AZ15/16-B1
AZ15/16-B1
    SCHMERSAL
AZ15/16-B1 数据手册
Print - Create PDF - 21.04.2011 12:42:55h Create EXCEL file Datasheet - AZ 15/16-B1 Safety switch with separate actuator / AZ 15 / Actuator (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 15/16-B1 Article number 1083036 EAN code 4030661070001 Global Properties Product name Gerader Betätiger B1 Weight 15 g Mechanical data Design of actuators straight, rigid Minimum actuating radius 160 mm notice Minimum actuating radius on hinged guards 150 mm The axis of the hinge should be 5 mm above the top edge of the safety switch and in the same plane Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 267 kB, 29.08.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/montage/m_z15p02.pdf Images Dimensional drawing (miscellaneous) K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 12:42:56h Kasbase 1.4.7 DBI
AZ15/16-B1 价格&库存
很抱歉,暂时无法提供与“AZ15/16-B1”相匹配的价格&库存,您可以联系我们找货
