AZM170-02ZRK-24VAC/DC 数据手册
Print -
Create PDF -
Create EXCEL file - Hide system components
Datasheet - AZM 170-02ZRK 24 VAC/DC
Solenoid interlock / AZM 170
• thermoplastic enclosure
• Double-insulated
• Compact design
• 90 mm x 84 mm x 30 mm
• 1 Cable entry M 20 x 1.5
• Interlock with protection against incorrect locking.
• Long life
• High holding force
• IDC method of termination
• Manual release
(Minor differences between the printed image and the original product may
exist!)
Ordering details
Product type description
Article number
1140795
EAN code
4030661119830
Approval
Approval
BG
USA/CAN
CCC
Classification
Standards
EN ISO 13849-1
B10d Opener (NC)
2.000.000
Mission time
20 Years
notice
Global Properties
Product name
AZM 170
21.04.2011
10:13:56h
Standards
EN 60947-5-1, BG-GS-ET-19
Compliance with the Directives (Y/N)
Yes
Number of actuating directions
2 piece
Active principle
electromechanical
Duty cycle
Magnet 100 %
Materials
- Material of the housings
Plastic, glass-fibre reinforced thermoplastic, self-extinguishing
- Material of the contacts
Silver
Housing coating
None
Weight
288 g
Mechanical data
Design of electrical connection
Cable section
- Min. Cable section
1 x 0,75 mm²
- Max. Cable section
1 x 1.0 mm², flexible
Mechanical life
> 1.000.000 operations
Emergency unlocking device (Y/N)
No
Manual release (Y/N)
Yes
- bottom
Emergency release (Y/N)
No
Latching force
30 N
Positive break force
17 N
positive break travel
11 mm
Clamping force Fmax
1000 N
Max. Actuating speed
2 m/s
Ambient conditions
Ambient temperature
- Min. environmental temperature
- 25°C
- Max. environmental temperature
+ 60°C
Protection class
IP67 to IEC/EN 60529
Electrical data
Design of control element
Opener (NC)
Switching principle
Creep circuit element
Number of auxiliary contacts
0 piece
Number of safety contacts
2 piece
Power to unlock
Yes
Power to lock
No
Rated control voltage Us
24 VAC/DC
Power consumption
max. 10 W
Rated impulse withstand voltage Uimp
4 kV
Rated insulation voltage Ui
250 V
Thermal test current Ithe
10 A
Utilisation category
AC-15: 230 V / 4 A, DC-13: 24 V / 4 A
Max. fuse rating
6 A gG D-fuse
ATEX
Explosion protection categories for gases
None
Explosion protected category for dusts
None
Miscellaneous data
Applications
sliding safety guard,
removable guard,
hinged safety guard
Dimensions
Dimensions of the sensor
- Width of sensor
90 mm
- Height of sensor
84 mm
- Length of sensor
30 mm
notice
This type termination (IDC) method enables simple connetion of flexible conductors without the need for the use of conductor ferrules
Individual coding available on request
Manual release
• For manual release using M5 triangular key, available as accessory
Diagram
Note Diagram
positive break NC contact
active
no active
Normally-open contact
Normally-closed contact
Switch travel diagram
Notes Switch travel diagram
Contact closed
Contact open
Setting range
Break point
Positive opening sequence/- angle
VS adjustable range of NO contact
VÖ adjustable range of NC contact
N after travel
Ordering suffix
The applicable ordering suffix is added at the end of the part number of the safety switch.
