AZM170-B6
AZM170-B6
    SCHMERSAL
AZM170-B6 数据手册
Print - Create PDF - 21.04.2011 10:47:36h Create EXCEL file Datasheet - AZM 170-B6 Solenoid interlock / AZM 170 / Actuator AZM 170 • For very smal actuating radii • The direction of actuation can be selected by applicable insertion of the insert (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZM 170-B6 Article number 1123391 EAN code 4030661104416 Global Properties Product name Beweglicher Betätiger B6 Weight 25 g Mechanical data Design of actuators flexible Minimum actuating radius 50 mm notice Actuating radius adjustable, minimum 50 mm, using an hexagonal key wrench 2 mm A/F (a and b) The axis of the hinge should be 11 mm above the top edge of the safety switch and in the same plane Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 178 kB, 20.06.2005 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/montage/M_z17p02.pdf Images Dimensional drawing (miscellaneous) K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 10:47:36h Kasbase 1.4.7 DBI
AZM170-B6 价格&库存
很抱歉,暂时无法提供与“AZM170-B6”相匹配的价格&库存,您可以联系我们找货
