102790RO
102790RO
    RUKO
    RUKO - 102790RO - Drill Bit Set, Countersinker, HSS, 6.3 mm - 20.5 mm, 6 Piece
102790RO 数据手册
TECHNICALLY PERFECTED. HSS HSSE Co 5 C DIN 335 3 90° ≥ Ø 8,3 mm Taper and deburring countersinkers ULTIMATECUT (DIN 335) type C 90° Ø2 The newly developed cutting geometry of the ULTIMATECUT enormously reduces the axial and radial forces, which are affecting the tool during the countersinking. The variably running relief grinding was specially developed and ensures a very quiet countersinking procedure and a perfect surface quality, which guarantees the best results. (The new RUnaTEC coating further increases performance). The specially developed flute parameters, such as the angle, the transition radius as well as the extra-wide chip flute, ensure an optimal chip and heat removal and therefore enable a high wear resistance. Furthermore, the new geometry prevents material welding and reduces the countersinking force. Considerably less feed power while countersinking is now necessary. The materials can be handled either with a very high as well as with a very low cutting speed, without loss of quality/loosing quality concerning the result. The ULTIMATECUT achieves the best performance in mostly all applications and materials! L1 Ø1 Packing unit: in plastic tubes of 1 Ø3 + achieves the best performance in almost all materials and applications + considerably less feed force required + up to 60% longer service life + up to 30% faster countersinking + extremely quiet running + optimal and smooth surface + perfect chip removal Steel (N/mm2) < 900 Brass Steel (N/mm2) < 1100 Bronze Steel (N/mm2) < 1300 Plastics Rust-resistant steel Cast iron Aluminium Titanium alloyed Ø2 mm Ø1 mm L1 mm Ø3 mm Countersinkings as per DIN 74 6,3 8,3 10,4 12,4 15,0 16,5 19,0 20,5 23,0 25,0 31,0 1,5 2,0 2,5 2,8 3,2 3,2 3,5 3,5 3,8 3,8 4,2 45,0 50,0 50,0 56,0 60,0 60,0 63,0 63,0 67,0 67,0 71,0 5,0 6,0 6,0 8,0 10,0 10,0 10,0 10,0 10,0 10,0 12,0 M 3 M 4 M 5 M 6 M 8 M 8 M 10 M 10 M 12 M 12 M 16 PRECISION TOOLS HSS 102 767 102 771 102 774 102 776 102 778 102 779 102 780 102 781 102 782 102 783 102 785 HSS HSSE Co 5 HSSE Co 5 102 767 P 102 771 P 102 774 P 102 776 P 102 778 P 102 779 P 102 780 P 102 781 P 102 782 P 102 783 P 102 785 P 102 767 E 102 771 E 102 774 E 102 776 E 102 778 E 102 779 E 102 780 E 102 781 E 102 782 E 102 783 E 102 785 E 102 767 EP 102 771 EP 102 774 EP 102 776 EP 102 778 EP 102 779 EP 102 780 EP 102 781 EP 102 782 EP 102 783 EP 102 785 EP 1 1 1 1 1 1 1 1 1 1 1 Technical changes, errors and printing mistakes are reserved. Delivery while stocks last. MKT 02-2017 HSS HSSE Co 5 DIN 335 C 3 90° ≥ Ø 8,3 mm Taper and deburring countersinker sets ULTIMATECUT (DIN 335) type C 90° in steel case HSS HSS HSSE Co 5 HSSE Co 5 102 790 102 790 P 102 790 E 102 790 EP 5-piece set of taper and deburring countersinkers ULTIMATECUT (DIN 335) type C 90° Ø 6,3 - 10,4 - 16,5 - 20,5 - 25,0 mm 102 791 102 791 P 102 791 E 102 791 EP HSS HSSE Co 5 HSSE Co 5 102 790 102 790 P 102 791 EP 6-piece set of taper and deburring countersinkers ULTIMATECUT (DIN 335) type C 90° Ø 6,3 - 8,3 - 10,4 - 12,4 - 16,5 - 20,5 mm Taper and deburring countersinker sets ULTIMATECUT (DIN 335) type C 90° in plastic case HSS 102 790 ERO 102 790 EPRO 5-piece set of taper and deburring countersinkers ULTIMATECUT (DIN 335) type C 90° Ø 6,3 - 10,4 - 16,5 - 20,5 - 25,0 mm 102 791 RO 102 791 PRO 102 791 ERO 102 791 EPRO PRECISION TOOLS 102 791 EPRO 102 790 PRO 102 790 PRO 102 790 RO 102 790 RO 6-piece set of taper and deburring countersinkers ULTIMATECUT (DIN 335) type C 90° Ø 6,3 - 8,3 - 10,4 - 12,4 - 16,5 - 20,5 mm Technical changes, errors and printing mistakes are reserved. Delivery while stocks last. MKT 02-2017
102790RO 价格&库存
很抱歉,暂时无法提供与“102790RO”相匹配的价格&库存,您可以联系我们找货
