AZ17/170-B5
AZ17/170-B5
    SCHMERSAL
AZ17/170-B5 数据手册
Print - Create PDF - 21.04.2011 10:45:01h Create EXCEL file Datasheet - AZ 17/170-B5 Safety switch with separate actuator / AZ 17 / Actuator • Particularly suitable for hinged guards (front mounting) (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 17/170-B5 Article number 1122895 EAN code 4030661104409 Global Properties Product name Abgewinkelter Betätiger B5 Weight 20 g Mechanical data Design of actuators angled Minimum actuating radius 140 mm notice On hinged guards, minimum actuating radius at 90° to the plane of the actuator 140 mm minimum actuating radius on hinged guards in line with the plane of the actuator 200 mm The axis of the hinge should be 13 mm above the top edge of the safety switch and in the same plane Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 178 kB, 20.06.2005 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/montage/M_z17p02.pdf Images Dimensional drawing (miscellaneous) K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 10:45:01h Kasbase 1.4.7 DBI
AZ17/170-B5 价格&库存
很抱歉,暂时无法提供与“AZ17/170-B5”相匹配的价格&库存,您可以联系我们找货
