A245058ETX
A245058ETX
    RUKO
    Tap Set, Machine, HSSE-Co 5 Series, M3 - M12, 7 Piece
A245058ETX 数据手册
TWIST DRILLS Twist drills DIN 338 type N HSSE-Co 5 ground in plastic box Ø 1,0 - 10,0 mm in plastic box of 10 Ø 10,2 - 13,0 mm in plastic box of 5 mm mm Art.-Nr. Ø mm Ø 1,0 mm Ø 1,5 mm Ø 2,0 mm Ø 2,5 mm Ø 3,0 mm Ø 3,3 mm Ø 3,5 mm Ø 4,0 mm Ø 4,2 mm Ø 4,5 mm Ø 5,0 mm Ø 5,5 mm Ø 6,0 mm Ø 6,5 mm Ø 6,8 mm Ø 7,0 mm Ø 7,5 mm Ø 8,0 mm Ø 8,5 mm Ø 9,0 mm Ø 9,5 mm Ø 10,0 mm Ø 10,2 mm Ø 10,5 mm Ø 11,0 mm Ø 11,5 mm Ø 12,0 mm Ø 12,5 mm Ø 13,0 mm 34,0 mm 40,0 mm 49,0 mm 57,0 mm 61,0 mm 65,0 mm 70,0 mm 75,0 mm 75,0 mm 80,0 mm 86,0 mm 93,0 mm 93,0 mm 101,0 mm 109,0 mm 109,0 mm 109,0 mm 117,0 mm 117,0 mm 125,0 mm 125,0 mm 133,0 mm 133,0 mm 133,0 mm 142,0 mm 142,0 mm 151,0 mm 151,0 mm 151,0 mm 12,0 mm 18,0 mm 24,0 mm 30,0 mm 33,0 mm 36,0 mm 39,0 mm 43,0 mm 43,0 mm 47,0 mm 52,0 mm 57,0 mm 57,0 mm 63,0 mm 69,0 mm 69,0 mm 69,0 mm 75,0 mm 75,0 mm 81,0 mm 81,0 mm 87,0 mm 87,0 mm 87,0 mm 94,0 mm 94,0 mm 101,0 mm 101,0 mm 101,0 mm Twist drills DIN 338 type N HSSE-Co 5 ground in plastic case 215 010 TX 215 015 TX 215 020 TX 215 025 TX 215 030 TX 215 033 TX 215 035 TX 215 040 TX 215 042 TX 215 045 TX 215 050 TX 215 055 TX 215 060 TX 215 065 TX 215 068 TX 215 070 TX 215 075 TX 215 080 TX 215 085 TX 215 090 TX 215 095 TX 215 100 TX 215 102 TX 215 105 TX 215 110 TX 215 115 TX 215 120 TX 215 125 TX 215 130 TX 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 Twist drills DIN 338 type N HSSE-Co 5 ground in steel case Unit Unit 25 Piece 25 Piece Ø 1,0 - 10,0 x 0,5 mm Ø 1,0 - 10,0 x 0,5 mm Unit Unit 20 Piece 20 Piece Ø 1,0 - 13,0 x 0,5 mm 4 Ø 1,0 - 13,0 x 0,5 mm 19-piece set of twist drills A 215 214 RO 19-piece set of twist drills A 215 214 25-piece set of twist drills A 215 215 RO 25-piece set of twist drills A 215 215 TERRAX by RUKO Twist drill magazine DIN 338 type N HSSE-Co 5 ground in steel case 5 pcs. each of Ø 1,0 - 5,0 x 0,5 mm 3 pcs. each of Ø 5,5 - 7,5 x 0,5 mm 2 pcs. each of Ø 8,0 - 10,0 x 0,5 mm Unit 10 Piece Twist drill magazine DIN 338 type N HSSE-Co 5 ground A 215 190 Twist drill magazine DIN 338 type N HSSE-Co 5 ground in steel case 10 pcs. each of Ø 1,0 - 6,0 x 0,5 mm 10 pcs. each of Ø 3,3 + 4,2 mm Unit 10 Piece Twist drill magazine DIN 338 type N HSSE-Co 5 ground A 215 195 Twist drill magazine DIN 338 type N HSSE-Co 5 ground in steel case 10 pcs. each of Ø 1,0 - 8,0 x 0,5 mm 5 pcs. each of Ø 8,5 - 10,0 x 0,5 mm Unit 10 Piece Twist drill magazine DIN 338 type N HSSE-Co 5 ground A 215 200 TERRAX by RUKO 5 Twist drills DIN 338 type N HSS ground in plastic box Ø 1,0 - 10,0 mm in plastic box of 10 Ø 10,2 - 13,0 mm in plastic box of 5 mm mm Art.