AZ17-11ZRK
AZ17-11ZRK
    SCHMERSAL
AZ17-11ZRK 数据手册
Print - Create PDF - Create EXCEL file - Hide system components Datasheet - AZ 17-11ZRK Safety switch with separate actuator / AZ 17 • thermoplastic enclosure • Small body • 8 actuating planes • 30 mm x 60 mm x 30 mm • Multiple coding • Double-insulated • Long life • High level of contact reliability with low voltages and currents • Not sensitive to dirty conditions by virtue of patented roller system • cable gland M16 (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 17-11ZRK Article number 1133967 EAN code 4030661050911 Approval Approval BG USA/CAN CCC Classification Standards EN ISO 13849-1 B10d Opener (NC) 2.000.000 B10d Normally open contact (NO) 1.000.000 - notice Mission time notice Global Properties at 10% Ie and ohmic load 20 Years 21.04.2011 10:09:22h Product name AZ 17 Standards EN 60947-5-1, BG-GS-ET-15 Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, self-extinguishing - Material of the contacts Silver Housing coating None Weight 85 g Mechanical data Design of electrical connection IDC method of termination Cable section - Min. Cable section 1 x 0,75 mm² - Max. Cable section 1 x 1 mm² Mechanical life > 1.000.000 operations higher Latching force (Y/N) Yes Latching force 30 N Positive break force 17 N positive break travel 11 mm Max. Actuating speed 0,2 m/s Ambient conditions Protection class IP67 to IEC/EN 60529 Electrical data Design of control element Normally open contact (NO), Opener (NC) Switching principle Creep circuit element Number of auxiliary contacts 1 piece Number of safety contacts 1 piece Rated impulse withstand voltage Uimp 4 kV Rated insulation voltage Ui 250 V Thermal test current Ithe 10 A Utilisation category AC-15: 230 V / 4 A DC-13: 24 V / 4 A Max. fuse rating 6 A gG D-fuse ATEX Explosion protection categories for gases None Explosion protected category for dusts None Dimensions Dimensions of the sensor - Width of sensor 30 mm - Height of sensor 85 mm - Length of sensor 30 mm notice Individual coding available on request This type termination (IDC) method enables simple connetion of flexible conductors without the need for the use of conductor ferrules Included in delivery Actuators must be ordered separately. Slot sealing plugs Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Switch travel diagram Notes Switch travel diagram Contact closed Contact open Setting range Break point Positive opening sequence/- angle VS adjustable range of NO contact VÖ adjustable range of NC contact N after travel Ordering suffix The applicable ordering suffix is added at the end of the part number of the safety switch. Order example: AZ 17-11ZRK-1637 ...-1637 0,3 µm gold-plated contacts Ordering code AZ 17-(1)Z(2)K-(3)-(4)-(5) (1) 11 Normally open contact (NO) 1 / Opener (NC) 1 02 Opener (NC) 2 (2) without Latching force 5 N R Latching force 30 N (3) without cable gland M16 2243 Front cable entry 2243-1 Rear cable entry ST Connector M12, 4-pole (4) 1637 gold-plated contacts (5) 5M 5 m Cable length 6M 6 m Cable length Documents Operating instructions and Declaration of conformity (br) 650 kB, 07.07.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/ace/br/mrl_az17-ace_br.pdf Operating instructions and Declaration of conformity (fr) 647 kB, 02.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/fr/mrl_az17_fr.pdf Operating instructions and Declaration of conformity (es) 641 kB, 02.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/es/mrl_az17_es.pdf Operating instructions and Declaration of conformity (en) 721 kB, 02.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/en/mrl_az17_en.pdf Operating instructions and Declaration of conformity (nl) 638 kB, 02.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/nl/mrl_az17_nl.pdf Operating instructions and Declaration of conformity (de) 597 kB, 18.02.2011 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/de/mrl_az17_de.pdf Operating instructions and Declaration of conformity (it) 627 kB, 02.06.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/it/mrl_az17_it.pdf Operating instructions and Declaration of conformity (jp) 1 MB, 17.11.2010 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/bedien/jp/mrl_az17_jp.pdf BG-test certificate (de) 552 kB, 28.02.2007 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/baumuste/z_z17p01.pdf BG-test certificate (en) 551 kB, 28.02.2007 http://127.0.0.1/Bilddata/AZ/Pdf/Az17/baumuste/z_z17p02.pdf CCC certification (en) 746 kB, 12.12.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_175p02.pdf CCC certification (cn) 730 kB, 12.12.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_175p03.pdf Gost certification (ru) 1 MB, 21.06.2007 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/zertifikat/q_az1p01.pdf Images Dimensional drawing (basic component) Configuration graphic System components Actuator 1122893 - AZ 17/170-B1 • Particularly suitable for sliding doors 1137406 - AZ 17/170-B1-2245 • Damps vibration on guard device 1122895 - AZ 17/170-B5 • Particularly suitable for hinged guards (front mounting) 1126060 - AZ 17-B6 • For very smal actuating radii • The direction of actuation can be selected by applicable insertion of the insert 1139788 - AZ 17/170-B11 • Particularly suitable for sliding doors 1139789 - AZ 17/170-B15 • Particularly suitable for hinged guards (front mounting) AZ 17-B25 • Ergonomic operation • No supplementary door-handle required • Door hinge on left-hand side (View point towards the hazardous area) • No protruding actuator • Actuator without handle • Simple mounting • Several door-handles available • Possibility to mount the own handles using a default square screw (8 mm) Accessories 1150363 - Mounting set MS AZ 17 P 1149212 - Mounting set MS AZ 17 R/P 1208493 - AZM 170-B CENTERING GUIDE • for AZ 17 and AZM 170 Mounting accessories 1135338 - TAMPERPROOF SCREWS M 5 x 12 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available 1135339 - TAMPERPROOF SCREWS M 5 x 16 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available 1135340 - TAMPERPROOF SCREWS M 5 x 20 • To mount the actuator • Higher protection against tampering with interlock • Protects against unauthorised removal of actuator • Various lengths available K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 10:09:23h Kasbase 1.4.7 DBI
AZ17-11ZRK 价格&库存
很抱歉,暂时无法提供与“AZ17-11ZRK”相匹配的价格&库存,您可以联系我们找货
