AZ16ZVRK-M20
AZ16ZVRK-M20
    SCHMERSAL
AZ16ZVRK-M20 数据手册
Print - Create PDF - Create EXCEL file - Hide system components Datasheet - AZ 16ZVRK Safety switch with separate actuator / AZ 16 • thermoplastic enclosure • Double-insulated • Large wiring compartment • 52 mm x 90 mm x 30 mm • Multiple coding • Long life • High level of contact reliability with low voltages and currents • Slotted holes for adjustment, circular holes for location • 3 cable entries M 16 x 1.5 • LED version available (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 16ZVRK Article number 1152094 EAN code 4030661164700 Approval Approval BG USA/CAN CCC Classification Standards EN ISO 13849-1 B10d Opener (NC) 2.000.000 B10d Normally open contact (NO) 1.000.000 - notice Mission time at 10% Ie and ohmic load 20 Years notice Global Properties Product name AZ 16 Standards EN 60947-5-1, BG-GS-ET-15 21.04.2011 12:09:14h Compliance with the Directives (Y/N) Yes Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, self-extinguishing - Material of the contacts Silver Housing coating None Weight 115 g Mechanical data Design of electrical connection Screw connection Cable section - Min. Cable section 0,75 mm² - Max. Cable section 2.5 mm² Mechanical life 20.000.000 operations higher Latching force (Y/N) Yes Latching force 30 N With ejection force (Y/N) No Positive break force 10 N positive break travel 8 mm Max. Actuating speed 0,2 m/s notice All indications about the cable section are including the conductor ferrules. Ambient conditions Ambient temperature - Min. environmental temperature −30 °C - Max. environmental temperature +80 °C Protection class IP67 to IEC/EN 60529 Electrical data Design of control element Normally open contact (NO), Opener (NC) Switching principle Creep circuit element Number of auxiliary contacts 1 piece Number of safety contacts 1 piece Rated impulse withstand voltage Uimp 6 kV Rated insulation voltage Ui 500 V Thermal test current Ithe 10 A Utilisation category AC-15: 230 V / 4 A, DC-13: 24 V / 4 A Max. fuse rating 6 A gG D-fuse ATEX Explosion protection categories for gases None Explosion protected category for dusts None Dimensions Dimensions of the sensor - Width of sensor 52 mm - Height of sensor 90 mm - Length of sensor 30 mm Included in delivery Actuators must be ordered separately. Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Switch travel diagram Notes Switch travel diagram Contact closed Contact open Setting range Break point Positive opening sequence/- angle VS adjustable range of NO contact VÖ adjustable range of NC contact N after travel Ordering suffix The applicable ordering suffix is added at the end of the part number of the safety switch. Order example: AZ 16ZVRK-2254 ...-2254 Latching force 5 N ...- 1762 Versions with M5 nuts For front mounting of safety switch, e.g. on sheet-steel covers Cannot be retrofitted ...-1637 0,3 µm gold-plated contacts ...- M20 cable entries M20 ...-G24 only available for version with one NO and one NC contact. Protected against incorrect polarity and voltage spikes. Ordering code AZ 16-(1)ZV(2)K-(3)-(4)-(5) (1) without 1 Normally open contact (NO) / 1 Opener (NC) 02 2 Opener (NC) 03 3 Opener (NC) 12 Normally open contact (NO) 1 / Opener (NC) 2 (2) without Ejection force R Latching force 30 N (3) G24 with LED (only available for version with one NO and one NC contact.) (4) without Cable entry M16 M20 Cable entry M20 ST Connector M12, 4-pole, bottom STL Connector M12, 4-pole, left STR Connector M12, 4-pole, right (5) 2254 Latching force 5 N 1762 Front mounting 1637 gold-plated contacts Documents Operating instructions and Declaration of conformity (de) 396 kB, 18.02.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/DE/mrl_az15-16_de.pdf Operating instructions and Declaration of conformity (en) 516 kB, 26.05.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/EN/mrl_az15-16_en.pdf Operating instructions and Declaration of conformity (fr) 442 kB, 01.07.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/FR/mrl_az15-16_fr.pdf Operating instructions and Declaration of conformity (pt) 436 kB, 24.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/pt/mrl_az15-16_pt.pdf Operating instructions and Declaration of conformity (es) 405 kB, 25.03.