-Nr. Ø mm Ø 1,0 mm Ø 1,5 mm Ø 2,0 mm Ø 2,5 mm Ø 3,0 mm Ø 3,3 mm Ø 3,5 mm Ø 4,0 mm Ø 4,2 mm Ø 4,5 mm Ø 5,0 mm Ø 5,5 mm Ø 6,0 mm Ø 6,5 mm Ø 6,8 mm Ø 7,0 mm Ø 7,5 mm Ø 8,0 mm Ø 8,5 mm Ø 9,0 mm Ø 9,5 mm Ø 10,0 mm Ø 10,2 mm Ø 10,5 mm Ø 11,0 mm Ø 11,5 mm Ø 12,0 mm Ø 12,2 mm Ø 12,5 mm Ø 13,0 mm 34,0 mm 40,0 mm 49,0 mm 57,0 mm 61,0 mm 65,0 mm 70,0 mm 75,0 mm 75,0 mm 80,0 mm 86,0 mm 93,0 mm 93,0 mm 101,0 mm 109,0 mm 109,0 mm 109,0 mm 117,0 mm 117,0 mm 125,0 mm 125,0 mm 133,0 mm 133,0 mm 133,0 mm 142,0 mm 142,0 mm 151,0 mm 151,0 mm 151,0 mm 151,0 mm 12,0 mm 18,0 mm 24,0 mm 30,0 mm 33,0 mm 36,0 mm 39,0 mm 43,0 mm 43,0 mm 47,0 mm 52,0 mm 57,0 mm 57,0 mm 63,0 mm 69,0 mm 69,0 mm 69,0 mm 75,0 mm 75,0 mm 81,0 mm 81,0 mm 87,0 mm 87,0 mm 87,0 mm 94,0 mm 94,0 mm 101,0 mm 101,0 mm 101,0 mm 101,0 mm Twist drills DIN 338 type N HSS ground in plastic case 214 010 TX 214 015 TX 214 020 TX 214 025 TX 214 030 TX 214 033 TX 214 035 TX 214 040 TX 214 042 TX 214 045 TX 214 050 TX 214 055 TX 214 060 TX 214 065 TX 214 068 TX 214 070 TX 214 075 TX 214 080 TX 214 085 TX 214 090 TX 214 095 TX 214 100 TX 214 102 TX 214 105 TX 214 110 TX 214 115 TX 214 120 TX 214 122 TX 214 125 TX 214 130 TX 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 Twist drills DIN 338 type N HSS ground in steel case VPE VPE 25 Stück 25 Stück Ø 1,0 - 10,0 x 0,5 mm Ø 1,0 - 10,0 x 0,5 mm VPE VPE 20 Stück 20 Stück Ø 1,0 - 13,0 x 0,5 mm 6 Ø 1,0 - 13,0 x 0,5 mm 19-piece set of twist drills A 214 214 RO 19-piece set of twist drills A 214 214 25-piece set of twist drills A 214 215 RO 25-piece set of twist drills A 214 215 TERRAX by RUKO Twist drills magazine DIN 338 type N HSS ground in plastic case 10 pcs. each of Ø 1,0 - 8,0 x 0,5 mm 5 pcs. each of Ø 8,5 - 10,0 x 0,5 mm Unit 10 Piece Twist drills magazine DIN 338 type N HSS ground Twist drill magazine DIN 338 type N HSS ground in steel case 10 pcs. each of Ø 1,0 - 6,0 x 0,5 mm 10 pcs. each of Ø 3,3 + 4,2 mm Twist drill magazine DIN 338 type N HSS ground in steel case 10 pcs. each of Ø 1,0 - 8,0 x 0,5 mm 5 pcs. each of Ø 8,5 - 10,0 x 0,5 mm Unit Unit 10 Piece 10 Piece Twist drill magazine DIN 338 type N HSS ground A 214 195 Twist drill magazine DIN 338 type N HSS ground in steel case 10 pcs. each of Ø 1,0 - 8,0 x 0,5 mm 5 pcs. each of Ø 8,5 - 13,0 x 0,5 mm 10 pcs. each of Ø 3,3 + 4,2 mm A 214 200 RO Twist drill magazine DIN 338 type N HSS ground A 214 200 Twist drill set DIN 345 type N HSS in steel case VPE 10 Stück Unit 10 Piece VPE 10 Stück Twist drills magazine DIN 338 type N HSS ground A 214 220 Ø 14,0 / 15,0 / 16,0 / 17,0 / 18,0 / 19,0 / 20,0 / 21,0 / 22,0 / 23,0 mm A 204 001 Ø 14,0 / 16,0 / 18,0 / 20,0 / 22,0 / 24,0 / 25,0 / 26,0 / 28,0 / 30,0 mm A 204 002 TERRAX by RUKO 7 Twist drills DIN 338 type N HSS rolled in plastic box Ø 1,0 - 10,0 mm in plastic box of 10 Ø 10,2 - 13,0 mm in plastic box of 5 mm mm Art.