AZM170-02ZRKA-24VAC/DC
    SCHMERSAL
AZM170-02ZRKA-24VAC/DC 数据手册
Print - Create PDF - Create EXCEL file - Hide system components Datasheet - AZM 170-02ZRKA 24 VAC/DC Solenoid interlock / AZM 170 • thermoplastic enclosure • Double-insulated • Compact design • 90 mm x 84 mm x 30 mm • 1 Cable entry M 20 x 1.5 • Interlock with protection against incorrect locking. • Long life • High holding force • IDC method of termination • Manual release (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZM 170-02ZRKA 24 VAC/DC Article number 1141020 EAN code 4030661120294 Approval Approval BG USA/CAN CCC Classification Standards EN ISO 13849-1 B10d Opener (NC) 2.000.000 Mission time 20 Years notice Global Properties Product name AZM 170 21.04.2011 10:22:50h Standards EN 60947-5-1, BG-GS-ET-19 Compliance with the Directives (Y/N) Yes Number of actuating directions 2 piece Active principle electromechanical Duty cycle Magnet 100 % Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, self-extinguishing - Material of the contacts Silver Housing coating None Weight 278 g Mechanical data Design of electrical connection IDC method of termination Cable section - Min. Cable section 1 x 0,75 mm² - Max. Cable section 1 x 1.0 mm², flexible Mechanical life > 1.000.000 operations Emergency unlocking device (Y/N) No Manual release (Y/N) Yes - bottom Emergency release (Y/N) No Latching force 30 N Positive break force 17 N positive break travel 11 mm Clamping force Fmax 1000 N Max. Actuating speed 2 m/s Ambient conditions Ambient temperature - Min. environmental temperature - 25°C - Max. environmental temperature + 60°C Protection class IP67 to IEC/EN 60529 Electrical data Design of control element Opener (NC) Switching principle Creep circuit element Number of auxiliary contacts 0 piece Number of safety contacts 2 piece Power to unlock No Power to lock Yes Rated control voltage Us 24 VAC/DC Power consumption max. 10 W Rated impulse withstand voltage Uimp 4 kV Rated insulation voltage Ui 250 V Thermal test current Ithe 10 A Utilisation category AC-15: 230 V / 4 A, DC-13: 24 V / 4 A Max. fuse rating 6 A gG D-fuse ATEX Explosion protection categories for gases None Explosion protected category for dusts None Miscellaneous data Applications sliding safety guard, removable guard, hinged safety guard Dimensions Dimensions of the sensor - Width of sensor 90 mm - Height of sensor 84 mm - Length of sensor 30 mm notice This type termination (IDC) method enables simple connetion of flexible conductors without the need for the use of conductor ferrules Individual coding available on request Manual release • For manual release using M5 triangular key, available as accessory Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Switch travel diagram Notes Switch travel diagram Contact closed Contact open Setting range Break point Positive opening sequence/- angle VS adjustable range of NO contact VÖ adjustable range of NC contact N after travel Ordering suffix The applicable ordering suffix is added at the end of the part number of the safety switch. Order example: AZM 170-02ZRKA 24 VAC/DC-1637 ...-1637 0,3 µm gold-plated contacts ...ST-2431 connector M12 , Individual solenoid monitoring Ordering code AZM 170(1)-(2)Z(3)K(4)-(5)-(6)-(7) (1) without IDC method of termination SK Screw connection (2) 11 1 Normally open contact (NO) / 1 Opener (NC) 02 2 Opener (NC) 12/0.0 1 Normally open contact (NO), 2 Opener (NC) / - (3) without Latching force 5 N R Latching force 30 N I Individual coding (4) without Power to unlock A Power to lock (5) without cable gland ST Connector M12 x 1 ST-2431 Connector M12 x 1, Individual solenoid monitoring (6) 24VAC/DC Us 24 VAC/DC 110VAC Us 110 VAC 230VAC Us 230 VAC (7) without Manual release 2197 Manual release from side (Power to unlock) 1637 gold-plated contacts AZM 170ST and AZM 170SK AZM 170ST-(1)Z(2)K(3)-(4)-(5)-024 AZM 170SK-(1)Z(2)K(3)-(4)-(5)-024 (1) 11/11 1 Normally open contact (NO), 1 Opener (NC) / 1 Normally open contact (NO), 1 Opener (NC) 11/02 1 Normally open contact (NO), 1 Opener (NC) / 2 Opener (NC) 12/00 1 Normally open contact (NO), 2 Opener (NC) / - 12/11 1 Normally open contact (NO), 2 Opener (NC) / 1 Normally open contact (NO), 1 Opener (NC) 12/02 1 Normally open contact (NO), 2 Opener (NC) / 2 Opener (NC) 02/01 2 Opener (NC), - / 1 Opener (NC), - 02/10 2 Opener (NC), - / 1 Normally open contact (NO), - (2) without Latching force 5 N R Latching force 30 N (3) without Power to unlock A Power to lock (4) 1637 gold-plated contacts (5) 2197 Manual release for Power to unlock Documents Operating instructions and Declaration of conformity (jp) 709 kB, 14.04.2011 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/jp/mrl_azm170_jp.pdf Operating instructions and Declaration of conformity (es) 665 kB, 25.03.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/es/mrl_azm170_es.pdf Operating instructions and Declaration of conformity (en) 746 kB, 12.03.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/en/mrl_azm170_en.pdf Operating instructions and Declaration of conformity (fr) 670 kB, 01.07.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/fr/mrl_azm170_fr.pdf Operating instructions and Declaration of conformity (nl) 720 kB, 23.09.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/nl/mrl_azm170_nl.pdf Operating instructions and Declaration of conformity (de) 573 kB, 18.02.2011 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/de/mrl_azm170_de.pdf Operating instructions and Declaration of conformity (it) 645 kB, 09.04.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/bedien/azm170/it/mrl_azm170_it.pdf BG-test certificate (en) 574 kB, 05.01.2011 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/baumuste/z_m17p02.pdf BG-test certificate (de) 589 kB, 05.01.2011 http://127.0.0.1/Bilddata/Azm/Pdf/Azm170/baumuste/z_m17p01.pdf CCC certification (en) 747 kB, 12.12.2006 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/zertifikat/q_371p02.pdf CCC certification (cn) 725 kB, 12.12.2006 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/zertifikat/q_371p03.pdf Images Dimensional drawing (basic component) Assembly example Detail photo System components Actuator 1122893 - AZ 17/170-B1 • Particularly suitable for sliding doors 1137406 - AZ 17/170-B1-2245 • Damps vibration on guard device 1122895 - AZ 17/170-B5 • Particularly suitable for hinged guards (front mounting) 1139788 - AZ 17/170-B11 • Particularly suitable for sliding doors 1139789 - AZ 17/170-B15 • Particularly suitable for hinged guards (front mounting) 1123391 - AZM 170-B6 • For very smal actuating radii • The direction of actuation can be selected by applicable insertion of the insert Accessories 1208493 - AZM 170-B CENTERING GUIDE • for AZ 17 and AZM 170 1100887 - TRIANGULAR KEY M5 • For manual release using M5 triangular key, available as accessory • For maintenance, installation, etc. K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 10:22:50h Kasbase 1.4.7 DBI
AZM170-02ZRKA-24VAC/DC 价格&库存
很抱歉,暂时无法提供与“AZM170-02ZRKA-24VAC/DC”相匹配的价格&库存,您可以联系我们找货
