Print -
Create PDF -
Create EXCEL file - Hide system components
Datasheet - BNS 33-02Z-2187
Safety sensors / BNS 33
(Minor differences between the printed image and the original product
may exist!)
• thermoplastic enclosure
• Concealed mounting possible
• Insensitive to transverse misalignment
• 88 mm x 25 mm x 13 mm
• Long life
• no mechanical wear
• Insensitive to soiling
• AS-Interface Safety at Work available
• Individual contact outlet
Ordering details
Product type description
BNS 33-02Z-2187
Article number
1128792
EAN code
4030661049595
Approval
Approval
BG
USA/CAN
Classification
Standards
EN ISO 13849-1
B10d Opener (NC)
25.000.000
- notice
Mission time
at max. 20% contact load
20 Years
notice
Global Properties
Product name
BNS 33
Standards
IEC 60947-5-3, BG-GS-ET-14
Compliance with the Directives (Y/N)
Yes
Materials
- Material of the housings
Plastic, glass-fibre reinforced thermoplastic
- Material of the cable mantle
PVC
Weight
70 g
Monitoring function of downstream devices (Y/N)
No
Prerequisite evaluation unit
Yes
Recommended safety-monitoring module
Recommended actuator
BPS 33, BPS 33-2326
21.04.2011
15:58:16h
Mechanical data
Design of electrical connection
Cable
Cable length
1m
Conductors
0,25 mm²
AWG-Number
23
mechanical installation conditions
not flush
Active area
Side
Ensured switch distance ON
5 mm / 8 mm
- BPS 33-2326 = 8 mm Actuating magnet
- BPS 33 = 5 mm Actuating magnet
Ensured switch distance OFF
15 mm / 18 mm
- BPS 33 = 15 mm Actuating magnet
- BPS 33-2326 = 18 mm Actuating magnet
Repeat accuracy R
≤ 0,1 x
Type of actuation
Magnet
Direction of motion
head-on with regard to the active surface
restistance to shock
30 g / 11 ms
Resistance to vibration
10 ... 55 Hz, Amplitude 1 mm
Ambient conditions
Ambient temperature
- Min. environmental temperature
−25 °C
- Max. environmental temperature
+70 °C
Storage and transport temperature
- Min. Storage and transport temperature
−25 °C
- Max. Storage and transport temperature
+70 °C
Protection class
IP67
Electrical data
Integrated Safety monitoring module available (Y/N)
No
Cross circuit/short circuit recognition possible (Y/N)
Yes
Voltage type
VAC/DC
Switch frequency
max. 5 Hz
Switching voltage
max. 100 VAC/DC
Switching current
max. 250 mA
Switching capacity
max. 3 W
Outputs
Design of control output
Other, Reed contakts
Number of shutters
0 piece
Number of openers
2 piece
Electrical data - Safety outputs
Number of secure semi-conductor outputs
0 piece
Number of secure outputs with contact
0 piece
Electrical data - Diagnostic output
Number of semi-conductor outputs with signaling function
0 piece
Number of outputs with signaling function that already have a
contact
0 piece
LED switching conditions display
LED switching conditions display (Y/N)
No
ATEX
Explosion protection categories for gases
None
Explosion protected category for dusts
None
Dimensions
Dimensions of the sensor
- Width of sensor
88 mm
- Height of sensor
25 mm
- Length of sensor
13 mm
notice
Contact symbols shown for the closed condition of the guard device.
The contact configuration for versions with or without LED is identical.
Included in delivery
Actuators must be ordered separately.
Diagram
Note Diagram
positive break NC contact
active
no active
Normally-open contact
Normally-closed contact
Ordering code
BNS 33-(1)Z(2)-(3)-(4)
(1)
02
2 Opener (NC)
11
1 Normally open contact (NO) / 1 Opener (NC)
12
1 Normally open contact (NO) / 2 Opener (NC)
(2)
without without LED switching conditions display
G
(3)
with LED switching conditions display
without with cable
ST
with connector M8
(4)
2187
2187-10 Individual contact outlet, with LED
2237
Actuation from cable direction
Documents
Operating instructions and Declaration of conformity (fr) 418 kB, 05.11.2009
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/fr/mrl_bns33-2187-2363_fr.pdf
Operating instructions and Declaration of conformity (jp) 1 MB, 23.11.2010
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/jp/mrl_bns33-2187-2363_jp.pdf
Operating instructions and Declaration of conformity (nl) 424 kB, 05.11.2009
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/nl/mrl_bns33-2187-2363_nl.pdf
Operating instructions and Declaration of conformity (en) 698 kB, 21.01.2010
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/en/mrl_bns33-2187-2363_en.pdf
Operating instructions and Declaration of conformity (de) 617 kB, 21.01.2010
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/de/mrl_bns33-2187-2363_de.pdf
Operating instructions and Declaration of conformity (es) 417 kB, 11.11.2009
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/es/mrl_bns33-2187-2363_es.pdf
Operating instructions and Declaration of conformity (it) 791 kB, 16.11.2009
http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/it/mrl_bns33-2187-2363_it.pdf
Images
Dimensional drawing (basic component)
Characteristic curve
System components
Actuator
1107771 - BPS 33
1148482 - BPS 33-2326
• higher switching distance Sao 8 mm
Accessories
1158893 - SPACER BN 31/33
• to mount the magnetic safety sensor and actuator on ferromagnetic material
K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal
The data and values have been checked throroughly. Technical modifications and errors excepted.
Generiert am 21.04.2011 - 15:58:17h Kasbase 1.4.7 DBI
很抱歉,暂时无法提供与“BNS33-11Z-ST”相匹配的价格&库存,您可以联系我们找货
