21.08.2012
08:43:46h
Datasheet - BNS 250-11ZG
Safety sensors / BNS 250
Preferred typ
• LED version
• thermoplastic enclosure
• Small body
• Concealed mounting possible
• 33 mm x 25 mm x 13 mm
• Long life
• no mechanical wear
• Insensitive to transverse misalignment
• Insensitive to soiling
(Minor differences between the printed image and the original product may
exist!)
Ordering details
Product type description
BNS 250-11ZG
Article number
101120671
EAN code
4030661049250
Approval
Approval
BG
USA/CAN
Classification
Standards
EN ISO 13849-1
B10d Opener/Normally open contact (NC/NO)
25.000.000
- notice
Mission time
at max. 20% contact load
20 Years
notice
Global Properties
Product name
BNS 250
Standards
IEC 60947-5-3, BG-GS-ET-14
Compliance with the Directives (Y/N)
Yes
Materials
- Material of the housings
Plastic, glass-fibre reinforced thermoplastic
- Material of the cable mantle
PVC
Weight
50 g
Coding available (Y/N)
Yes
Monitoring function of downstream devices (Y/N)
No
Prerequisite evaluation unit
Yes
Recommended safety-monitoring module
Recommended actuator
BPS 250
Mechanical data
Design of electrical connection
Cable
Cable length
1m
Conductors
0,25 mm²
AWG-Number
23
mechanical installation conditions
not flush
Active area
front side
Ensured switch distance ON
4 mm
Ensured switch distance OFF
14 mm
Type of actuation
Magnet
Direction of motion
head-on with regard to the active surface
restistance to shock
30 g / 11 ms
Resistance to vibration
10 ... 55 Hz, Amplitude 1 mm
Ambient conditions
Ambient temperature
- Min. environmental temperature
−25 °C
- Max. environmental temperature
+70 °C
Storage and transport temperature
- Min. Storage and transport temperature
−25 °C
- Max. Storage and transport temperature
+70 °C
Protection class
IP67
Electrical data
Integrated Safety monitoring module available (Y/N)
No
Cross circuit/short circuit recognition possible (Y/N)
Yes
Voltage type
VDC
Switch frequency
max. 5 Hz
Switching voltage
max. 24 VDC
Switching current
max. 100 mA
Switching capacity
max. 1 W
Outputs
Design of control output
Other, Reed contakts
Number of shutters
1 piece
Number of openers
1 piece
Electrical data - Safety outputs
Number of secure semi-conductor outputs
0 piece
Number of secure outputs with contact
0 piece
Electrical data - Diagnostic output
Number of semi-conductor outputs with signaling function
0 piece
Number of outputs with signaling function that already have a contact
0 piece
LED switching conditions display
LED switching conditions display (Y/N)
Yes
- The LED is illuminated when the guard door is open.
ATEX
Explosion protection categories for gases
None
Explosion protected category for dusts
None
Dimensions
Dimensions of the sensor
- Width of sensor
33 mm
- Height of sensor
25 mm
- Length of sensor
13 mm
notice
Contact symbols shown for the closed condition of the guard device.
The contact configuration for versions with or without LED is identical.
Included in delivery
Actuators must be ordered separately.
Diagram
Note Diagram
positive break NC contact
active
no active
Normally-open contact
Normally-closed contact
Ordering code
BNS 250-(1)Z(2)-(3)
(1)
11
1 Normally open contact (NO) / 1 Opener (NC)
12
1 Normally open contact (NO) / 2 Opener (NC)
(2)
without
without LED switching conditions display
G
with LED switching conditions display
(3)
2187
Individual contact outlet (without LED switching conditions display)
Documents
Operating instructions and Declaration of conformity (de) 1 MB, 21.01.2010
Code: mrl_bns250_de
Operating instructions and Declaration of conformity (en) 1 MB, 21.01.2010
Code: mrl_bns250_en
Operating instructions and Declaration of conformity (es) 769 kB, 13.01.2010
Code: mrl_bns250_es
Operating instructions and Declaration of conformity (fr) 769 kB, 13.01.2010
Code: mrl_bns250_fr
Operating instructions and Declaration of conformity (it) 767 kB, 13.01.2010
Code: mrl_bns250_it
Operating instructions and Declaration of conformity (jp) 1 MB, 23.11.2010
Code: mrl_bns250_jp
Operating instructions and Declaration of conformity (nl) 772 kB, 25.01.2010
Code: mrl_bns250_nl
Operating instructions and Declaration of conformity (pt) 310 kB, 05.07.2012
Code: mrl_bns250_pt
Operating instructions and Declaration of conformity (pl) 288 kB, 02.04.2012
Code: mrl_bns250_pl
Images
Dimensional drawing (basic component)
Characteristic curve
System components
Actuator
101120594 - BPS 250
Accessories
101131223 - SPACER BNS 250
• to mount the magnetic safety sensor and actuator on ferromagnetic
material
• Suitable for food processing industry
K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal
The data and values have been checked throroughly. Technical modifications and errors excepted.
Generiert am 21.08.2012 - 08:43:47h Kasbase 2.2.2.F DBI
Image: nscnt.php?et=sS9Tsg
Image: cnt.php?
et=sS9Tsg&v=3.0&java=n&et_easy=0
&et_pagename=
&et_areas=&et_ilevel=0&et_target=,0,0,0
&et_lpage=0&et_trig=0&et_se=0&et_cust=0
&et_basket=&et_url=&et_tag=&et_sub=
&et_organisation=&et_demographic=
