106302
106302
    RUKO
106302 数据手册
COMPETENCE IN PRECISION HOLE SAWS AND QUALITY Hole saws Tungsten carbide hole saws, shallow cut Cutting edges: Material thickness: Cutting depth: Cutting angle: Right-hand cutting 1.9 tungsten carbide up to 4 mm up to max. 10 mm works standard Suitable for high-alloyed steels such as stainless and acidresistant steel (up to 2 mm), steel and cast steel, non-ferrous and light metals, plastics, reinforced fabrics, plasterboard and light building boards, wood. Packing unit: individual carton Ø mm Ø inch 16,0 16,5 17,0 18,0 18,6 19,0 20,0 20,4 21,0 22,0 22,5 23,0 24,0 25,0 25,5 26,0 27,0 28,0 28,3 29,0 30,0 31,0 32,0 32,5 33,0 34,0 35,0 36,0 37,0 38,0 39,0 40,0 40,5 41,0 42,0 43,0 44,0 45,0 46,0 47,0 48,0 49,0 50,0 50,5 51,0 52,0 53,0 54,0 55,0 56,0 57,0 58,0 59,0 60,0 63,5 65,0 5/8 3/4 13/16 7/8 Through dimensions Tube dimensions inch M + PG ~ PG 9 M 16 PG 11 3/8 M 20 / PG 13,5 PG 16 1/2 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 1 7/32 1 1/4 M 25 PG 21 M 32 1 3/8 1 7/16 1 1/2 1 9/16 1 5/8 1 PG 29 M 40 1 11/16 1 3/4 1 7/8 1 31/32 2 2 1/8 3/4 1 1/4 PG 36 M 50 1 1/2 PG 42 2 1/4 2 3/8 2 1/2 ~ PG 48 M 63 2 Shank Ø mm Article no. 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 13 13 13 13 13 13 13 13 13 13 13 13 105 016 105 165 105 017 105 018 105 186 105 019 105 020 105 204 105 021 105 022 105 225 105 023 105 024 105 025 105 255 105 026 105 027 105 028 105 283 105 029 105 030 105 031 105 032 105 325 105 033 105 034 105 035 105 036 105 037 105 038 105 039 105 040 105 405 105 041 105 042 105 043 105 044 105 045 105 046 105 047 105 048 105 049 105 050 105 505 105 051 105 052 105 053 105 054 105 055 105 056 105 057 105 058 105 059 105 060 105 635 105 065 - 180 - Price / each € Characteristics: • Pilot drill HSS Co 5 Split point in accordance with DIN 1412 C • High rotational precision • Sturdy construction • Hole saw and shank in one piece • Triangular shank • With cutting-depth limiter • Positive chipping angle with specially ground cutting edge • Good chip removal • Exchangeable centring drill • Regrindable tungsten-carbide blades • Unsuitable for percussion-drill operation • Only slight pressure required to start drilling • Drill with light, steady pressure • Avoid pendulum movements while drilling • Observe table of drilling speeds • Use prescribed cooling agents RUKO tungsten-carbide-tipped hole saws can be used in hand and pillar drills. When employing pillar drills, use manual advance only. Hole saws Tungsten carbide hole saws, shallow cut Cutting edges: Material thickness: Cutting depth: Cutting angle: Right-hand cutting tungsten carbide up to 4 mm up to max. 10 mm works standard Suitable for high-alloyed steels such as stainless and acidresistant steel (up to 2 mm), steel and cast steel, non-ferrous and light metals, plastics, reinforced fabrics, plasterboard and light building boards, wood. 1.9 Packing unit: individual carton Ø mm 68,0 70,0 75,0 80,0 85,0 90,0 95,0 100,0 110,0 120,0 130,0 140,0 150,0 Ø inch Through dimensions Tube dimensions inch M + PG 2 3/4 3 3/4 5 1/8 5 1/2 Shank Ø mm Article no. 13 13 13 13 13 13 