244206
244206
    RUKO
    RUKO - 244206 - PRO COIL THRED REPAIRING SET, M12
244206 数据手册
Thread repair tool 07 Thread repair tool There are various causes that lead to the destruction of threads. These include for instance corrosion, wear or a too high tightening torque. The ProCoil thread repair range by RUKO allows for a low-cost, simple and quick repair of damaged and worn out threads. galvanized steel guarantees high quality internal threads that withstand effects of temperature and corrosion. One more advantage of the ProCoil range is the simple and quick installation. Application areas are for instance machine and plant construction, automotive and electrical engineering, power plant technology or shipbuilding. Besides repair, scrap recycling is also of great significance to the industry. 206 PRECISION TOOLS 07 Overview of symbols HSS M 60° N C height-speed steel ≥ Ø 2,0 mm Shank: square as per dIN 10 Shape C: Split point right hand cutting ISO2 6H metric, dIN ISO 13 right hand cutting Thread angle bright surface Shank: cylindrical 118° h8 Point angle: 118° Tolerance e.g. h8 800 Type N N/mm² 25-30° Tenacity classes Thread tolerance for metric and metric fine threads according to dIN ISO 13 for internal threads helix angle e.g. 25-30° 5xD drilling depth e.g. 5 x diameter Product Information 1 Drilling out: firstly drill out the damaged thread with a RUKO twist drill. In this regard it should be noted that larger drill holes are necessary with thread formers. Check that the screw tap and threaded bolt from the ProCoil set have the same thread and pitch. 2 Thread cutting: The new internal thread is now cut into the drilled out hole with a RUKO screw tap. Using RUKO cutting oil is recommended. 3 Fitting the thread insert: Place the insert onto the insertion tool. Care should be taken here that the tang fits in the groove and the adjusting ring is correctly set. Now use light pressure to twist the thread insert in the direction of the thread. Attention: do NOT twist against the thread direction, as the tang may break off. 4 Breaking the tang: Remove the insertion tool and break the tang with the tang breaking tool. The new thread with the ProCoil thread insert is now ready for use. 1 2 3 4 PRECISION TOOLS 207 Standard design, stainless steel and free running. Thread reinforcement for materials with low shearing strenght, e.g. aluminium alloys and magnesium alloys as well as to repair enables worn and damaged threads. Packing unit: in plastic box 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,00 1,25 1,0 1,0 1,0 1,0 1,0 1,0 1,0 1,0 1,0 244 303 244 304 244 305 244 306 244 308 244 310 244 312 244 314 244 315 50 50 50 50 50 50 25 25 25 M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 Mf 14 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,00 1,25 1,5 1,5 1,5 1,5 1,5 1,5 1,5 1,5 1,5 244 403 244 404 244 405 244 406 244 408 244 410 244 412 244 414 244 415 50 50 50 50 50 50 25 25 25 M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 Mf 14 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,00 1,25 2,0 2,0 2,0 2,0 2,0 2,0 2,0 2,0 2,0 244 503 244 504 244 505 244 506 244 508 244 510 244 512 244 514 244 515 50 50 50 50 50 50 25 25 25 Ø1 Ø1 L1 M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 Mf 14 Ø3 L2 Article no. L1 height = factor x Ø L3 Pitch mm L2 Nominal thread size Pin-Breaker Nominal thread size Ø1 mm Ø2 mm Ø3 mm L1 mm L2 mm L3 mm Article no. M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 2,0 2,7 3,5 4,6 6,0 7,5 9,0 10,0 9,8 9,8 9,8 9,8 9,8 9,8 12,2 14,5 6,0 6,0 - 15,0 20,0 22,0 22,0 40,0 40,0 40,0 40,0 75,0 75,0 75,0 75,0 75,0 75,0 75,0 80,0 25,0 20,0 18,0 18,0 - 244 163 244 164 244 165 244 166 244 168 244 170 244 172 244 174 Ø2 Ø2 1 1 1 1 1 1 1 1 fitting-Tools L1 07 Thread Inserts 208 Nominal thread size Ø1 mm L1 mm Article no. M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 2,0 2,8 3,5 4,8 6,0 7,5 9,5 11,2 60,0 60,0 60,0 60,0 80,0 80,0 80,0 80,0 244 183 244 184 244 185 244 186 244 188 244 190 244 192 244 194 PRECISION TOOLS 1 1 1 1 1 1 1 1 Ø1 ProCoil Thread repairing assortment in plastic case 07 Article no. 244 208 Assortment 2 Assortment M 6 - M14 5 twist drills hSS Ø 6,2 - 8,3 - 10,3 - 12,4 - 14,5 mm + 5 single-cut taps dIN 352 hSS M 6 - M 