Order example: AZM 170-02ZRK 24 VAC/DC-1637
...-1637
0,3 µm gold-plated contacts
...ST-2431
connector M12 , Individual solenoid monitoring
Ordering code
AZM 170(1)-(2)Z(3)K(4)-(5)-(6)-(7)
(1)
without
SK
Screw connection
(2)
11
1 Normally open contact (NO) / 1 Opener (NC)
02
2 Opener (NC)
12/0.0
1 Normally open contact (NO), 2 Opener (NC) / -
(3)
without
Latching force 5 N
R
Latching force 30 N
I
Individual coding
(4)
without
Power to unlock
A
Power to lock
(5)
without
cable gland
ST
Connector M12 x 1
ST-2431
Connector M12 x 1, Individual solenoid monitoring
(6)
24VAC/DC Us 24 VAC/DC
110VAC
Us 110 VAC
230VAC
Us 230 VAC
(7)
without
Manual release
2197
Manual release from side (Power to unlock)
1637
AZM 170ST and AZM 170SK
AZM 170ST-(1)Z(2)K(3)-(4)-(5)-024
AZM 170SK-(1)Z(2)K(3)-(4)-(5)-024
(1)
11/11
1 Normally open contact (NO), 1 Opener (NC) / 1 Normally open contact (NO), 1 Opener (NC)
11/02
1 Normally open contact (NO), 1 Opener (NC) / 2 Opener (NC)
12/00
12/11
1 Normally open contact (NO), 2 Opener (NC) / 1 Normally open contact (NO), 1 Opener (NC)
12/02
1 Normally open contact (NO), 2 Opener (NC) / 2 Opener (NC)
02/01
2 Opener (NC), - / 1 Opener (NC), -
02/10
2 Opener (NC), - / 1 Normally open contact (NO), -
(2)
without
Latching force 5 N
R
Latching force 30 N
(3)
without
Power to unlock
A
Power to lock
(4)
1637
(5)
2197
Manual release for Power to unlock
Documents
Operating instructions and Declaration of conformity (jp) 709 kB, 14.04.2011
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/jp/mrl_azm170_jp.pdf
Operating instructions and Declaration of conformity (es) 665 kB, 25.03.2010
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/es/mrl_azm170_es.pdf
Operating instructions and Declaration of conformity (en) 746 kB, 12.03.2010
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/en/mrl_azm170_en.pdf
Operating instructions and Declaration of conformity (fr) 670 kB, 01.07.2010
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/fr/mrl_azm170_fr.pdf
Operating instructions and Declaration of conformity (nl) 720 kB, 23.09.2010
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/nl/mrl_azm170_nl.pdf
Operating instructions and Declaration of conformity (de) 573 kB, 18.02.2011
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/de/mrl_azm170_de.pdf
Operating instructions and Declaration of conformity (it) 645 kB, 09.04.2010
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/it/mrl_azm170_it.pdf
BG-test certificate (en) 574 kB, 05.01.2011
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/baumuste/z_m17p02.pdf
BG-test certificate (de) 589 kB, 05.01.2011
http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/baumuste/z_m17p01.pdf
CCC certification (en) 747 kB, 12.12.2006
http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/zertifikat/q_371p02.pdf
CCC certification (cn) 725 kB, 12.12.2006
http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/zertifikat/q_371p03.pdf
Images
Dimensional drawing (basic component)
Assembly example
Detail photo
System components
Actuator
1122893 - AZ 17/170-B1
• Particularly suitable for sliding doors
1137406 - AZ 17/170-B1-2245
• Damps vibration on guard device
1122895 - AZ 17/170-B5
• Particularly suitable for hinged guards (front mounting)
1139788 - AZ 17/170-B11
1139789 - AZ 17/170-B15
1123391 - AZM 170-B6
• For very smal actuating radii
• The direction of actuation can be selected by applicable insertion of the
insert
Accessories
1208493 - AZM 170-B CENTERING GUIDE
• for AZ 17 and AZM 170
1100887 - TRIANGULAR KEY M5
• For maintenance, installation, etc.
K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal
The data and values have been checked throroughly. Technical modifications and errors excepted.
Generiert am 21.04.2011 - 10:13:56h Kasbase 1.4.7 DBI
AZM170-02ZRK-24VAC/DC 价格&库存
很抱歉,暂时无法提供与“AZM170-02ZRK-24VAC/DC”相匹配的价格&库存,您可以联系我们找货
