214 009
214 009
    RUKO
    RUKO - 214 009 - Twist Drill Bit, HSS, 0.9mm, 11mm Effective, 32mm Overall
214 009 数据手册
Twist drills Twist drills DIN 338 type N HSS ground, with split point 1.1 Point cut: helical point from Ø 3,0 mm with split point DIN 1412 C Point angle: 118° Helix angle: 20-30° Ø tolerance: h8 Surface: bright Right-hand cutting Highly efficient standard drill suitable for all usual drilling work in all normal materials. High rotational precision. Applications: for steel and cast-steel alloyed and unalloyed up to 900 N/mm² strength, grey cast, malleable cast iron, die-cast metal, iron sinter, nickel-silver, graphite cast iron, shortchipping aluminium alloys, bronze and brass.. Packing unit: Ø 0,30 mm up to 10,40 mm in plastic box of 10 Ø 10,50 mm up to 16,00 mm in plastic box of 5 Ø mm Total length mm Flute length mm Article no. 0,30 0,40 0,50 0,60 0,70 0,80 0,90 1,00 1,10 1,20 1,25 1,30 1,40 1,50 1,60 1,70 1,75 1,80 1,90 2,00 2,10 2,20 2,25 2,30 2,40 2,50 2,60 2,70 2,75 2,80 2,90 3,00 3,10 3,20 3,25 3,30 3,40 3,50 3,60 3,70 3,75 3,80 3,90 4,00 4,10 4,20 4,25 4,30 4,40 4,50 4,60 4,70 19 20 22 24 28 30 32 34 36 38 38 38 40 40 43 43 43 46 46 49 49 53 53 53 57 57 57 61 61 61 61 61 65 65 65 65 70 70 70 70 70 75 75 75 75 75 75 80 80 80 80 80 3 5 6 7 9 10 11 12 14 16 16 16 18 18 20 20 20 22 22 24 24 27 27 27 30 30 30 33 33 33 33 33 36 36 36 36 39 39 39 39 39 43 43 43 43 43 43 47 47 47 47 47 214 003 214 004 214 005 214 006 214 007 214 008 214 009 214 010 214 011 214 012 214 0125 214 013 214 014 214 015 214 016 214 017 214 0175 214 018 214 019 214 020 214 021 214 022 214 0225 214 023 214 024 214 025 214 026 214 027 214 0275 214 028 214 029 214 030 214 031 214 032 214 0325 214 033 214 034 214 035 214 036 214 037 214 0375 214 038 214 039 214 040 214 041 214 042 214 0425 214 043 214 044 214 045 214 046 214 047 Price each € - 18 - Ø mm Total length mm Flute length mm Article no. 4,75 4,80 4,90 5,00 5,10 5,20 5,25 5,30 5,40 5,50 5,60 5,70 5,75 5,80 5,90 6,00 6,10 6,20 6,25 6,30 6,40 6,50 6,60 6,70 6,75 6,80 6,90 7,00 7,10 7,20 7,25 7,30 7,40 7,50 7,60 7,70 7,75 7,80 7,90 8,00 8,10 8,20 8,25 8,30 8,40 8,50 8,60 8,70 8,75 8,80 8,90 9,00 80 86 86 86 86 86 86 86 93 93 93 93 93 93 93 93 101 101 101 101 101 101 101 101 101 109 109 109 109 109 109 109 109 109 117 117 117 117 117 117 117 117 117 117 117 117 125 125 125 125 125 125 47 52 52 52 52 52 52 52 57 57 57 57 57 57 57 57 63 63 63 63 63 63 63 63 63 69 69 69 69 69 69 69 69 69 75 75 75 75 75 75 75 75 75 75 75 75 81 81 81 81 81 81 214 0475 214 048 214 049 214 050 214 051 214 052 214 0525 214 053 214 054 214 055 214 056 214 057 214 0575 214 058 214 059 214 060 214 061 214 062 214 0625 214 063 214 064 214 065 214 066 214 067 214 0675 214 068 214 069 214 070 214 071 214 072 214 0725 214 073 214 074 214 075 214 076 214 077 214 0775 214 078 214 079 214 080 214 081 214 082 214 0825 214 083 214 084 214 085 214 086 214 087 214 0875 214 088 214 089 214 090 Price each € Twist drills Twist drills DIN 338 type N HSS ground, with split point Point cut: helical point from Ø 3,0 mm with split point DIN 1412 C Point angle: 118° Helix angle: 20-30° Ø tolerance: h8 Surface: bright Right-hand cutting Highly efficient standard drill suitable for all usual drilling work in all normal materials. High rotational precision. Applications: for steel and cast-steel alloyed and unalloyed up to 900 N/mm² strength, grey cast, malleable cast iron, die-cast metal, iron sinter, nickel-silver, graphite cast iron, shortchipping aluminium alloys, bronze and brass.. Packing unit: Ø 0,30 mm up to 10,40 mm in plastic box of 10 Ø 10,50 mm up to 16,00 mm in plastic box of 5 Ø mm Total length mm Flute length mm Article no. 9,10 9,20 9,25 9,30 9,40 9,50 9,60 9,70 9,75 9,80 9,90 10,00 10,10 10,20 10,30 10,40 10,50 10,60 10,70 10,80 10,90 11,00 11,10 11,20 125 125 125 125 125 125 133 133 133 133 133 133 133 133 133 133 133 142 142 142 142 142 142 142 81 81 81 81 81 81 87 87 87 87 87 87 87 87 87 87 87 94 94 94 94 94 94 94 214 091 214 092 214 0925 214 093 214 094 214 095 214 096 214 097 214 0975 214 098 214 099 214 100 214 101 214 102 214 103 214 104 214 105 214 106 214 107 214 108 214 109 214 110 214 111 214 112 Price each € - 19 - Ø mm Total length mm Flute length mm Article no. 11,30 11,40 11,50 11,60 11,70 11,80 11,90 12,00 12,10 12,20 12,30 12,40 12,50 12,60 12,70 12,80 12,90 13,00 13,50 14,00 14,50 15,00 15,50 16,00 142 142 142 142 142 142 151 151 151 151 151 151 151 151 151 151 151 151 160 160 169 169 178 178 94 94 94 94 94 94 101 101 101 101 101 101 101 101 101 101 101 101 108 108 114 114 120 120 214 113 214 114 214 115 214 116 214 117 214 118 214 119 214 120 214 121 214 122 214 123 214 124 214 125 214 126 214 127 214 128 214 129 214 130 214 135 214 140 214 145 214 150 214 155 214 160 Price each € 1.1
214 009 价格&库存
很抱歉,暂时无法提供与“214 009”相匹配的价格&库存,您可以联系我们找货
