232-050
232-050
    RUKO
232-050 数据手册
Thread-cutting tools Machine taps M DIN 371 HSS, ground Chamfer: 1.6 Type B, 4 - 5 threads with progressive tap Thread: metric, DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6H Surface: bright Right-hand cutting Machine tap with reinforced shank for through threads in unalloyed or low-alloyed steels up to 800 N/mm² strength, malleable cast iron and non-ferrous metals. The thread is cut in one operation. Packing unit: Individual plastic pack Nominal thread size Pitch mm Thread core hole mm Total length mm Thread length mm Article no. M 2 M 2,5 M 3 M 4 M 5 M 6 M 8 M 10 0,40 0,45 0,50 0,70 0,80 1,00 1,25 1,50 1,60 2,05 2,50 3,30 4,20 5,00 6,80 8,50 45,0 50,0 56,0 63,0 70,0 80,0 90,0 100,0 8,0 9,0 10,0 12,0 13,0 13,0 18,0 20,0 232 020 232 025 232 030 232 040 232 050 232 060 232 080 232 100 Price each € Machine taps M DIN 376 HSS, ground Chamfer: Type B, 4 - 5 threads with progressive tap Thread: metric, DIN ISO 13 Flanks: relief-ground Tolerance: ISO 2 / 6H Surface: bright Right-hand cutting Machine tap with overflow shank for through threads in unalloyed or low-alloyed steels up to 800 N/mm² strength, malleable cast iron and non-ferrous metals. The thread is cut in one operation. Packing unit: Individual plastic pack Nominal thread size Pitch mm Thread core hole mm Total length mm Thread length mm Article no. M 12 M 14 M 16 M 18 M 20 M 22 M 24 M 27 M 30 1,75 2,00 2,00 2,50 2,50 2,50 3,00 3,00 3,50 10,20 12,00 14,00 15,50 17,50 19,50 21,00 24,00 26,50 110,0 110,0 110,0 125,0 140,0 140,0 160,0 160,0 180,0 22,0 25,0 28,0 30,0 30,0 30,0 32,0 38,0 45,0 232 120 232 140 232 160 232 180 232 200 232 220 232 240 232 270 232 300 - 96 - Price each €
232-050 价格&库存
很抱歉,暂时无法提供与“232-050”相匹配的价格&库存,您可以联系我们找货
