AZ15/16-B6
AZ15/16-B6
    SCHMERSAL
AZ15/16-B6 数据手册
Print - Create PDF - 21.04.2011 13:49:14h Create EXCEL file Datasheet - AZ 15/16-B6 Safety switch with separate actuator / AZ 15 / Actuator • For very smal actuating radii in line with or at 90° to the plane of the actuator (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 15/16-B6 Article number 1137434 EAN code 4030661104706 Global Properties Product name Beweglicher Betätiger AZ 15/16-B6 Weight 20 g Mechanical data Design of actuators angled, flexible Minimum actuating radius 35 mm notice Actuating radius adjustable using an hexagonal key wrench 2,5 mm (a/b) mm A/F (a and b), minimum 35 mm at 90° to the plane of the actuator and minimum 38 mm, in line with the plane of the actuator The axis of the hinge should be 11 mm above the top edge of the safety switch and in the same plane Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 267 kB, 29.08.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/montage/m_z15p02.pdf Images Dimensional drawing (miscellaneous) K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 13:49:14h Kasbase 1.4.7 DBI
AZ15/16-B6 价格&库存
很抱歉,暂时无法提供与“AZ15/16-B6”相匹配的价格&库存,您可以联系我们找货
