205217
205217
    RUKO
205217 数据手册
Twist drills Twist drills DIN 338 type N HSS rolled, HSS ground, HSS Co 5 ground and HSS-TiN ground 1.1 Ø mm Total length mm Flute length mm Article no. HSS-R Cont. pcs. Article no. HSS-G Cont. pcs. Article no. HSS-G Co 5 Cont. pcs. Article no. HSS-G TiN Cont. pcs. 14,00 14,50 15,00 15,50 16,00 16,50 17,00 17,50 18,00 18,50 19,00 19,50 20,00 160 169 169 178 178 184 184 191 191 198 198 205 205 108 114 114 120 120 125 125 130 130 135 135 140 140 201 140 201 145 201 150 201 155 201 160 201 165 201 170 201 175 201 180 201 185 201 190 201 195 201 200 5 5 5 5 5 1 1 1 1 1 1 1 1 214 140 214 145 214 150 214 155 214 160 — — — — — — — — 5 5 5 5 5 — — — — — — — — 215 140 215 145 215 150 215 155 215 160 — — — — — — — — 5 5 5 5 5 — — — — — — — — 250 140 T 250 145 T 250 150 T 250 155 T 250 160 T — — — — — — — — 5 5 5 5 5 — — — — — — — — Twist drill sets DIN 338 type N HSS rolled, HSS ground, HSS Co 5 ground and HSS-TiN ground in steel case No. 205 212 No. 214 214 No. 215 214 No. 250 214 T Description Article no. HSS-R Article no. HSS-G Article no. HSS-G Co 5 Article no. HSS-G TiN Consisting of 13 twist drills DIN 338 type N Ø 1,5 mm up to 6,5 mm in increments of 0,5 mm + Ø 3,3 and 4,2 mm 205 207 — — — Consisting of 19 twist drills DIN 338 type N Ø 1,0 mm up to 10,0 mm in increments of 0,5 mm 205 212 214 214 215 214 250 214 T Consisting of 25 twist drills DIN 338 type N Ø 1,0 mm up to 13,0 mm in increments of 0,5 mm 205 213 214 215 215 215 250 215 T Consisting of 41 twist drills DIN 338 type N Ø 6,0 mm up to 10,0 mm in increments of 0,1 mm 205 218 214 218 215 218 — Consisting of 50 twist drills DIN 338 type N Ø 1,0 mm up to 5,9 mm in increments of 0,1 mm 205 217 214 217 215 217 — - 19 - Twist drills 1.1 Twist drill sets DIN 338 type N HSS rolled, HSS ground and HSS Co 5 ground in bench stand Description Article no. Consisting of 91 twist drills DIN 338 type N HSS rolled Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm 205 223 Consisting of 91 twist drills DIN 338 type N HSS ground Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm 214 223 Consisting of 91 twist drills DIN 338 type N HSS Co 5 ground Ø 1,0 mm up to 10,0 mm in increments of 0,1 mm 215 223 No. 205 223 Twist drill sets DIN 338 type N HSS ground and HSS Co 5 ground in magazine Description Article no. Consisting of 170 twist drills DIN 338 type N HSS ground 10 pcs, Ø 1,0 - 8,0 mm in increments of 0,5 mm 5 pcs, Ø 8,5 - 10,0 mm in increments of 0,5 mm 214 200 Consisting of 170 twist drills DIN 338 type N HSS Co 5 ground 10 pcs, Ø 1,0 - 8,0 mm in increments of 0,5 mm 5 pcs, Ø 8,5 - 10,0 mm in increments of 0,5 mm 215 200 No. 214 200 Drill cabinet Description Article no. Drill cabinet empty 1 - 13 mm x 0,1 205 2081 L Drill cabinet empty 1 - 13 mm x 0,5 205 208 L Drill cabinet consisting of 570 twist drills DIN 338 type N HSS rolled contents list see below 205 208 Drill cabinet consisting of 570 twist drills DIN 338 type N HSS ground contents list see below 214 208 Drill cabinet consisting of 570 twist drills DIN 338 type N HSS Co 5 ground contents list see below 215 208 No. 205 208 L Contents list: Ø mm x pcs. Ø mm x pcs. Ø mm x pcs. Ø mm x pcs. Ø mm x pcs. 1,0 x 50 1,5 x 50 2,0 x 50 2,5 x 50 3,0 x 30 3,5 x 30 4,0 x 30 4,5 x 30 5,0 x 30 5,5 x 30 6,0 x 20 6,5 x 20 7,0 x 20 7,5 x 20 8,0 x 10 8,5 x 10 9,0 x 10 9,5 x 10 10,0 x 10 10,5 x 10 11,0 x 10 11,5 x 10 12,0 x 10 12,5 x 10 13,0 x 10 - 20 -
205217 价格&库存
很抱歉,暂时无法提供与“205217”相匹配的价格&库存,您可以联系我们找货
