230-050 M5
230-050 M5
    RUKO
    RUKO - 230-050 M5 - Tap Set, M5 x 0.8 mm, 3 Piece
230-050 M5 数据手册
Thread-cutting tools Hand taps M DIN 352 HSS, ground 1.6 Set: 3-piece Taper tap: 5 - 6-thread chamfer Second tap: 4 - 5-thread chamfer Final tap: 2 - 3-thread chamfer Thread: metric, DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6H Surface: bright Right-hand cutting For through threads and bottoming threads in unalloyed or low-alloyed steels up to 800 N/mm² strength, malleable cast iron and non-ferrous metals. The thread is cut in three operations. Also available individually Taper tap: Article no. -1 Second tap: Article no. -2 Final tap: Article no. -3 Packing unit: Set in plastic pack Nominal thread size Pitch mm Thread core hole mm Total length mm Thread length mm Article no. M 1 M 1,2 M 1,4 M 1,6 M 1,7 M 1,8 M 2 M 2,2 M 2,3 M 2,5 M 2,6 M 3 M 3,5 M 4 M 4,5 M 5 M 6 M 7 M 8 M 9 M 10 M 11 M 12 M 14 M 15 M 16 M 18 M 20 M 22 M 24 M 27 M 30 M 33 M 36 M 39 M 42 M 45 M 48 M 52 0,25 0,25 0,30 0,35 0,35 0,35 0,40 0,45 0,40 0,45 0,45 0,50 0,60 0,70 0,75 0,80 1,00 1,00 1,25 1,25 1,50 1,50 1,75 2,00 2,00 2,00 2,50 2,50 2,50 3,00 3,00 3,50 3,50 4,00 4,00 4,50 4,50 5,00 5,00 0,75 0,95 1,10 1,25 1,35 1,45 1,60 1,75 1,90 2,10 2,10 2,50 2,90 3,30 3,70 4,20 5,00 6,00 6,80 7,80 8,50 9,50 10,20 12,00 13,00 14,00 15,50 17,50 19,50 21,00 24,00 26,50 29,50 32,00 35,00 37,50 40,50 43,00 47,00 32,0 32,0 32,0 32,0 32,0 32,0 36,0 36,0 36,0 40,0 40,0 40,0 45,0 45,0 50,0 50,0 50,0 50,0 56,0 63,0 70,0 70,0 75,0 80,0 80,0 80,0 95,0 95,0 100,0 110,0 110,0 125,0 125,0 150,0 150,0 150,0 160,0 180,0 180,0 5,5 5,5 7,0 7,0 8,0 8,0 8,0 9,0 9,0 8,0 8,0 10,0 12,0 12,0 16,0 13,0 15,0 16,0 18,0 22,0 24,0 24,0 29,0 30,0 32,0 32,0 40,0 40,0 40,0 45,0 50,0 56,0 56,0 63,0 63,0 63,0 70,0 75,0 75,0 230 010 230 012 230 014 230 016 230 017 230 018 230 020 230 022 230 023 230 025 230 026 230 030 230 035 230 040 230 045 230 050 230 060 230 070 230 080 230 090 230 100 230 110 230 120 230 140 230 150 230 160 230 180 230 200 230 220 230 240 230 270 230 300 230 330 230 360 230 390 230 420 230 450 230 480 230 520 Emphasised articles are new additions. - 88 - Price set €
230-050 M5 价格&库存
很抱歉,暂时无法提供与“230-050 M5”相匹配的价格&库存,您可以联系我们找货