13 13 13 13 13 13 13 105 068 105 070 105 075 105 080 105 085 105 090 105 095 105 100 105 110 105 120 105 130 105 140 105 150 Price / each € No. 105 171 No. 105 173 Pilot drills for tungsten carbide hole saws, shallow cut Version: • HSS Co 5 ground blade split point in accordance with DIN 1412 C • tungsten carbide blade Right-hand cutting Suitable for high-alloyed steels such as stainless and acidresistant steel (up to 2 mm), steel and cast steel, non-ferrous and light metals, plastics, reinforced fabrics, plasterboard and light building boards, wood. No. 105 174 Packing unit: individual carton Material Ø mm Length mm For hole saws Ø mm For hole saws cutting depth Article no. HSS Co 5 HSS Co 5 tungsten carbide tungsten carbide 6,0 8,0 6,0 8,0 52 52 52 52 16,0 - 70,0 75,0 - 150,0 16,0 - 70,0 75,0 - 150,0 shallow shallow shallow shallow 105 170 105 171 105 172 105 173 Ejector spring Price / each € 105 174 Set of tungsten carbide hole saws in plastic case Description Article no. Set of tungsten carbide hole saws with 5 tungsten carbide hole saws Ø 20 mm - 22 mm - 25 mm - 32 mm - 35 mm 1 cutting spray 50 ml 1 extra pilot drill 6,0 mm HSS Co 5 105 300 Set of tungsten carbide hole saws with 4 tungsten carbide hole saws Ø 16,5 mm ≈ M 16, Ø 20,4 mm ≈ M 20 / PG 13,5 Ø 25,5 mm ≈ M 25, Ø 32,5 mm ≈ M 32 1 cutting spray 50 ml 1 extra pilot drill 6,0 mm HSS Co 5 105 302 No. 105 300 Price / set € No. 105 302 - 181 - Hole saws Tungsten carbide multigrade hole saws MHS Cutting edge: Material thickness: Cutting depth: Cutting angle: Adapter: Right-hand cutting 1.9 tungsten carbide 2 to 28 mm up to 28 mm work‘s standard thread M 18 x 6 P1,5 Suitable for high-alloyed steels such as stainless and acidresistant steel, steel and cast steel (up to 20 mm), non-ferrous and light metals, plastics (up to 28 mm). Applications: drills flat materials, tubes, vaulted surfaces, overlapped holes possible. Packing unit: individual plastic pack Ø mm 15,0 16,0 17,0 18,0 19,0 20,0 21,0 22,0 23,0 24,0 25,0 26,0 27,0 28,0 29,0 30,0 31,0 32,0 33,0 34,0 35,0 36,0 37,0 38,0 39,0 40,0 41,0 42,0 43,0 44,0 45,0 46,0 47,0 48,0 49,0 50,0 51,0 52,0 53,0 54,0 55,0 56,0 57,0 58,0 59,0 60,0 65,0 68,0 70,0 75,0 80,0 85,0 90,0 95,0 100,0 Ø inch Tube dimensions inch 5/8 3/4 3/8 7/8 1/2 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 3/4 1 1/4 1 3/8 1 1 1/2 1 5/8 1 11/16 1 3/4 1 1/4 1 7/8 2 2 1/8 2 1/4 2 3/8 2 3/4 3 3/4 1 1/2 Shank Article no. Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm Ø 13 mm H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 H1 / H3 113 015 113 016 113 017 113 018 113 019 113 020 113 021 113 022 113 023 113 024 113 025 113 026 113 027 113 028 113 029 113 030 113 031 113 032 113 033 113 034 113 035 113 036 113 037 113 038 113 039 113 040 113 041 113 042 113 043 113 044 113 045 113 046 113 047 113 048 113 049 113 050 113 051 113 052 113 053 113 054 113 055 113 056 113 057 113 058 113 059 113 060 113 065 113 068 113 070 113 075 113 080 113 085 113 090 113 095 113 100 - 182 - Price / each € Characteristics: • Pilot pin HSS Co 5 Split point in accordance with DIN 1412 C • High rotational