AZ16-12ZVRK-M20
AZ16-12ZVRK-M20
    SCHMERSAL
AZ16-12ZVRK-M20 数据手册
Print - Create PDF - 26.04.2011 18:18:20h Create EXCEL file - Hide system components Datasheet - AZ 16-12ZVRK Image: [LOGO] Safety switch with separate actuator / AZ 16 • thermoplastic enclosure • Double-insulated • Large wiring compartment • 52 mm x 90 mm x 30 mm • Multiple coding • Long life • High level of contact reliability with low voltages and currents • Slotted holes for adjustment, circular holes for location • 3 cable entries M 16 x 1.5 (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 16-12ZVRK Article number 1154221 EAN code 4030661171586 Approval Approval BG USA/CAN CCC Classification Standards EN ISO 13849-1 B10d Opener (NC) 2.000.000 B10d Normally open contact (NO) 1.000.000 - notice Mission time at 10% Ie and ohmic load 20 Years notice Global Properties Product name AZ 16 Standards EN 60947-5-1, BG-GS-ET-15 Compliance with the Directives (Y/N) Yes Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, self-extinguishing - Material of the contacts Silver Housing coating None Weight 120 g Mechanical data Design of electrical connection Screw connection Cable section - Min. Cable section 0,75 mm² - Max. Cable section 2.5 mm² Mechanical life 20.000.000 operations higher Latching force (Y/N) Yes Latching force 30 N With ejection force (Y/N) No Positive break force 20 N positive break travel 8 mm Max. Actuating speed 0,2 m/s notice All indications about the cable section are including the conductor ferrules. Ambient conditions Ambient temperature - Min. environmental temperature −30 °C - Max. environmental temperature +80 °C Protection class IP67 to IEC/EN 60529 Electrical data Design of control element Normally open contact (NO), Opener (NC) Switching principle Creep circuit element Number of auxiliary contacts 1 piece Number of safety contacts 2 piece Rated impulse withstand voltage Uimp 6 kV Rated insulation voltage Ui 500 V Thermal test current Ithe 10 A Utilisation category AC-15: 230 V / 4 A, DC-13: 24 V / 4 A Max. fuse rating 6 A gG D-fuse ATEX Explosion protection categories for gases None Explosion protected category for dusts None Dimensions Dimensions of the sensor - Width of sensor 52 mm - Height of sensor 90 mm - Length of sensor 30 mm Included in delivery Actuators must be ordered separately. Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Switch travel diagram Notes Switch travel diagram Contact closed Contact open Setting range Break point Positive opening sequence/- angle VS adjustable range of NO contact VÖ adjustable range of NC contact N after travel Ordering suffix The applicable ordering suffix is added at the end of the part number of the safety switch. Order example: AZ 16-12ZVRK-2254 ...-2254 Latching force 5 N ...- 1762 Versions with M5 nuts For front mounting of safety switch, e.g. on sheet-steel covers Cannot be retrofitted ...-1637 0,3 µm gold-plated contacts ...- M20 cable entries M20 Ordering code AZ 16-(1)ZV(2)K-(3)-(4)-(5) (1) without 1 Normally open contact (NO) / 1 Opener (NC) 02 2 Opener (NC) 03 3 Opener (NC) 12 Normally open contact (NO) 1 / Opener (NC) 2 (2) without Ejection force R Latching force 30 N (3) G24 with LED (only available for version with one NO and one NC contact.) (4) without Cable entry M16 M20 Cable entry M20 ST Connector M12, 4-pole, bottom STL Connector M12, 4-pole, left STR Connector M12, 4-pole, right (5) 2254 Latching force 5 N 1762 Front mounting 1637 gold-plated contacts Documents Operating instructions and Declaration of conformity (de) 396 kB, 18.02.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/DE/mrl_az15-16_de.pdf Operating instructions and Declaration of conformity (en) 516 kB, 26.05.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/EN/mrl_az15-16_en.pdf Operating instructions and Declaration of conformity (fr) 442 kB, 01.07.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/FR/mrl_az15-16_fr.pdf Operating instructions and Declaration of conformity (pt) 436 kB, 24.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/pt/mrl_az15-16_pt.pdf Operating instructions and Declaration of conformity (es) 405 kB, 25.03.