214024
    RUKO
214024 数据手册
Twist drills DiN 338 type N, Hss ground Ø DIN 338 N C HSS-G 5xD h8 118° ≥ Ø 2,0 mm 25-30° 1.01 L2 High-performance ground standard twist drill made from heavy-duty high speed steel. The fully ground twist drill has a precise concentricity. Thanks to the split point, this drill has good centring properties and requires little pressure. L1 Packing unit: in plastic box HSS-G HSS-G steel (N/mm2) < 900 < 1100 < 1300 stainless steel Main application 54 Ø mm L1 mm L2 mm 0,30 0,40 0,50 0,60 0,70 0,80 0,90 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 19,0 20,0 22,0 24,0 28,0 30,0 32,0 34,0 36,0 38,0 38,0 38,0 40,0 40,0 43,0 43,0 46,0 46,0 46,0 49,0 49,0 53,0 53,0 53,0 57,0 57,0 57,0 61,0 61,0 61,0 61,0 61,0 65,0 65,0 65,0 3,0 5,0 6,0 7,0 9,0 10,0 11,0 12,0 14,0 16,0 16,0 16,0 18,0 18,0 20,0 20,0 20,0 22,0 22,0 24,0 24,0 27,0 27,0 27,0 30,0 30,0 30,0 33,0 33,0 33,0 33,0 33,0 36,0 36,0 36,0 aluminium HSS-G brass bronze plastics cast iron titanium alloyed Other application Article no. HSS-G 214 003 214 004 214 005 214 006 214 007 214 008 214 009 214 010 214 011 214 012 214 0125 214 013 214 014 214 015 214 016 214 017 214 0175 214 018 214 019 214 020 214 021 214 022 214 0225 214 023 214 024 214 025 214 026 214 027 214 0275 214 028 214 029 214 030 214 031 214 032 214 0325 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G Black 214 003 S 214 004 S 214 005 S 214 006 S 214 007 S 214 008 S 214 009 S 214 010 S 214 011 S 214 012 S 214 0125 S 214 013 S 214 014 S 214 015 S 214 016 S 214 017 S 214 0175 S 214 018 S 214 019 S 214 020 S 214 021 S 214 022 S 214 0225 S 214 023 S 214 024 S 214 025 S 214 026 S 214 027 S 214 0275 S 214 028 S 214 029 S 214 030 S 214 031 S 214 032 S 214 0325 S Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G TiN 250 003 T 250 004 T 250 005 T 250 006 T 250 007 T 250 008 T 250 009 T 250 010 T 250 011 T 250 012 T 250 0125 T 250 013 T 250 014 T 250 015 T 250 016 T 250 017 T 250 0175 T 250 018 T 250 019 T 250 020 T 250 021 T 250 022 T 250 0225 T 250 023 T 250 024 T 250 025 T 250 026 T 250 027 T 250 0275 T 250 028 T 250 029 T 250 030 T 250 031 T 250 032 T 250 0325 T Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 « www.ruko.de » Ø mm L1 mm L2 mm 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 65,0 70,0 70,0 70,0 70,0 70,0 75,0 75,0 75,0 75,0 75,0 75,0 80,0 80,0 80,0 80,0 80,0 80,0 86,0 86,0 86,0 86,0 86,0 86,0 86,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 93,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 109,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 117,0 125,0 125,0 125,0 125,0 36,0 39,0 39,0 39,0 39,0 39,0 43,0 43,0 43,0 43,0 43,0 43,0 47,0 47,0 47,0 47,0 47,0 47,0 52,0 52,0 52,0 52,0 52,0 52,0 52,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 57,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 69,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 81,0 81,0 81,0 81,0 Article no. HSS-G 214 033 214 034 214 035 214 036 214 037 214 0375 214 038 214 039 214 040 214 041 214 042 214 0425 214 043 214 044 214 045 214 046 214 047 214 0475 214 048 214 049 214 050 214 051 214 052 214 0525 214 053 214 054 214 055 214 056 214 057 214 0575 214 058 214 059 214 060 214 061 214 062 214 0625 214 063 214 064 214 065 214 066 214 067 214 0675 214 068 214 069 214 070 214 071 214 072 214 0725 214 073 214 074 214 075 214 076 214 077 214 0775 214 078 214 079 214 080 214 081 214 082 214 0825 214 083 214 084 214 085 214 086 214 087 214 0875 214 088 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G 214 033 S 214 034 S 214 035 S 214 036 S 214 037 S 214 0375 S 214 038 S 214 039 S 214 040 S 214 041 S 214 042 S 214 0425 S 214 043 S 214 044 S 214 045 S 214 046 S 214 047 S 214 0475 S 214 048 S 214 049 S 214 050 S 214 051 S 214 052 S 214 0525 S 214 053 S 214 054 S 214 055 S 214 056 S 214 057 S 