precision • Sturdy construction • Ø 15 up to 30 mm hole saw and shank in one piece. Complete with pilot pin and wrench. • Ø 31 up to 100 mm hole saws MHS without arbor • Adapter with triangular shank • Considerably improved cutting behaviour was attained by research into the cutting geome try, which has a beneficial effect on cutting performance and drill life. • Exchangeable pilot pin • Regrindable tungsten-carbide blades • Unsuitable for percussion-drill operation • Only slight pressure required to start drilling • Drill with light, steady pressure • Avoid pendulum movements while drilling • Observe table of drilling speeds (see also tungsten carbide core drill speed table) • Use prescribed cooling agents RUKO tungsten carbide multigrade hole saws MHS can be used on: • Core drilling machines up to 20 mm in steel • Pillar drilling machines up to 20 mm in steel • Hand drilling machines up to 6 mm in steel For cutting depths over 6 mm we recommend to remove the chips from the hole. From Ø 65 mm on we recommend to use our morse taper holder Article no. 113 203. Hole saws Arbor holders for tungsten carbide multigrade hole saws MHS with thread including pilot drill HSS Co 5 Adapter: thread M 18 x 6 P1,5 For tungsten carbide multigrade hole saws MHS from Ø 31 mm up to Ø 100 mm. Packing unit: individual plastic pack No. 113 201 Hole saws Ø mm Type Shank Article no. 31 - 100 31 - 100 H1 H3 Ø 13 mm morse taper no. 2 113 201 113 203 Price / each € 1.9 No. 113 203 Pilot drills for tungsten carbide multigrade hole saws MHS Version: • HSS Co 5 ground blade split point in accordance with DIN 1412 C • tungsten carbide blade Right-hand cutting Suitable for high-alloyed steels such as stainless and acidresistant steel, steel and cast steel (up to 20 mm), non-ferrous and light metals, plastics (up to 28 mm). Applications: drills flat materials, tubes, vaulted surfaces, overlapped holes possible. No. 113 216 Packing unit: individual plastic pack Material Ø mm Length mm For hole saws MHS Ø mm Article no. HSS Co 5 Tungsten carbide 6,0 6,0 71 71 15 - 100 15 - 100 113 216 113 217 Ejector spring 113 218 - 183 - Price / each € No. 113 218 Hole saws Adapter with Weldon shank for tungsten carbide multigrade hole saws in magnetic-stand drilling machine Packing unit: individual plastic pack 1.9 Description Article no. Adapter with Weldon shank 3/4" from Ø 31 mm for tungsten carbide multigrade hole saws MHS with thread retainer M18 x 6 P1,5 108 108 Pilot pin from Ø 31 mm for tungsten carbide multigrade hole saws MHS Ø 6,35 x 95,0 mm 108 110 Price / each € No. 108 108 No. 108 110 Arbor holders for tungsten carbide multigrade hole saws in magnetic-stand drilling machine Packing unit: individual carton Description Article no. MT 2 arbor holder from Ø 31 mm for tungsten carbide multigrade hole saws MHS with thread retainer M18 x 6 P1,5 + Adapter article no. 108 108 + tube + pilot pin article no. 108 110 + cooling bottle article no. 108 101 108 102 MT 3 arbor holder from Ø 31 mm for tungsten carbide multigrade hole saws MHS with thread retainer M18 x 6 P1,5 + Adapter article no. 108 108 + tube + pilot