A106340
A106340
    RUKO
    RUKO - A106340 - Bimetal Hole Saw Set, 8 Piece, Electrician
A106340 数据手册
 Twist drill set DIN 345 type N HSS in steel case Twist drill set DIN 345 type N HSS in steel case Ø 14,0 / 15,0 / 16,0 / 17,0 / 18,0 / 19,0 / 20,0 / 21,0 / 22,0 / 23,0 mm Ø 14,0 / 16,0 / 18,0 / 20,0 / 22,0 / 24,0 / 25,0 / 26,0 / 28,0 / 30,0 mm  Unit  10 Piece Unit 10 Piece       Description Article no. Twist drill set DIN 345 type N HSS A 204 001 Price € Description Article no. Twist drill set DIN 345 type N HSS A 204 002 Twist drill sets DIN 338 type N HSS rolled in plastic bit-box Twist drill sets DIN 338 type N HSS-TiN ground in plastic bit-box Ø 1,0 - 10,0 x 0,5 mm Ø 1,0 - 10,0 x 0,5 mm Unit  25 Piece Unit  25 Piece       Description Article no. Twist drill set DIN 338 type N HSS rolled A 205 225 Price € Description Article no. Twist drill set DIN 338 type N HSS-TiN ground A 250 225 T Drill set with twist drills DIN 338 type N HSS rolled, masonry drills and wood drills in plastic bit-box Bi-metal hole saw set HSS in plastic case 6 twist drills DIN 338 type N HSS rolled Ø 3,0 / 4,0 / 5,0 / 6,0 / 8,0 / 10,0 mm Ø 22,0 / 29,0 / 35,0 / 44,0 / 51,0 / 68,0 mm + 2 arbor holders A2 and A4 6 masonry drills DIN 8039 Ø 3,0 / 4,0 / 5,0 / 6,0 / 8,0 / 10,0 mm  Price € Price € Unit 5 Piece 6 wood drills Ø 3,0 / 4,0 / 5,0 / 6,0 / 8,0 / 10,0 mm        Unit  25 Piece Description Article no. Twist drill set with twist drills, masonry drills and wood drills A 205 226 Price € Description Article no. Bi-metal hole saw set HSS for electricians A 106 340 Price €
A106340 价格&库存
很抱歉,暂时无法提供与“A106340”相匹配的价格&库存,您可以联系我们找货