-Nr. Ø mm Ø 1,0 mm Ø 1,5 mm Ø 2,0 mm Ø 2,5 mm Ø 3,0 mm Ø 3,3 mm Ø 3,5 mm Ø 4,0 mm Ø 4,2 mm Ø 4,5 mm Ø 5,0 mm Ø 5,5 mm Ø 6,0 mm Ø 6,5 mm Ø 6,8 mm Ø 7,0 mm Ø 7,5 mm Ø 8,0 mm Ø 8,5 mm Ø 9,0 mm Ø 9,5 mm Ø 10,0 mm Ø 10,2 mm Ø 10,5 mm Ø 11,0 mm Ø 11,5 mm Ø 12,0 mm Ø 12,2 mm Ø 12,5 mm Ø 13,0 mm 34,0 mm 40,0 mm 49,0 mm 57,0 mm 61,0 mm 65,0 mm 70,0 mm 75,0 mm 75,0 mm 80,0 mm 86,0 mm 93,0 mm 93,0 mm 101,0 mm 109,0 mm 109,0 mm 109,0 mm 117,0 mm 117,0 mm 125,0 mm 125,0 mm 133,0 mm 133,0 mm 133,0 mm 142,0 mm 142,0 mm 151,0 mm 151,0 mm 151,0 mm 151,0 mm 12,0 mm 18,0 mm 24,0 mm 30,0 mm 33,0 mm 36,0 mm 39,0 mm 43,0 mm 43,0 mm 47,0 mm 52,0 mm 57,0 mm 57,0 mm 63,0 mm 69,0 mm 69,0 mm 69,0 mm 75,0 mm 75,0 mm 81,0 mm 81,0 mm 87,0 mm 87,0 mm 87,0 mm 94,0 mm 94,0 mm 101,0 mm 101,0 mm 101,0 mm 101,0 mm Twist drill sets DIN 338 type N HSS rolled in plastic case 201 010 TX 201 015 TX 201 020 TX 201 025 TX 201 030 TX 201 033 TX 201 035 TX 201 040 TX 201 042 TX 201 045 TX 201 050 TX 201 055 TX 201 060 TX 201 065 TX 201 068 TX 201 070 TX 201 075 TX 201 080 TX 201 085 TX 201 090 TX 201 095 TX 201 100 TX 201 102 TX 201 105 TX 201 110 TX 201 115 TX 201 120 TX 201 122 TX 201 125 TX 201 130 TX 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 Twist drill sets DIN 338 type N HSS rolled in steel case Unit Unit 25 Piece 25 Piece Ø 1,0 - 10,0 x 0,5 mm Ø 1,0 - 10,0 x 0,5 mm Unit Unit 20 Piece 20 Piece Ø 1,0 - 13,0 x 0,5 mm 8 Ø 1,0 - 13,0 x 0,5 mm 19-piece set of twist drills A 205 210 RO 19-piece set of twist drills A 205 210 25-piece set of twist drills A 205 211 RO 25-piece set of twist drills A 205 211 TERRAX by RUKO Twist drill magazine DIN 338 type N HSS rolled in steel case Twist drill magazine DIN 338 type N HSS rolled in steel case 10 pcs. each of Ø 1,0 - 8,0 x 0,5 mm 5 pcs. each of Ø 8,5 - 10,0 x 0,5 mm 10 pcs. each of Ø 1,0 - 6,0 x 0,5 mm 10 pcs. each of Ø 3,3 + 4,2 mm Unit Unit 10 Piece 10 Piece Twist drill magazine DIN 338 type N HSS rolled A 205 195 Twist drill magazine DIN 338 type N HSS rolled A 205 200 TERRAX by RUKO 9 Twist drills DIN 338 type N HSS-TiN ground in plastic box Ø 1,0 - 10,0 mm in plastic box of 10 Ø 10,2 - 13,0 mm in plastic box of 5 mm mm mm Ø mm Ø 1,0 mm Ø 1,5 mm Ø 2,0 mm Ø 2,5 mm Ø 3,0 mm Ø 3,3 mm Ø 3,5 mm Ø 4,0 mm Ø 4,2 mm Ø 4,5 mm Ø 5,0 mm Ø 5,5 mm Ø 6,0 mm Ø 6,5 mm Ø 6,8 mm mm Ø mm 34,0 mm 40,0 mm 49,0 mm 57,0 mm 61,0 mm 65,0 mm 70,0 mm 75,0 mm 75,0 mm 80,0 mm 86,0 mm 93,0 mm 93,0 mm 101,0 mm 109,0 mm 12,0 mm 18,0 mm 24,0 mm 30,0 mm 33,0 mm 36,0 mm 39,0 mm 43,0 