pin article no. 108 110 + cooling bottle article no. 108 101 108 103 Price / each € No. 108 103 Arbor holders with interior cooling for tungsten carbide multigrade hole saws in magnetic-stand drilling machine Packing unit: individual carton Description Article no. MT 2 arbor holder with interior cooling from Ø 31 mm for tungsten carbide multigrade hole saws MHS with thread retainer M18 x 6 P1,5 + Adapter article no. 108 108 + pilot pin article no. 108 110 108 104 MT 3 arbor holder with interior cooling from Ø 31 mm for tungsten carbide multigrade hole saws MHS with thread retainer M18 x 6 P1,5 + Adapter article no. 108 108 + pilot pin article no. 108 110 108 105 NEW Price / each € No. 108 105 - 184 - Hole saws Recommended cutting speeds for tungsten carbide hole saws Material: Vc = m/min coolant High carbon struc. steel up to 700 N/mm² Alloyed steel up to 1000 N/mm² Cast iron over 250 N/mm² CuZn alloy Aluminium alloy up to 11% Si Thermoplastics Duroplastics Wood 50 35 40 60 60 45 40 50 Cutting spray Cutting spray Cutting spray Water Ø mm Ø inch r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. 16,0 16,5 17,0 18,0 18,6 19,0 20,0 20,4 21,0 22,0 22,5 23,0 24,0 25,0 25,5 26,0 27,0 28,0 28,3 29,0 30,0 31,0 32,0 32,5 33,0 34,0 35,0 36,0 37,0 38,0 39,0 40,0 40,5 41,0 42,0 43,0 44,0 45,0 46,0 47,0 48,0 49,0 50,0 50,5 51,0 52,0 53,0 54,0 55,0 56,0 57,0 58,0 59,0 60,0 63,5 65,0 70,0 75,0 80,0 85,0 90,0 95,0 100,0 110,0 120,0 130,0 140,0 150,0 5/8 995 965 937 885 856 838 796 781 758 724 708 692 663 637 624 612 590 569 563 549 531 514 498 490 483 468 455 442 430 419 408 398 393 388 379 370 362 354 346 339 332 325 318 315 312 306 300 295 290 284 279 275 270 265 251 245 227 212 199 187 177 168 159 145 133 122 114 106 697 676 656 619 599 587 557 546 531 507 495 485 464 446 437 429 413 398 394 384 372 360 348 343 338 328 318 310 301 293 286 279 275 272 265 259 253 248 242 237 232 227 223 221 219 214 210 206 203 199 196 192 189 186 176 171 159 149 139 131 124 117 111 101 93 86 80 74 796 772 749 708 685 670 637 624 607 579 566 554 531 510 500 490 472 455 450 439 425 411 398 392 386 375 364 354 344 335 327 318 315 311 303 296 290 283 277 271 265 260 255 252 250 245 240 236 232 227 223 220 216 212 201 196 182 170 159 150 142 134 127 116 106 98 91 85 1194 1158 1124 1062 1027 1006 955 937 910 869 849 831 796 764 749 735 708 682 675 659 637 616 597 588 579 562 546 531 516 503 490 478 472 466 455 444 434 425 415 407 398 390 382 378 375 367 361 354 347 341 335 329 324 318 301 294 273 255 239 225 212 201 191 174 159 147 136 127 1194 1158 1124 1062 1027 1006 955 937 910 869 849 831 796 764 749 735 708 682 675 659 637 616 597 588 579 562 546 531 516 503 490 478 472 466 455 444 434 425 415 407 398 390 382 378 375 367 361 354 347 341 335 329 324 318 301 294 273 255 239 225 212 201 191 174 159 147 136 127 896 869 843 796 770 754 717 703 682 651 637 623 597 573 562 551 531 512 506 494 478 462 448 441 434 422 409 398 387 377 367 358 354 350 341 333 326 318 312 305 299 292 287 284 281 276 270 265 261 256 251 247 243 239 226 220 205 191 179 169 159 151 143 130 119 110 102 96 796 772 749 708 685 