AES1135 (24VDC)
AES1135 (24VDC)
    SCHMERSAL
    SCHMERSAL - AES1135 (24VDC) - Safety Relay, 24 VDC, AES, DIN Rail, 2 A, Screw
AES1135 (24VDC) 数据手册
Print - Create PDF - 20.04.2011 17:44:58h Create EXCEL file Datasheet - AES 1135 Guard door monitors and Safety control modules for Emergency Stop applications / Monitoring of electromechanical and non-contact switchgear / AES 113x • Monitoring of BNS range magnetic safety sensors • 1 safety contact, STOP 0 • 2 Signalling outputs (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AES 1135 Article number 1170036 EAN code 4030661296920 Approval Approval BG USA/CAN Classification Standards EN ISO 13849-1, IEC 61508 PL up d Control category up 3 PFH value 1.0 x 10-7/h SIL up 2 Mission time 20 Years Global Properties Product name AES 113x Standards IEC/EN 60204-1, IEC 60947-5-3, EN 954-1, BG-GS-ET-14, BG-GS-ET-20 Compliance with the Directives (Y/N) Yes Climatic stress EN 60068-2-3, BG-GS-ET-14 Mounting snaps onto standard DIN rail to EN 60715 Terminal designations IEC/EN 60947-1 Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, ventilated - Material of the contacts Ag-Ni, 0,2 µm gold flashed Weight 155 g Start conditions Automatic Start input (Y/N) No Feedback circuit (Y/N) No Start-up test (Y/N) No Reset after disconnection of supply voltage (Y/N) Yes Automatic reset function (Y/N) Yes Reset with edge detection (Y/N) No Pull-in delay - ON delay with automatic start adjustable 0,1 / 1.0 s Drop-out delay - Drop-out delay in case of emergency stop < 50 ms Mechanical data Connection type Screw connection Cable section - Min. Cable section 0,25 mm² - Max. Cable section 2.5 mm² Pre-wired cable rigid or flexible Tightening torque for the terminals 0,6 Nm Detachable terminals (Y/N) No Mechanical life 20.000.000 operations Electrical lifetime 150.000 operations for 230 VAC, 5 A (cos φ = 1) restistance to shock 30 g / 11 ms Resistance to vibration To EN 60068-2-6 10...55 Hz, Amplitude 0,35 mm, ± 15 % Ambient conditions Ambient temperature - Min. environmental temperature 0°C - Max. environmental temperature + 55°C Storage and transport temperature - Min. Storage and transport temperature - 25°C - Max. Storage and transport temperature + 70°C Protection class - Protection class-Enclosure IP40 - Protection class-Terminals IP20 - Protection class-Clearance IP54 Air clearances and creepage distances To IEC/EN 60664-1 - Rated impulse withstand voltage Uimp 4.8 kV - Overvoltage category III To VDE 0110 - Degree of pollution 2 To VDE 0110 Electromagnetic compatibility (EMC) EMC rating 10 V/m Electrical data Rated DC voltage for controls - Min. rated DC voltage for controls 20.4 V - Max. rated DC voltage for controls 27.6 V Rated AC voltage for controls, 50 Hz - Min. rated AC voltage for controls, 50 Hz - - Max. rated AC voltage for controls, 50 Hz - Rated AC voltage for controls, 60 Hz - Min. rated AC voltage for controls, 60 Hz - - Max. rated AC voltage for controls, 60 Hz - Contact resistance max. 100 mΩ Power consumption 0 piece Number of openers adjustable 1 piece -> 2 piece Input resistance approx. 4000 Ω at GND Input signal "1" 10 ... 30 VDC Input signal "0" 0 ... 2 VDC Cable length 1000 m with 0,75 mm² (for Rated voltage) Outputs Stop category 0 Number of safety contacts 1 piece Number of auxiliary contacts 0 piece Number of signalling outputs 2 piece Switching capacity - Switching capacity of the safety contacts min. 10 mA, max. 6 A - Switching capacity of the signaling/diagnostic outputs Y1-Y2 = 100 mA Fuse rating - Protection of the safety contacts 6 A gG D-fuse - Fuse rating for the signaling/diagnostic outputs short-circuit proof Signalling output Y1: Authorized operation, safety contacts on; Y2: No authorised operation, safety contacts off Utilisation category To EN 60947-5-1 AC-15: 230 V / 3 A DC-13: 24 V / 2 A Number of undelayed semi-conductor outputs with signaling function Number of undelayed outputs with signaling function (with 2 piece contact) 0 piece Number of delayed semi-conductor outputs with signaling function. 0 piece Number of delayed outputs with signalling function (with contact). 