mm 43,0 mm 47,0 mm 52,0 mm 57,0 mm 57,0 mm 63,0 mm 69,0 mm 250 010 TX 250 015 TX 250 020 TX 250 025 TX 250 030 TX 250 033 TX 250 035 TX 250 040 TX 250 042 TX 250 045 TX 250 050 TX 250 055 TX 250 060 TX 250 065 TX 250 068 TX Ø 7,0 mm Ø 7,5 mm Ø 8,0 mm Ø 8,5 mm Ø 9,0 mm Ø 9,5 mm Ø 10,0 mm Ø 10,2 mm Ø 10,5 mm Ø 11,0 mm Ø 11,5 mm Ø 12,0 mm Ø 12,2 mm Ø 12,5 mm Ø 13,0 mm 109,0 mm 109,0 mm 117,0 mm 117,0 mm 125,0 mm 125,0 mm 133,0 mm 133,0 mm 133,0 mm 142,0 mm 142,0 mm 151,0 mm 151,0 mm 151,0 mm 151,0 mm 69,0 mm 69,0 mm 75,0 mm 75,0 mm 81,0 mm 81,0 mm 87,0 mm 87,0 mm 87,0 mm 94,0 mm 94,0 mm 101,0 mm 101,0 mm 101,0 mm 101,0 mm 250 070 TX 250 075 TX 250 080 TX 250 085 TX 250 090 TX 250 095 TX 250 100 TX 250 102 TX 250 105 TX 250 110 TX 250 115 TX 250 120 TX 250 122 TX 250 125 TX 250 130 TX Twist drills magazine DIN 338 type N HSS-TiN ground in plastic case 10 pcs. each of Ø 1,0 - 8,0 x 0,5 mm 5 pcs. each of Ø 8,5 - 10,0 x 0,5 mm Twist drills magazine DIN 338 type N HSS ground A 250 200 RO Twist drills DIN 338 type N HSS-TiN ground in plastic case Twist drills DIN 338 type N HSS-TiN ground in steel case Unit Unit 25 Piece 25 Piece Ø 1,0 - 10,0 x 0,5 mm Ø 1,0 - 10,0 x 0,5 mm Unit Unit 20 Piece 20 Piece Ø 1,0 - 13,0 x 0,5 mm 10 Ø 1,0 - 13,0 x 0,5 mm 19-piece set of twist drills A 250 214 TRO 19-piece set of twist drills A 250 214 T 25-piece set of twist drills A 250 215 TRO 25-piece set of twist drills A 250 215 T TERRAX by RUKO STEP DRILLS Step drills HSS + HSS-TiN, CBN ground, straight cut with split point Point cut: work´s specification with split point DIN 1412 C Point angle: 118° Step angle: 90° Ø tolerance: works specification Surface: bright / titanium-nitride coated right hand cutting Size 0/9 I Ø 4,0 - 12,0 mm Size 1 I Ø 4,0 - 20,0 mm Size 2 I Ø 6,0 - 30,0 mm Packing unit: in plastic box of 1 Size no. 0/9 1 2 Drilling range Size no. 4,0 - 12,0 A101 050-9 TX 4,0 - 20,0 A101 051 TX 6,0 - 30,0 A101 052 TX Step drill set HSS, straight cut in plastic case Unit Unit 5 Piece 5 Piece 3-piece set of step drills HSS, sizes 0/9, 1, 2 TERRAX by RUKO 4,0 - 12,0 A 101 050-9 TTX 4,0 - 20,0 A 101 051 TTX 6,0 - 30,0 A 101 052 TTX Step drill set HSS-TiN, straight cut in plastic case Size 0/9 / Size 1 / Size 2 12 0/9 1 2 Drilling range Size 0/9 / Size 1 / Size 2 A 101 126 RO 3-piece set of step drills HSS-TiN, sizes 0/9, 1, 2 A 101 126 TRO TAPER AND DEBURRING COUNTERSINKER Taper and deburring countersinker HSS + HSS-TiN DIN 335 type C 90° Counters. angle: Shank: Cutting edges: Surface: right hand cutting 90° cylindrical 3 bright / titanium-nitride Packing unit: in plastic tubes of 1 Ø2 mm mm 6,3 8,3 10,4 12,4 16,5 20,5 45,0 50,0 50,0 56,0 60,0 63,0 102 