670 637 624 607 579 566 554 531 510 500 490 472 455 450 439 425 411 398 392 386 375 364 354 344 335 327 318 315 311 303 296 290 283 277 271 265 260 255 252 250 245 240 236 232 227 223 220 216 212 201 196 182 170 159 150 142 134 127 116 106 98 91 85 995 965 937 885 856 838 796 781 758 724 708 692 663 637 624 612 590 569 563 549 531 514 498 490 483 468 455 442 430 419 408 398 393 388 379 370 362 354 346 339 332 325 318 315 312 306 300 295 290 284 279 275 270 265 251 245 227 212 199 187 177 168 159 145 133 122 114 106 3/4 13/16 7/8 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 1 7/32 1 1/4 1 3/8 1 7/16 1 1/2 1 9/16 1 5/8 1 11/16 1 3/4 1 7/8 1 31/32 2 2 1/8 2 1/4 2 3/8 2 1/2 2 3/4 3 3/4 5 1/8 5 1/2 Compressed air Compressed air - 185 - Compressed air Compressed air 1.9 Hole saws HSS bi-metal hole saws, with varied toothing Cutting edges: Jacket: Cutting depth: Cutting teeth: Right-hand cutting HSS special steel up to max. 38 mm (1 1/2") varied toothing Suitable for unalloyed steel (up to 700 N/mm² strength), non-ferrous and light metals, plastics, plasterboard and light building boards, fibreboard, plywood and wood. Packing unit: individual carton 1.9 Ø mm 14 16 17 19 20 21 22 24 25 27 28 29 30 32 33 35 36 37 38 40 41 43 44 46 48 51 52 54 55 57 59 60 63 64 65 67 68 70 73 76 79 83 86 89 92 95 98 102 105 108 111 114 121 127 140 152 160 168 177 210 Ø inch 9/16 Through dimensions PG 5/8 ~ PG 9 3/4 ~ PG 11 7/8 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 1 1/4 ~ PG 13,5 ~ PG 16 ~ PG 21 1 3/8 1 1/2 1 5/8 1 11/16 1 3/4 1 13/16 1 7/8 2 2 1/8 Tube dimensions inch 3/8 1/2 3/4 1 PG 29 1 1/4 ~ PG 36 1 1/2 PG 42 2 1/4 2 3/8 2 1/2 ~ PG 48 2 2 5/8 2 3/4 2 7/8 3 3 1/8 3 1/4 3 3/8 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/4 4 3/8 4 1/2 4 3/4 5 5 1/2 6 6 5/16 6 5/8 8 9/32 2 1/2 3 3 1/2 4 For arbor holders Article no. A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 106 014 106 016 106 017 106 019 106 020 106 021 106 022 106 024 106 025 106 027 106 028 106 029 106 030 106 032 106 033 106 035 106 036 106 037 106 038 106 040 106 041 106 043 106 044 106 046 106 048 106 051 106 052 106 054 106 055 106 057 106 059 106 060 106 063 106 064 106 065 106 067 106 068 106 070 106 073 106 076 106 079 106 083 106 086 106 089 106 092 106 095 106 098 106 102 106 105 106 108 106 111 106 114 106 121 106 127 106 140 106 152 106 160 106 168 106 177 106 200 - 186 - Price / each € Characteristics: • High rotational precision • Sturdy construction • Hole saw and shank in two parts, so hole saws of different diameters can be exchanged and fitted more rapidly • A1, A2, A5, A6 arbor with hexagonal shank and A7 arbor with SDS-plus shank • A4 arbor with cylindrical shank • Positive chipping and cutting angles ensure more aggressive cutting • Varied toothing ensures: - smoother cutting - less effort - less vibration and heat production during cutting - up to three times longer tool life • The HSS teeth are welded onto a jacket of special steel • Good chip removal • Slots in the jacket side assist removal of cutouts • Exchangeable centring drill • Unsuitable for percussion-drill