133016950
133016950
    SCHMERSAL
    SCHMERSAL - 133016950 - Safety Interlock Switch, AZM190 Series, DPST-NC, Screw, 230 V, 4 A, IP67
133016950 数据手册
DATASHEET AZM190-02/01RK-48VAC Thermoplastic enclosure Long life Interlock with protection against incorrect locking. 89 mm x 178 mm x 41 mm Actuating head can be repositioned by 4 x 90° 2 cable entries M 20 x 1.5 Wiring compartment Slim design, particularly suitable for fitting on hinged doors, aluminium profiles and fencing Sealing mechanism to prevent the ingress of dirt Cut clamp termination Schmersal Ltd., Sparrowhawk Close, WR14 1GL Malvern The details and data referred to have been carefully checked. Images may diverge from original. Further technical data can be found in the manual. Technical amendments and errors possible. Generated on: 04/06/2024, 01:56
133016950 价格&库存
很抱歉,暂时无法提供与“133016950”相匹配的价格&库存,您可以联系我们找货