107 TX 102 111 TX 102 114 TX 102 116 TX 102 119-1 TX 102 121 TX mm 6,3 8,3 10,4 12,4 16,5 20,5 45,0 50,0 50,0 56,0 60,0 63,0 102 107 TTX 102 111 TTX 102 114 TTX 102 116 TTX 102 119 -1 TTX 102 121 TTX Taper and deburring countersinker set HSS, in plastic box Taper and deburring countersinker set HSS-TiN, in plastic box Unit Unit 5 Piece 5 Piece DIN 335 type C 90° Ø 6,3 - 8,3 - 10,4 - 12,4 16,5 - 20,5 mm Taper and deburring countersinker set DIN 335 type C 90° 14 1,85 € 2,00 € 2,15 € 2,25 € 2,95 € 3,50 € Ø2 mm TERRAX by RUKO DIN 335 type C 90° Ø 6,3 - 8,3 - 10,4 - 12,4 16,5 - 20,5 mm A 102 152 RO Taper and deburring countersinker set DIN 335 type C 90° A 102 152 TRO CORE DRILLS Core drills HSS + HSS-TiN with weldon shank (3/4"), CBN ground, cutting depth 30,0 mm Core drill made of heavy-duty high speed steel. Suitable for steel (such as T-brackets, large sheets), cast iron, non-ferrous and light metals. Packing unit: in plastic tubes of 1 Ø mm mm 12,0 14,0 16,0 18,0 20,0 22,0 24,0 26,0 28,0 30,0 32,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 108 212 TX 108 214 TX 108 216 TX 108 218 TX 108 220 TX 108 222 TX 108 224 TX 108 226 TX 108 228 TX 108 230 TX 108 232 TX 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 30,0 108 212 TTX 108 214 TTX 108 216 TTX 108 218 TTX 108 220 TTX 108 222 TTX 108 224 TTX 108 226 TTX 108 228 TTX 108 230 TTX 108 232 TTX Ø mm mm 12,0 14,0 16,0 18,0 20,0 22,0 24,0 26,0 28,0 30,0 32,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 19,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 63,0 Pilot pin Ø 6,35 x 77,0 mm for core drills HSS with weldon shank (¾") Set of core drills HSS with weldon shank (3/4"), CBN ground, in steel case Set of core drills HSS-TiN with weldon shank (3/4"), CBN ground, in steel case Unit Unit 5 Piece 5 Piece Ø 12,0 - 14,0 - 16,0 18,0 - 20,0 - 22,0 mm + 1 pilot pin Ø 6,35 mm Ø 12,0 - 14,0 - 16,0 18,0 - 20,0 - 22,0 mm + 1 pilot pin Ø 6,35 mm Set of core drills HSS with weldon shank 16 108 304 TX TERRAX by RUKO A 108 820 Set of core drills HSS-TiN with weldon shank A 108 820 T THREAD-CUTTING Thread-cutting set HSS in steel case Hand tap set HSS in steel case Unit Unit 25 Piece 25 Piece One three-piece set of hand taps DIN 352 HSS M 3 / M 4 / M 5 / M 6 / M 8 / M 10 / M 12 HSS ground M3 - M12 + die stock DIN 225 – 25,0 x 9,0 mm Thread-cutting set, 8 pcs. A 245 014 Thread-cutting set, 21 pcs. Thread-cutting set HSS in steel case Unit 20 Piece + 1 hand tap set DIN 352 HSS / M3 - M12 + die stock DIN 225 – 25,0 x 9,0 mm + 1 tap wrench DIN 1814 Size 1½ + 1 screwdriver Thread-cutting set, 31 pcs. A 245 013 Thread-cutting set HSS in plastic case Unit 25 Piece Hand tap set DIN 352 