0 piece Number of secure undelayed semi-conductor outputs with signaling function 0 piece Number of secure, undelayed outputs with signaling function, with contact. 0 piece Number of secure, delayed semi-conductor outputs with signaling function 0 piece Number of secure, delayed outputs with signaling function (with contact). 0 piece LED switching conditions display LED switching conditions display (Y/N) Yes Number of LED´s 1 piece Integral system diagnosis ISD Integral system diagnosis ISD - The following faults are registered by the safety monitoring modules and indicated by ISD - Failure of door contacts to open or close - Cross-wire or short-circuit monitoring of the switch connections - Interruption of the switch connections - Failure of the safety relay to pull-in or drop-out - Fault on the input circuits or the relay control circuits of the safety monitoring module Miscellaneous data Applications Safety sensor Guard system Dimensions Dimensions - Width 22.5 mm - Height 100 mm - Depth 121 mm notice Inductive loads (e.g. contactors, relays, etc.) are to be suppressed by means of a suitable circuit. notice - Wiring example To secure a guard door up to PL 3 and Category #03# Monitoring 1 guard door(s), each with a magnetic safety sensor of the BNS range If one or two external relays or contactors are used to switch the load, the system can then only be classified in Category 3 to EN 954-1, if exclusion of the fault “Failure of the external contactors” can be substantiated and is documented, e.g. by using reliable down-rated contactors. A second contactor leads to an increase in the level of security by redundant switching to switch the load off. Modification for 2 NC contacts: The safety monitoring module can be modified to monitor two NC contacts by bridging the terminals A1 and X1. The short-circuit recognition between connections then becomes inoperative. Expansion of enable delay time: The enable delay time can be increased from 0,1 s to 1,0 s by changing the position of a jumper link connection under the cover of the unit. The wiring diagram is shown with guard doors closed and in de-energised condition. The ISD tables (Intergral System Diagnostics) for analysis of the fault indications and their causes are shown in the appendix. Documents Operating instructions and Declaration of conformity (de) 824 kB, 30.11.2010 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/DE/mrl_aes1135_1136_de.pdf Operating instructions and Declaration of conformity (fr) 673 kB, 02.12.2009 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/FR/mrl_aes1135_1136_fr.pdf Operating instructions and Declaration of conformity (it) 660 kB, 02.12.2009 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/IT/mrl_aes1135_1136_it.pdf Operating instructions and Declaration of conformity (es) 659 kB, 02.12.2009 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/ES/mrl_aes1135_1136_es.pdf Operating instructions and Declaration of conformity (de) 666 kB, 02.12.2009 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/DE/mrl_aes1135_1136_de.pdf Operating instructions and Declaration of conformity (nl) 658 kB, 02.12.2009 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/NL/mrl_aes1135_1136_nl.pdf Operating instructions and Declaration of conformity (jp) 1 MB, 30.11.2010 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/JP/mrl_aes1135_1136_jp.pdf Operating instructions and Declaration of conformity (en) 747 kB, 02.12.2009 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/bedien/EN/mrl_aes1135_1136_en.pdf Wiring example (99) 17 kB, 22.08.2008 http://127.0.0.1/Bilddata/Si_baust/Aes1135/Schaltun/Maes1l01.pdf Wiring example (99) 18 kB, 22.08.2008 http://127.0.0.1/Bilddata/Si_baust/Aes1135/Schaltun/Maes1l02.pdf ISD tables (Intergral System Diagnostics) (en) 35 kB, 29.07.2008 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/ISD/i_ae2p02.pdf ISD tables (Intergral System Diagnostics) (de) 51 kB, 29.07.2008 http://127.0.0.1/Bilddata/Si_baust/Pdf/Aes1135/ISD/i_ae2p01.pdf Images Dimensional drawing (basic component) Wiring example Wiring example K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 20.04.2011 - 17:44:59h Kasbase 1.4.7 DBI
AES1135 (24VDC) 价格&库存
很抱歉,暂时无法提供与“AES1135 (24VDC)”相匹配的价格&库存,您可以联系我们找货