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/ES/mrl_az15-16_es.pdf Operating instructions and Declaration of conformity (br) 436 kB, 26.05.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/AZ 15 16 ACE/br/mrl_az15-16_br.pdf Operating instructions and Declaration of conformity (pt) 433 kB, 25.05.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/AZ 15 16 ACE/pt/mrl_az15-16_pt.pdf Operating instructions and Declaration of conformity (jp) 479 kB, 15.03.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/JP/mrl_az15-16_jp.pdf Operating instructions and Declaration of conformity (it) 330 kB, 27.11.2009 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/IT/mrl_az15-16_it.pdf Operating instructions and Declaration of conformity (nl) 431 kB, 14.09.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/NL/mrl_az15-16_nl.pdf BG-test certificate (en) 197 kB, 01.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/baumuste/z_z15p02.pdf BG-test certificate (de) 198 kB, 01.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/baumuste/z_z15p01.pdf CCC certification (cn) 730 kB, 12.12.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_175p03.pdf Gost certification (ru) 1 MB, 21.06.2007 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_az1p01.pdf Images Dimensional drawing (basic component) System components Actuator 1083036 - AZ 15/16-B1 1092711 - AZ 15/16-B1-1747 • For play-free interlocking of light guards • Suitable for retrofitting 1093553 - AZ 15/16-B1-1747 • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane • Suitable for retrofitting 1108276 - AZ 15/16-B1-2024 1108278 - AZ 15/16-B1-2024 WITH SLOT SEALING PLUG • For protection against the ingress of course dirt 1111079 - AZ 15/16-B1-2053 • For interlocking of light to medium-weight guards 1111081 - AZ 15/16-B1-2053 WITH BALL LATCH • For interlocking of light to medium-weight guards 1126793 - AZ 15/16-B1-2177 • For interlocking of light, unguided guards 1126794 - AZ 15/16-B1-2177 WITH CENTERING GUIDE • For interlocking of light, unguided guards 1137408 - AZ 15/16-B1-2245 • Damps vibration on guard device 1095558 - AZ 15/16-B2 • For very smal actuating radii in line with the plane of the actuator 1096091 - AZ 15/16-B2-1747 • For very smal actuating radii in line with the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards 1096089 - AZ 15/16-B2-1747 WITH MAGNETIC LATCH • For very smal actuating radii in line with the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane 1095550 - AZ 15/16-B3 • For very smal actuating radii at 90° to the plane of the actuator 1096090 - AZ 15/16-B3-1747 WITH MAGNETIC LATCH • For very smal actuating radii at 90° to the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane 1096092 - AZ 15/16-B3-1747 • For very smal actuating radii at 90° to the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards 1137434 - AZ 15/16-B6 • For very smal actuating radii in line with or at 90° to the plane of the actuator Door-handle system AZ 16-STS30 • Latching handle • Suitable for all types of guard Accessories 1149214 - Mounting set MS AZ 15/16 R/P 1150373 - Mounting set MS AZ 15/16 P 1089116 - Slot sealing plugs AZ 15/16-1476 • For protection against the ingress of course dirt • To cover unused actuator slots • Simple clip-in fitting 1115025 - Ball latch 2053-2 • Additional ball latch for stable latching of light to medium-weight guards • For separate mounting on the guard 1110500 - SZ 16/335 • To prevent inadvertent closing, e.g. during maintenance • For complex plant • Prevents actuation of the switch • Up to 6 padlocks can be fitted • The lockout tag can be mounted on a chain near to the safety switch Mounting accessories 1135338 - TAMPERPROOF SCREWS M 5 x 12 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available 1135339 - TAMPERPROOF SCREWS M 5 x 16 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available 1135340 - TAMPERPROOF SCREWS M 5 x 20 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 26.04.2011 - 18:18:22h Kasbase 1.4.7 DBI
AZ16-12ZVRK-M20 价格&库存
很抱歉,暂时无法提供与“AZ16-12ZVRK-M20”相匹配的价格&库存,您可以联系我们找货
