101092
101092
    RUKO
101092 数据手册
Step drills Step drills HSS, CBN ground, spiral fluted with split point Point cut: 1.4 work´s specification with split point DIN 1412 C Point angel: 118° Step angle: 90° Ø-Tolerance: work´s specification Surface: bright Right-hand cutting Packing unit: in plastic tubes of 1 Size no. 0/9k 1k 2k Drilling range mm Total length mm 4,0 - 12,00 4,0 - 20,00 4,0 - 30,00 48 58 72 Ø mm 4,0 mm 5,0 mm 6,0 mm 7,0 mm 8,0 mm 9,0 mm 10,0 mm 11,0 mm 12,0 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Step height 2 mm. Ideal to produce switchboards. Steps 9 9 14 Shank-Ø mm 6 8 10 Article no. Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm No. 0/9k 20,0 mm Price / each € Ø mm 4,0 mm 6,0 mm 8,0 mm 10,0 mm 12,0 mm 14,0 mm 16,0 mm 18,0 mm 20,0 mm 22,0 mm 24,0 mm 26,0 mm 28,0 mm 30,0 mm 101 061 101 062 101 063 No. 1k Step drills HSS, CBN ground, spiral fluted with split point for metric cable connections, through holes after DIN/EN 50262 Point cut: work´s specification with split point DIN 1412 C Point angel: 118° Step angle: 90° Ø-Tolerance: work´s specification Surface: bright Right-hand cutting Packing unit: in plastic tubes of 1 Ø mm 6,5 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Step height 4 mm. Size no. Drilling range mm Total length mm Steps Shank-Ø mm Article no. 15 17 6,5 - 32,5 6,5 - 40,5 79 96 9 11 10 10 101 092 101 090 Price / each € 8,5 mm 12,5 mm 16,5 mm 20,5 mm 25,5 mm 29,0 mm 32,5 mm Ø mm 6,5 mm 8,5 mm 10,5 mm 12,5 mm 16,5 mm work´s specification with split point DIN 1412 C Point angle: 118° Step angel: 90° Ø-Tolerance: work´s specification Surface: bright Right-hand cutting Packing unit: in plastic tubes of 1 20,5 mm No. 15 25,5 mm 29,0 mm 32,5 mm 36,5 mm 40,5 mm Step drills HSS, CBN ground, spiral fluted with split point for metric cable connections, core holes after DIN/EN 60423 Point cut: No. 2k 10,5 mm Ø mm No. 17 5,3 mm 7,0 mm 9,0 mm 10,5 mm The CBN ground and spiral flutes guarantee quiet running and high cutting performance. Especially the chip flow is optimized, so even long, non-breaking chips will be removed easily. The optimized chip flow protects the cutting edges and reduces built-up edges and cold weld marks. The cone makes it easier to withdraw the tool from the material. Step height 4 mm. 14,5 mm 18,5 mm 23,5 mm Ø mm 27,0 mm 5,3 mm 7,0 mm 9,0 mm 10,5 mm 30,5 mm 14,5 mm 18,5 mm 23,5 mm 27,0 mm 30,5 mm No. 14 Size no. Drilling range mm Total length mm Steps Shank-Ø mm Article no. 14 16 5,3 - 30,5 5,3 - 38,5 79 96 9 11 10 10 101 093 101 091 34,5 mm 38,5 mm Price / each € No. 16 - 58 -
101092 价格&库存
很抱歉,暂时无法提供与“101092”相匹配的价格&库存,您可以联系我们找货
