101146843
101146843
    SCHMERSAL
    SCHMERSAL - 101146843 - Safety Interlock Switch, AZM 170I Series, SPST-NO, SPST-NC, M12 Connector, 2...
101146843 数据手册
DATASHEET AZM 170-11ZRIA-ST-B6R 24VAC/DC Connector M12, 4-pole A- and B-coding of the connectors Double-insulated Individual coding Coding level "High" according to ISO 14119 90 mm x 84 mm x 30 mm Compact design Interlock with protection against incorrect locking. Long life High holding force right-hand model For very smal actuating radii in line with or at 90° to the plane of the actuator Schmersal Ltd., Sparrowhawk Close, WR14 1GL Malvern The details and data referred to have been carefully checked. Images may diverge from original. Further technical data can be found in the manual. Technical amendments and errors possible. Generated on: 28/05/2024, 15:12
101146843 价格&库存
很抱歉,暂时无法提供与“101146843”相匹配的价格&库存,您可以联系我们找货