214 0575 S 214 058 S 214 059 S 214 060 S 214 061 S 214 062 S 214 0625 S 214 063 S 214 064 S 214 065 S 214 066 S 214 067 S 214 0675 S 214 068 S 214 069 S 214 070 S 214 071 S 214 072 S 214 0725 S 214 073 S 214 074 S 214 075 S 214 076 S 214 077 S 214 0775 S 214 078 S 214 079 S 214 080 S 214 081 S 214 082 S 214 0825 S 214 083 S 214 084 S 214 085 S 214 086 S 214 087 S 214 0875 S 214 088 S Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Article no. HSS-G TiN 250 033 T 250 034 T 250 035 T 250 036 T 250 037 T 250 0375 T 250 038 T 250 039 T 250 040 T 250 041 T 250 042 T 250 0425 T 250 043 T 250 044 T 250 045 T 250 046 T 250 047 T 250 0475 T 250 048 T 250 049 T 250 050 T 250 051 T 250 052 T 250 0525 T 250 053 T 250 054 T 250 055 T 250 056 T 250 057 T 250 0575 T 250 058 T 250 059 T 250 060 T 250 061 T 250 062 T 250 0625 T 250 063 T 250 064 T 250 065 T 250 066 T 250 067 T 250 0675 T 250 068 T 250 069 T 250 070 T 250 071 T 250 072 T 250 0725 T 250 073 T 250 074 T 250 075 T 250 076 T 250 077 T 250 0775 T 250 078 T 250 079 T 250 080 T 250 081 T 250 082 T 250 0825 T 250 083 T 250 084 T 250 085 T 250 086 T 250 087 T 250 0875 T 250 088 T Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 55 1.01 Twist drills DiN 338 type N, Hss ground Ø mm 1.01 8,90 9,00 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 56 L1 mm L2 mm 125,0 125,0 125,0 125,0 125,0 125,0 125,0 125,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 133,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 142,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 151,0 160,0 160,0 169,0 169,0 178,0 178,0 184,0 184,0 191,0 191,0 198,0 198,0 205,0 205,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 81,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 87,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 94,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 101,0 108,0 108,0 114,0 114,0 120,0 120,0 125,0 125,0 130,0 130,0 135,0 135,0 140,0 140,0 Article no. HSS-G 214 089 214 090 214 091 214 092 214 0925 214 093 214 094 214 095 214 096 214 097 214 0975 214 098 214 099 214 100 214 101 214 102 214 103 214 104 214 105 214 106 214 107 214 108 214 109 214 110 214 111 214 112 214 113 214 114 214 115 214 116 214 117 214 118 214 119 214 120 214 121 214 122 214 123 214 124 214 125 214 126 214 127 214 128 214 129 214 130 214 135 214 140 214 145 214 150 214 155 214 160 214 165 214 170 214 175 214 180 214 185 214 190 214 195 214 200 Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 1 1 1 1 1 1 1 1 Article no. HSS-G 214 089 S 214 090 S 214 091 S 214 092 S 214 0925 S 214 093 S 214 094 S 214 095 S 214 096 S 214 097 S 214 0975 S 214 098 S 214 099 S 214 100 S 214 101 S 214 102 S 214 103 S 214 104 S 214 105 S 214 106 S 214 107 S 214 108 S 214 109 S 214 110 S 214 111 S 214 112 S 214 113 S 214 114 S 214 115 S 214 116 S 214 117 S 214 118 S 214 119 S 214 120 S 214 121 S 214 122 S 214 123 S 214 124 S 214 125 S 214 126 S 214 127 S 214 128 S 214 129 S 214 130 S 214 135 S 214 140 S 214 145 S 214 150 S 214 155 S 214 160 S — — — — — — — — Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 — — — — — — — — Article no. HSS-G TiN 250 089 T 250 090 T 250 091 T 250 092 T 250 0925 T 250 093 T 250 094 T 250 095 T 250 096 T 250 097 T 250 0975 T 250 098 T 250 099 T 250 100 T 250 101 T 250 102 T 250 103 T 250 104 T 250 105 T 250 106 T 250 107 T 250 108 T 250 109 T 250 110 T 250 111 T 250 112 T 250 113 T 250 114 T 250 115 T 250 116 T 250 117 T 250 118 T 250 119 T 250 120 T 250 121 T 250 122 T 250 123 T 250 124 T 250 125 T 250 126 T 250 127 T 250 128 T 250 129 T 250 130 T 250 135 T 250 140 T 250 145 T 250 150 T 250 155 T 250 160 T — — — — — — — — Cont. pcs. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 — — — — — — — —
214024 价格&库存
很抱歉,暂时无法提供与“214024”相匹配的价格&库存,您可以联系我们找货
  • 1+11.52092
  • 5+9.56319
  • 10+8.92248
库存:100