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/ES/mrl_az15-16_es.pdf Operating instructions and Declaration of conformity (br) 436 kB, 26.05.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/AZ 15 16 ACE/br/mrl_az15-16_br.pdf Operating instructions and Declaration of conformity (pt) 433 kB, 25.05.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/AZ 15 16 ACE/pt/mrl_az15-16_pt.pdf Operating instructions and Declaration of conformity (jp) 479 kB, 15.03.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/JP/mrl_az15-16_jp.pdf Operating instructions and Declaration of conformity (it) 330 kB, 27.11.2009 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/IT/mrl_az15-16_it.pdf Operating instructions and Declaration of conformity (nl) 431 kB, 14.09.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/bedien/NL/mrl_az15-16_nl.pdf BG-test certificate (en) 197 kB, 01.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/baumuste/z_z15p02.pdf BG-test certificate (de) 198 kB, 01.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/baumuste/z_z15p01.pdf CCC certification (cn) 730 kB, 12.12.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_175p03.pdf Gost certification (ru) 1 MB, 21.06.2007 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_az1p01.pdf Images Dimensional drawing (basic component) System components Actuator 1083036 - AZ 15/16-B1 1092711 - AZ 15/16-B1-1747 • For play-free interlocking of light guards • Suitable for retrofitting 1093553 - AZ 15/16-B1-1747 • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane • Suitable for retrofitting 1108276 - AZ 15/16-B1-2024 1108278 - AZ 15/16-B1-2024 WITH SLOT SEALING PLUG • For protection against the ingress of course dirt 1111079 - AZ 15/16-B1-2053 • For interlocking of light to medium-weight guards 1111081 - AZ 15/16-B1-2053 WITH BALL LATCH • For interlocking of light to medium-weight guards 1126793 - AZ 15/16-B1-2177 • For interlocking of light, unguided guards 1126794 - AZ 15/16-B1-2177 WITH CENTERING GUIDE • For interlocking of light, unguided guards 1137408 - AZ 15/16-B1-2245 • Damps vibration on guard device 1095558 - AZ 15/16-B2 • For very smal actuating radii in line with the plane of the actuator 1096091 - AZ 15/16-B2-1747 • For very smal actuating radii in line with the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards 1096089 - AZ 15/16-B2-1747 WITH MAGNETIC LATCH • For very smal actuating radii in line with the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane 1095550 - AZ 15/16-B3 • For very smal actuating radii at 90° to the plane of the actuator 1096090 - AZ 15/16-B3-1747 WITH MAGNETIC LATCH • For very smal actuating radii at 90° to the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane 1096092 - AZ 15/16-B3-1747 • For very smal actuating radii at 90° to the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards 1137434 - AZ 15/16-B6 • For very smal actuating radii in line with or at 90° to the plane of the actuator Door-handle system AZ 16-STS30 • Latching handle • Suitable for all types of guard Accessories 1149214 - Mounting set MS AZ 15/16 R/P 1150373 - Mounting set MS AZ 15/16 P 1089116 - Slot sealing plugs AZ 15/16-1476 • For protection against the ingress of course dirt • To cover unused actuator slots • Simple clip-in fitting 1115025 - Ball latch 2053-2 • Additional ball latch for stable latching of light to medium-weight guards • For separate mounting on the guard 1110500 - SZ 16/335 • To prevent inadvertent closing, e.g. during maintenance • For complex plant • Prevents actuation of the switch • Up to 6 padlocks can be fitted • The lockout tag can be mounted on a chain near to the safety switch Mounting accessories 1135338 - TAMPERPROOF SCREWS M 5 x 12 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available 1135339 - TAMPERPROOF SCREWS M 5 x 16 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available 1135340 - TAMPERPROOF SCREWS M 5 x 20 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 12:09:16h Kasbase 1.4.7 DBI
AZ16ZVRK-M20 价格&库存
很抱歉,暂时无法提供与“AZ16ZVRK-M20”相匹配的价格&库存,您可以联系我们找货
AZ16ZVRK-M20
  • 1+809.29052
库存:95