operation • Only slight pressure required to start drilling • Drill with light, steady pressure • Avoid pendulum movements while drilling • Observe table of drilling speeds • Use prescribed cooling agents RUKO HSS bi-metal hole saws can be used in hand and pillar drills. When employing pillar drills, use manual advance only. Also suitable for other makes of drill. Prices without arbor. Hole saws NEW HSS Co 8 bi-metal hole saws, with fine toothing Cutting edges: Jacket: Cutting depth: Cutting teeth: Right-hand cutting HSS Co 8 special steel up to max. 38 mm (1 1/2") fine toothing Suitable for alloyed and non-alloyed steels (up to 1,000 N/mm² strength), high chromium alloyed steels such as staniless steel, steels resistant to rusts and acids, non-ferrous and light metals. Packing unit: individual carton Ø mm 14 16 17 19 20 21 22 24 25 27 28 29 30 32 33 35 36 37 38 40 41 43 44 46 48 51 52 54 55 57 59 60 63 64 65 67 68 70 73 76 79 83 86 89 92 95 98 102 105 108 111 114 121 127 140 152 160 168 177 210 Ø inch 9/16 Through dimensions PG 5/8 ~ PG 9 3/4 ~ PG 11 7/8 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 1 1/4 ~ PG 13,5 ~ PG 16 ~ PG 21 1 3/8 1 1/2 1 5/8 1 11/16 1 3/4 1 13/16 1 7/8 2 2 1/8 Tube dimensions inch 3/8 1/2 3/4 1 PG 29 1 1/4 ~ PG 36 1 1/2 PG 42 2 1/4 2 3/8 2 1/2 ~ PG 48 2 2 5/8 2 3/4 2 7/8 3 3 1/8 3 1/4 3 3/8 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/4 4 3/8 4 1/2 4 3/4 5 5 1/2 6 6 5/16 6 5/8 8 9/32 2 1/2 3 3 1/2 4 For arbor holders Article no. A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A1 / A4 / A5 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 A2 / A6 / A7 126 014 126 016 126 017 126 019 126 020 126 021 126 022 126 024 126 025 126 027 126 028 126 029 126 030 126 032 126 033 126 035 126 036 126 037 126 038 126 040 126 041 126 043 126 044 126 046 126 048 126 051 126 052 126 054 126 055 126 057 126 059 126 060 126 063 126 064 126 065 126 067 126 068 126 070 126 073 126 076 126 079 126 083 126 086 126 089 126 092 126 095 126 098 126 102 126 105 126 108 126 111 126 114 126 121 126 127 126 140 126 152 126 160 126 168 126 177 126 200 - 187 - 1.9 Price / each € Characteristics: • High rotational precision • Sturdy construction • Hole saw and shank in two parts, so hole saws of different diameters can be exchanged and fitted more rapidly • A1, A2, A5, A6 arbor with hexagonal shank and A7 arbor with SDS-plus shank • A4 arbor with cylindrical shank • The fine toothing ensures: - particularly good suitability for metals - quieter running - less power needed - lower vibrations and development of heat in cutting - the tool life is increased, in particular with metals. • The HSS Co 8 teeth are welded onto a jacket of special steel • Good chip removal • Slots in the jacket side assist removal of cutouts • Exchangeable centring drill • Unsuitable for percussion-drill operation • Only slight pressure required to start drilling • Drill with light, steady pressure • Avoid pendulum movements while drilling • Observe table of drilling speeds • Use prescribed cooling agents RUKO HSS Co 8 bi-metal hole saws can be used in hand and pillar drills. When