HSS / M3 - M12 + die stock DIN 225 – 20,0 x 5,0 / 20,0 x 7,0 / 25,0 x 9,0 / 30,0 x 11,0 / 38,0 x 14,0 mm + twist drills DIN 338 type N HSS ground – Ø 2,5 / 3,3 / 4,2 / 5,0 / 6,8 / 8,5 / 10,2 mm + tap wrench size 1 / size 2 DIN 1814 + 1 steel tap wrench size 1 + 1 screwdriver + 1 screw-pitch gauge Thread-cutting set, 45 pcs. 18 TERRAX by RUKO A 245 021 A 245 006 Thread-cutting set HSS in steel case Unit 5 Piece Hand tap set DIN 352 HSS / M3 - M12 + die stock DIN 225 – 20,0 x 5,0 / 20,0 x 7,0 / 25,0 x 9,0 / 30,0 x 11,0 / 38,0 x 14,0 mm + tap wrench size 1 + 2 DIN 1814 + 1 screwdriver + 1 screw-pitch gauge Thread-cutting set, 37 pcs. A 245 020 Thread-cutting set HSS in steel case Unit 5 Piece Hand tap set DIN 352 HSS / M3 - M12 + + + + + die stock DIN 225 – 20,0 x 5,0 / 20,0 x 7,0 / 25,0 x 9,0 / 30,0 x 11,0 / 38,0 x 14,0 mm twist drills DIN 338 type N HSS-R – Ø 2,5 / 3,3 / 4,2 / 5,0 / 6,8 / 8,5 / 10,2 mm tap wrench size 1 + 2 DIN 1814 1 screwdriver 1 screw-pitch gauge Thread-cutting set, 44 pcs. A 245 030 Thread-cutting set HSS in steel case Unit 5 Piece Hand tap set DIN 352 HSS / M3 - M20 + die stock DIN 225 – 20,0 x 5,0 / 20,0 x 7,0 / 25,0 x 9,0 / 30,0 x 11,0 / 38,0 x 14,0 / 45,0 x 18,0 mm + tap wrench size 1 + 3 DIN 1814 + 1 screwdriver + 1 screw-pitch gauge Thread-cutting set, 54 pcs. A 245 040 TERRAX by RUKO 19 Hand taps M DIN 352 HSS ground in plastic case Taper tap: Second tap: Final tap: 5 - 6 thread chamfer 4 - 5 thread chamfer 2 - 3 thread chamfer Thread: metric, DIN ISO 13 Tolerance: ISO 2 / 6H right hand cutting M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 M 16 M 18 M 20 Pitch mm Thread core hole Ø mm mm 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,00 2,00 2,50 2,50 2,5 3,3 4,2 5,0 6,8 8,5 10,2 12,0 14,0 15,5 17,5 40,0 45,0 50,0 56,0 63,0 70,0 75,0 80,0 80,0 95,0 95,0 mm 10,0 12,0 13,0 15,0 18,0 24,0 29,0 30,0 32,0 40,0 40,0 230 030 TX 230 040 TX 230 050 TX 230 060 TX 230 080 TX 230 100 TX 230 120 TX 230 140 TX 230 160 TX 230 180 TX 230 200 TX Round dies M DIN EN 22568 HSS ground in plastic case Type: Thread: Tolerance: Type B closed, preslotted metric, DIN ISO 13 ISO - 6g Surface: bright right hand cutting Pitch mm M 3 M 4 M 5 M 6 M 8 M 10 M 12 M 14 M 16 M 18 M 20 20 TERRAX by RUKO 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,00 2,00 2,50 2,50 Thickness mm 5,0 5,0 7,0 7,0 9,0 11,0 14,0 14,0 18,0 18,0 18,0 Outside Ø mm 20,0 20,0 20,0 20,0 25,0 38,0 38,0 38,0 45,0 45,0 45,0 237 030 TX 237 040 TX 237 050 TX 237 060 TX 237 080 TX 237 100 TX 237 120 TX 237 140 TX 237 160 TX 237 180 TX 237 200 TX MACHINE TAPS Machine taps M DIN 371 / 376 type B with progressive tap HSS ground Machine taps with