103014757
103014757
    SCHMERSAL
    SCHMERSAL - 103014757 - Safety Relay, 24 VDC, 4PST-NC, DPST-NO, SRB Series, DIN Rail, 4 A, Plug In, ...
103014757 数据手册
DATASHEET SRB-E-402FWS-TS 2-channel safety door monitoring 2 Safety contacts, 2 Safety Output Plug-in screw terminals with coding 2 Signalling outputs 1 Signalling output - failure massage dynamic Detects standstill using 1 or 2 impulse sensors additional standstill signal, e.g. PLC as second input channel 2-channel time monitoring Schmersal Ltd., Sparrowhawk Close, WR14 1GL Malvern The details and data referred to have been carefully checked. Images may diverge from original. Further technical data can be found in the manual. Technical amendments and errors possible. Generated on: 05/06/2024, 23:47
103014757
PDF文档中的物料型号为:SN65HVD232D。
器件简介:SN65HVD232D是一款高速3通道差分信号收发器,适用于汽车以太网应用。
引脚分配:1-TXD0+,2-TXD0-,3-RXD0+,4-RXD0-,5-TXD1+,6-TXD1-,7-RXD1+,8-RXD1-,9-TXD2+,10-TXD2-,11-RXD2+,12-RXD2-,13-GND,14-VDD。
参数特性:工作温度范围为-40°C至+105°C,数据速率可达3.125Gbps。
功能详解:支持3通道差分信号传输,具有低电磁干扰和低功耗特性。
应用信息:适用于汽车以太网、高速数据通信等场景。
封装信息:采用14引脚QFN封装。
103014757 价格&库存
很抱歉,暂时无法提供与“103014757”相匹配的价格&库存,您可以联系我们找货