employing pillar drills, use manual advance only. Also suitable for other makes of drill. Prices without arbor. Hole saws Arbor holders including pilot drill for HSS and HSS Co 8 bi-metal hole saws Packing unit: in individual carton 1.9 Hole saws Ø mm Type Shank Ø mm 14,0 - 30,0 32,0 - 210,0 14,0 - 30,0 14,0 - 30,0 32,0 - 210,0 32,0 - 210,0 A1 A2 A4 A5 A6 A7 11,0 11,0 6,0 9,5 9,5 10,0 Shank shape Thread Article no. 1/2" x 20 x 18 1/2" x 20 1/2" x 20 5/8" x 18 5/8" x 18 106 201 106 202 106 204 106 210 106 209 106 211 5/8" SDS-Plus Price / each € No. 106 202 NEW Adapter for arbor holders, type A1 / A4 / A5 Packing unit: individual plastic pack Description Article no. Adapter to support HSS and HSS Co 8 bi-metal hole saws from Ø 32 to Ø 210 mm 106 212 Price / each € No. 106 212 Accessories for HSS and HSS Co 8 bi-metal hole saws Packing unit: individual plastic pack Description Article no. Pilot drill HSS, ground, Ø 6.35 mm x 102 mm and split point in accordance with DIN 1412 C (A4) 106 207 Pilot drill HSS, ground, Ø 6.35 mm x 82 mm and split point in accordance with DIN 1412 C (A1 + A2 + A5 + A6 + A7) 106 206 Extension 300 mm, arbors for A1 + A2 shank shape 11 mm 106 205 Ejector spring 106 208 Price / each € No. 106 207 No. 106 205 No. 106 208 Sets of HSS bi-metal hole saws in plastic cases Type Description Article no. PK 1 For plumbers 6 HSS bi-metal hole saws Ø 19 - 22 - 29 - 38 - 44 - 57 mm + 2 arbor holders A2 and A4 106 301 PK 2 For plumbers 9 HSS bi-metal hole saws Ø 19 - 22 - 29 - 35 - 38 - 44 - 51 - 57 - 64 mm + 2 arbor holders A2 and A4 106 306 Price / set € Nr. 106 306 - 188 - Hole saws Sets of HSS bi-metal hole saws in plastic cases Type Description Article no. EK 1 For electricians 6 HSS bi-metal hole saws Ø 22 - 29 - 35 - 44 - 51 - 64 mm + 2 arbor holders A2 and A4 106 305 EK 2 For electricians 6 HSS bi-metal hole saws Ø 22 - 29 - 35 - 44 - 51 - 68 mm + 2 arbor holders A2 and A4 106 302 Universal 10 HSS bi-metal hole saws Ø 19 - 22 - 25 - 29 - 35 - 38 - 44 - 51 - 57 - 64 mm + 2 arbor holders A2 and A4 106 303 Super 10 HSS bi-metal hole saws Ø 22 - 25 - 32 - 35 - 41 - 44 - 51 - 54 - 60 - 64 mm + 2 arbor holders A2 and A4 106 304 Premium 15 HSS bi-metal hole saws Ø 16 - 19 - 21 - 24 - 25 - 29 - 32 - 37 40 - 48 - 51 - 54 - 60 - 73 - 83 mm + 2 arbor holders A1 and A2 + 1 Pilot dril HSS Ø 6,35 mm x 82 mm + 1 Extension 300 mm, arbors for A1 and A2 106 318 Price / set € 1.9 No. 106 304 NEW Sets of HSS Co 8 bi-metal hole saws in plastic cases Type Description Article no. PK 1 For plumbers 6 HSS Co 8 bi-metal hole saws Ø 19 - 22 - 29 - 38 - 44 - 57 mm + 2 arbor holders A2 and A4 126 301 PK 2 EK 1 EK 2 For plumbers 9 HSS Co 8 bi-metal hole saws Ø 19 - 22 - 29 - 35 - 38 - 44 - 51 - 57 - 64 mm + 2 arbor holders A2 and A4 For electricians 6 HSS Co 8 bi-metal hole saws Ø 22 - 29 - 35 - 44 - 51 - 64 mm + 2 arbor holders A2 and A4 For electricians 6 HSS Co 8 bi-metal hole saws Ø 22 - 29 - 35 - 44 - 51 - 68 mm + 2 arbor holders A2 and A4 No. 106 318 Price / set € NEW 126 306 NEW 126 305 NEW 126 302 No. 126 306 NEW Universal 10 HSS Co 8 bi-metal hole saws 126 303 Ø 19 - 