101 020
101 020
    RUKO
    RUKO - 101 020 - Drill Bit Set, Taper, 1mm - 3 mm, 3 Piece
101 020 数据手册
Tube and sheet drills Tube and sheet drill set HSS, CBN ground in polystyrene case Contents Article no. Tube and sheet drills HSS sizes 1, 2, 3 and 1 cutting spray 50 ml 101 009 1.3 Price / set € No. 101 009 Tube and sheet drill set HSS, CBN ground in steel case Contents Article no. Tube and sheet drills HSS sizes 1, 2, 3 and 1 cutting paste 30 g 101 020 Price / set € No. 101 020 Tube and sheet drill set HSS Co 5, CBN ground in steel case Contents Tube and sheet drills HSS Co 5 sizes 1, 2, 3 and 1 cutting paste 30 g Article no. Price / set € 101 020 E No. 101 020 E Tube and sheet drill set HSS-TiN, CBN ground in steel case Contents Tube and sheet drills HSS-TiN sizes 1, 2, 3 and 1 cutting paste 30 g Article no. Price / set € 101 020 T No. 101 020 T Tube and sheet drill set HSS “Antenna”, CBN ground in steel case Contents Article no. Tube and sheet drills HSS sizes 8, 9 and 1 milling drill HSS Ø 6,0 mm x 90 mm 101 023 Price / set € No. 101 023 - 53 -
101 020 价格&库存
很抱歉,暂时无法提供与“101 020”相匹配的价格&库存,您可以联系我们找货