8 - M 10 - M 12 - Mf 14 + 5 fitting tools M 6 - M 8 - M 10 - M 12 - M 14 + 5 pin-Breakers Ø 4,6 - 6,0 - 7,5 - 9,0 - 10,0 mm + 45 inserts M 6 - M 10, each 5 x Ø 1,0 / 1,5 / 2,0: height = 1,0 x Ø + 12 inserts M 12 - Mf 14, each 2 x Ø 1,0 / 1,5 / 2,0: height = 1,0 x Ø 244 209 244 209 Assortment M 5 - M12 5 twist drills hSS Ø 5,2 - 6,2 - 8,3 - 10,3 - 12,4 mm + 5 single-cut taps dIN 352 hSS M 5 - M 6 - M 8 - M 10 - M 12 + 5 fitting tools M 5 - M 6 - M 8 - M 10 - M 12 + 5 pin-Breakers Ø 3,5 - 4,6 - 6,0 - 7,5 - 9,0 mm + 60 inserts M 5 - M 10, each 5 x Ø 1,0 / 1,5 / 2,0 : height = 1,0 x Ø + 6 inserts M 12, each 2 x Ø 1,0 / 1,5 / 2,0 height = 1,0 x Ø 244 208 Assortment 1 PRECISION TOOLS 209 18-piece set of ProCoil thread repairing tools 1 twist drill Ø 3,1 mm + 1 single-cut tap dIN 352 hSS for thread M 3 x 0,5 + 1 fitting tool M 3 + 1 pin-Breaker Ø 2,0 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 200 Set M 4 1 twist drill Ø 4,1 mm + 1 single-cut tap dIN 352 hSS for thread M 4 x 0,7 + 1 fitting tool M 4 + 1 pin-Breaker Ø 2,7 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 201 Set M 5 1 twist drill Ø 5,2 mm + 1 single-cut tap dIN 352 hSS for thread M 5 x 0,8 + 1 fitting tool M 5 + 1 pin-Breaker Ø 3,5 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 202 Set M 6 1 twist drill Ø 6,2 mm + 1 single-cut tap dIN 352 hSS for thread M 6 x 1,0 + 1 fitting tool M 6 + 1 pin-Breaker Ø 4,6 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 203 Set M 8 1 twist drill Ø 8,3 mm + 1 single-cut tap dIN 352 hSS for thread M 8 x 1,25 + 1 fitting tool M 8 + 1 pin-Breaker Ø 6,0 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 204 Set M 10 1 twist drill Ø 10,3 mm + 1 single-cut tap dIN 352 hSS for thread M 10 x 1,5 + 1 fitting tool M 10 + 1 pin-Breaker Ø 7,5 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 205 Set M 12 1 twist drill Ø 12,4 mm + 1 single-cut tap dIN 352 hSS for thread M 12 x 1,75 + 1 fitting tool M 12 + 1 pin-Breaker Ø 9,0 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 206 Set M 14 1 twist drill Ø 14,5 mm + 1 single-cut tap dIN 352 hSS for thread M 14 x 2,0 + 1 fitting tool M 14 + 1 pin-Breaker Ø 10,0 mm + each 5 inserts height = 1,0 x Ø / height = 1,5 x Ø / height = 2,0 x Ø 244 207 210 PRECISION TOOLS 244 206 Set M 3 244 207 Article no. 244 205 07 ProCoil Thread repairing sets in plastic case DIN 338 N C HSS 5xD ≥ Ø 2,0 mm 118° 25-30° Ø1 h8 07 Twist drills dIN 338 type N hSS ground L1 Packing unit: individual plastic pack Steel (N/mm2) < 900 Brass Steel (N/mm2) < 1100 Bronze Steel (N/mm2) < 1300 Plastics Stainless steel Cast iron Aluminium Titanium alloyed for thread Thread core hole Ø1 mm L1 mm L2 mm M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 + Mf 14 3,10 4,10 5,20 6,20 8,30 10,30 12,40 14,50 65,0 75,0 86,0 101,0 117,0 133,0 151,0 169,0 36,0 43,0 52,0 63,0 75,0 87,0 101,0 114,0 800 HSS N/mm² L2 height performance ground twist drill consisting of heavy-duty high speed steel. The fully ground twist drill has a more precise concentricity. Application areas: for steel, alloyed and unalloyed cast iron (up to a strength of 900 N/mm²), grey, malleable, ductile and die-cast iron, sintered iron, nickel silver, graphite, short chipping aluminium alloys, brass and bronze. HSS 214 031 214 041 214 052 214 062 214 083 214 103 214 124 214 145 10 10 10 10 10 10 5 5 M ISO2 6H 60° Ø1 L2 Single-cut taps hSS ground L1 The single-cut tap hSS for through threads in unalloyed and low-alloyed steels up to a strength of 800 N/mm², malleable cast iron and non-ferrous metals. The thread can be cut in one operation by hand or machine. Packing unit: individual plastic pack Steel (N/mm2) < 900 Brass Steel (N/mm2) < 1100 Bronze Steel (N/mm2) < 1300 Plastics Stainless steel Cast iron Aluminium Titanium alloyed for thread Thread core hole Ø1 mm M mm L1 mm L2 mm HSS M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 Mf 14 3,10 4,10 5,20 6,20 8,30 10,30 12,40 14,50 14,50 3,6 4,9 6,0 7,3 9,6 11,9 14,3 16,6 15,6 53,0 58,0 66,0 72,0 80,0 89,0 95,0 102,0 102,0 13,0 16,0 19,0 22,0 24,0 29,0 30,0 32,0 32,0 244 603 244 604 244 605 244 606 244 608 244 610 244 612 244 614 244 615 1 1 1 1 1 1 1 1 1 PRECISION TOOLS 211 07 212 PRECISION TOOLS
244206 价格&库存
很抱歉,暂时无法提供与“244206”相匹配的价格&库存,您可以联系我们找货