reinforced shank for through threads. Chamfer: Thread: Flanks: M 3 M 4 M 5 M 6 M 8 M 10 M 12 type B, 4 - 5 threads with progressive tap metric, DIN ISO 13 relief-ground mm Pitch mm Thread core hole mm mm 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,5 3,3 4,2 5,0 6,8 8,5 10,2 56,0 63,0 70,0 80,0 90,0 100,0 110,0 Ø shank mm 11,0 13,0 16,0 19,0 22,0 24,0 28,0 3,5 4,5 6,0 6,0 8,0 10,0 9,0 232 030 TX 232 040 TX 232 050 TX 232 060 TX 232 080 TX 232 100 TX 232 120 TX Machine taps M DIN 371 / 376 type C / 35° righthand spiral flutes HSS ground Machine taps with reinforced shank and 35° right-hand spiral flutes for bottoming. Chamfer: Thread: Flanks: M 3 M 4 M 5 M 6 M 8 M 10 M 12 type C / 35° right-hand spiral flutes, 2-3 threads metric, DIN ISO 13 relief-ground Pitch mm Thread core hole mm mm 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,5 3,3 4,2 5,0 6,8 8,5 10,2 56,0 63,0 70,0 80,0 90,0 100,0 110,0 Machine tap set HSS, in plastic case Unit 5 Piece Unit 5 Piece 22 M DIN 371 / 376 - type B / M3 - M12 A 245 057 TX M DIN 371 / 376 - type C / 35° RSP / M3 - M12 A 245 058 TX TERRAX by RUKO mm 11,0 13,0 16,0 19,0 22,0 24,0 28,0 Ø shank mm 3,5 4,5 6,0 6,0 8,0 10,0 9,0 234 030 TX 234 040 TX 234 050 TX 234 060 TX 234 080 TX 234 100 TX 233 120 TX Machine taps M DIN 371 / 376 type B with progressive tap HSS ground Machine taps with reinforced shank for through threads. Chamfer: Thread: Flanks: M 3 M 4 M 5 M 6 M 8 M 10 M 12 type B, 4 - 5 threads with progressive tap metric, DIN ISO 13 relief-ground mm Pitch mm Thread core hole mm mm 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,5 3,3 4,2 5,0 6,8 8,5 10,2 56,0 63,0 70,0 80,0 90,0 100,0 110,0 Ø shank mm 11,0 13,0 16,0 19,0 22,0 24,0 28,0 3,5 4,5 6,0 6,0 8,0 10,0 9,0 232 030 ETX 232 040 ETX 232 050 ETX 232 060 ETX 232 080 ETX 232 100 ETX 232 120 ETX Machine taps M DIN 371 / 376 type C / 35° righthand spiral flutes HSS ground Machine taps with reinforced shank and 35° right-hand spiral flutes for bottoming. Chamfer: Thread: Flanks: M 3 M 4 M 5 M 6 M 8 M 10 M 12 type C / 35° right-hand spiral flutes, 2-3 threads metric, DIN ISO 13 relief-ground Pitch mm Thread core hole mm mm 0,50 0,70 0,80 1,00 1,25 1,50 1,75 2,5 3,3 4,2 5,0 6,8 8,5 10,2 56,0 63,0 70,0 80,0 90,0 100,0 110,0 mm 11,0 13,0 16,0 19,0 22,0 24,0 28,0 Ø shank mm 3,5 4,5 6,0 6,0 8,0 10,0 9,0 234 030 ETX 234 040 ETX 234 050 ETX 234 060 ETX 234 080 ETX 234 100 ETX 233 120 ETX Machine tap set HSSE-Co 5, in plastic case Unit 5 Piece Unit 5 Piece M DIN 371 / 376 - type B / M3 - M12 A 245 057 ETX M DIN 371 / 376 - type C / 35° RSP / M3 - M12 A 245 058 ETX TERRAX by RUKO 23
A245058ETX 价格&库存
很抱歉,暂时无法提供与“A245058ETX”相匹配的价格&库存,您可以联系我们找货
