109320
109320
    RUKO
109320 数据手册
Screw-hole punches Screw-hole punches with three-point cutting tip Die: Mat. thickness: Material: Draw-in bolt: three-point cutting tip up to 4 mm special steel metric fine-threads, from MF 10 grade 12.9 Suitable for sheet steel, stainless-steel sheets, non-ferrous and light metals, plastics. Ideal for switchgear manufacturers, electricians, plumbers, industry and handicrafts. Packing unit: individual cartons Ø mm 12,7 14,0 15,2 16,0 16,5 17,0 18,0 18,6 19,0 20,0 20,4 21,0 22,0 22,5 23,0 24,0 25,0 25,4 26,0 27,0 28,3 29,0 30,0 31,0 32,0 32,5 33,0 34,0 35,0 36,0 37,0 38,0 39,0 40,0 40,5 41,0 42,0 43,0 44,0 45,0 46,0 47,0 48,0 49,0 50,0 50,5 51,0 52,0 53,0 54,0 55,0 60,0 63,5 1.10 Through dimensions Draw-in bolt M + PG MF M 12 / PG 7 PG 9 M 16 PG 11 M 20 / PG 3,5 PG 16 M 25 PG 21 M 32 PG 29 M 40 PG 36 M 50 PG 42 ~ PG 48 M 63 MF 8 MF 8 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 10 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 12 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 MF 16 Article no. standard 109 127 109 140 109 152 109 160 109 165 109 170 109 180 109 186 109 190 109 200 109 204 109 210 109 220 109 225 109 230 109 240 109 250 109 254 109 260 109 270 109 283 109 290 109 300 109 310 109 320 109 325 109 330 109 340 109 350 109 360 109 370 109 380 109 390 109 400 109 405 109 410 109 420 109 430 109 440 109 450 109 460 109 470 109 480 109 490 109 500 109 505 109 510 109 520 109 530 109 540 109 550 109 600 109 635 Price / each € standard Article no. ball bearing — — 109 152 K 109 160 K 109 165 K 109 170 K 109 180 K 109 186 K 109 190 K 109 200 K 109 204 K 109 210 K 109 220 K 109 225 K 109 230 K 109 240 K 109 250 K 109 254 K 109 260 K 109 270 K 109 283 K 109 290 K 109 300 K 109 310 K 109 320 K 109 325 K 109 330 K 109 340 K 109 350 K 109 360 K 109 370 K 109 380 K 109 390 K 109 400 K 109 405 K 109 410 K 109 420 K 109 430 K 109 440 K 109 450 K 109 460 K 109 470 K 109 480 K 109 490 K 109 500 K 109 505 K 109 510 K 109 520 K 109 530 K 109 540 K 109 550 K 109 600 K 109 635 K - 193 - Price / each € ball bearing No. 109 300 ● Cuts holes in thin materials quickly, easily, cleanly and without burrs in a few simple operations ● Three-point cut gives improved contact and thus less deformation of the punched parts, preventing damage to the draw-in bolt ● The ball bearing between draw-in bolt and die plate makes handling even simpler and quicker, reducing the force required by approx. 67% ● Before the screw-hole punch is used, the draw-in bolt should always be lubricated with RUKO cutting spray or cutting paste ● The metric draw-in bolts of RUKO screw hole punches are always of the highest quality grade and are thus designed for extreme loads. If lost, they can be replaced for short periods of time by standard metric fine threaded bolts ● Particularly suitable for use with spanners, manual or foot-operated hydraulic punches ● Special sizes available on request No. 109 300 K
109320 价格&库存
很抱歉,暂时无法提供与“109320”相匹配的价格&库存,您可以联系我们找货