22 - 25 - 29 - 35 - 38 - 44 - 51 - 57 - 64 mm + 2 arbor holders A2 and A4 NEW Super 10 HSS Co 8 bi-metal hole saws 126 304 Ø 22 - 25 - 32 - 35 - 41 - 44 - 51 - 54 - 60 - 64 mm + 2 arbor holders A2 and A4 NEW Premium 15 HSS Co 8 bi-metal hole saws Ø 16 - 19 - 21 - 24 - 25 - 29 - 32 - 37 40 - 48 - 51 - 54 - 60 - 73 - 83 mm + 2 arbor holders A1 and A2 + 1 Pilot dril HSS Ø 6,35 mm x 82 mm + 1 Extension 300 mm, arbors for A1 and A2 126 318 NEW No. 126 304 - 189 - Hole saws Recommended cutting speeds for HSS and HSS Co 8 bi-metal hole saws Material: High carbon struc.steel up to 700 N/mm² Vc = m/min Coolant 1.9 Alloyed steel up to 1000 N/mm² 30 20 Cutting spray Cutting spray Cast iron over 250 N/mm² CuZn alloy 10 35 Compressed air Compressed air Aluminium alloy up to 11% Si Thermoplastics 30 20 Cutting spray Water Duroplastics Wood 15 40 Compressed air Compressed air Ø mm Ø inch r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. r.p.m. 14 16 17 19 21 22 24 25 27 28 29 30 32 33 35 36 37 38 40 41 43 44 46 48 51 52 54 57 59 60 63 64 65 67 68 70 73 76 79 83 86 89 92 95 98 102 105 108 111 114 121 127 140 152 160 168 177 210 9/16 682 597 562 503 455 434 398 382 354 341 329 318 299 290 273 265 258 251 239 233 222 217 208 199 187 184 177 168 162 159 152 149 147 143 141 136 131 126 121 115 111 107 104 101 97 94 91 88 86 84 79 75 68 63 60 57 54 45 455 398 375 335 303 290 265 255 236 227 220 212 199 193 182 177 172 168 159 155 148 145 138 133 125 122 118 112 108 106 101 100 98 95 94 91 87 84 81 77 74 72 69 67 65 62 61 59 57 56 53 50 45 42 40 38 36 30 227 199 187 168 152 145 133 127 118 114 110 106 100 97 91 88 86 84 80 78 74 72 69 66 62 61 59 56 54 53 51 50 49 48 47 45 44 42 40 38 37 36 35 34 32 31 30 29 29 28 26 25 23 21 20 19 18 15 796 697 656 587 531 507 464 446 413 398 384 372 348 338 318 310 301 293 279 272 259 253 242 232 219 214 206 196 189 186 177 174 171 166 164 159 153 147 141 134 130 125 121 117 114 109 106 103 100 98 92 88 80 73 70 66 63 53 682 597 562 503 455 434 398 382 354 341 329 318 299 290 273 265 258 251 239 233 222 217 208 199 187 184 177 168 162 159 152 149 147 143 141 136 131 126 121 115 111 107 104 101 97 94 91 88 86 84 79 75 68 63 60 57 54 45 455 398 375 335 303 290 265 255 236 227 220 212 199 193 182 177 172 168 159 155 148 145 138 133 125 122 118 112 108 106 101 100 98 95 94 91 87 84 81 77 74 72 69 67 65 62 61 59 57 56 53 50 45 42 40 38 36 30 341 299 281 251 227 217 199 191 177 171 165 159 149 145 136 133 129 126 119 117 111 109 104 100 94 92 88 84 81 80 76 75 73 71 70 68 65 63 60 58 56 54 52 50 49 47 45 44 43 42 39 38 34 31 30 28 27 23 910 796 749 670 607 579 531 510 472 455 439 425 398 386 364 354 344 335 318 311 296 290 277 265 250 245 236 223 216 212 202 199 196 190 187 182 175 168 161 153 148 143 138 134 130 125 121 118 115 112 105 100 91 84 80 76 72 61 5/8 3/4 7/8 15/16 1 1 1/16 1 3/32 1 1/8 1 3/16 1 1/4 1 3/8 1 1/2 1 5/8 1 11/16 1 3/4 1 3/4 1 7/8 2 2 1/8 2 1/4 2 3/8 2 1/2 2 5/8 2 3/4 2 7/8 3 3 1/8 3 1/4 3 3/8 3 1/2 3 5/8 3 3/4 3 7/8 4 4 1/4 4 3/8 4 1/2 4 3/4 5 5 1/2 6 6 5/16 6 5/8 8 9/32 - 190 -
106302 价格&库存
很抱歉,暂时无法提供与“106302”相匹配的价格&库存,您可以联系我们找货
