AZ15/16-B1-2053 BALL LATCH
    SCHMERSAL
    SCHMERSAL - AZ15/16-B1-2053 BALL LATCH - Switch Actuator, AZ 15 Series
AZ15/16-B1-2053 BALL LATCH 数据手册
Print - Create PDF - 21.04.2011 12:48:54h Create EXCEL file Datasheet - AZ 15/16-B1-2053 WITH BALL LATCH Safety switch with separate actuator / AZ 15 / Actuator • For interlocking of light to medium-weight guards (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 15/16-B1-2053 MIT KUGELRASTUNG Article number 1111081 EAN code 4030661100388 Global Properties Product name Gerader Betätiger B1-2053 mit Kugelrastung Weight 35 g Mechanical data Design of actuators straight, rigid Latching force adjustable up to 100 N Minimum actuating radius 150 mm notice Minimum actuating radius on hinged guards 150 mm The axis of the hinge should be 11 mm above the top edge of the safety switch and in the same plane Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 267 kB, 29.08.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/montage/m_z15p02.pdf Images Dimensional drawing (miscellaneous) Operating principle K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 12:48:54h Kasbase 1.4.7 DBI
AZ15/16-B1-2053 BALL LATCH 价格&库存
很抱歉,暂时无法提供与“AZ15/16-B1-2053 BALL LATCH”相匹配的价格&库存,您可以联系我们找货
