low cutting speeds. 1.5 Packing unit: in plastic tubes of 1 6,3 8,0 8,3 10,0 10,4 12,4 16,5 16,5 20,5 25,0 31,0 1,5 2,0 2,0 2,5 2,5 2,8 3,2 3,2 3,5 3,8 4,2 Total length L mm Shank Ø d2 mm 45,0 50,0 50,0 50,0 50,0 56,0 60,0 60,0 63,0 67,0 71,0 5,0 6,0 6,0 6,0 6,0 8,0 8,0 10,0 10,0 10,0 12,0 Countersinkings as per DIN 74 AF BF M4 M5 M3 M4 M5 M6 M8 M8 M 10 M 12 M 16 Article no. Price each € 102 107 E 102 110 E 102 111 E 102 113 E 102 114 E 102 116 E 102 119 E 102 119-1 E 102 121 E 102 123 E 102 125 E L Countersinker nominal Ø d3 d1 mm mm d2 d3 d1 Taper and deburring countersinkers ≈ DIN 335 type C 90° tungsten carbide K 20 Counters. angle: Shank: Cutting edges: Surface: Right-hand cutting 90° cylindrical 3 bright Because of the deep-ground flutes the cutting edges are absolutely sharp. Ideal for burr- and chatter-free deburring and countersinking. Applicable for abrasive and hard steel over 1000 N/mm² consistency, GG over 240 HB. d2 Countersinker nominal Ø d3 d1 mm mm 6,3 8,3 10,4 12,4 16,5 20,5 25,0 31,0 1,5 2,0 2,5 2,8 3,2 3,5 3,8 4,2 Total length L mm Shank Ø d2 mm 45,0 50,0 50,0 56,0 60,0 63,0 67,0 71,0 5,0 6,0 6,0 8,0 10,0 10,0 10,0 12,0 Countersinkings as per DIN 74 AF BF Article no. M3 M4 M5 M6 M8 M 10 M 12 M 16 102 261 102 262 102 263 102 264 102 265 102 266 102 267 102 268 Modifications of tungsten carbide quality reserved. - 69 - Price each € L Packing unit: in plastic tubes of 1 d3 d1
102107E 价格&库存
很抱歉,暂时无法提供与“102107E”相匹配的价格&库存,您可以联系我们找货
