BNS33-12Z-2187-2M
BNS33-12Z-2187-2M
    SCHMERSAL
BNS33-12Z-2187-2M 数据手册
Print - Create PDF - Create EXCEL file - Hide system components Datasheet - BNS 33-02Z-2187 Safety sensors / BNS 33 (Minor differences between the printed image and the original product may exist!) • thermoplastic enclosure • Concealed mounting possible • Insensitive to transverse misalignment • 88 mm x 25 mm x 13 mm • Long life • no mechanical wear • Insensitive to soiling • AS-Interface Safety at Work available • Individual contact outlet Ordering details Product type description BNS 33-02Z-2187 Article number 1128792 EAN code 4030661049595 Approval Approval BG USA/CAN Classification Standards EN ISO 13849-1 B10d Opener (NC) 25.000.000 - notice Mission time at max. 20% contact load 20 Years notice Global Properties Product name BNS 33 Standards IEC 60947-5-3, BG-GS-ET-14 Compliance with the Directives (Y/N) Yes Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic - Material of the cable mantle PVC Weight 70 g Monitoring function of downstream devices (Y/N) No Prerequisite evaluation unit Yes Recommended safety-monitoring module Recommended actuator BPS 33, BPS 33-2326 21.04.2011 15:58:16h Mechanical data Design of electrical connection Cable Cable length 1m Conductors 0,25 mm² AWG-Number 23 mechanical installation conditions not flush Active area Side Ensured switch distance ON 5 mm / 8 mm - BPS 33-2326 = 8 mm Actuating magnet - BPS 33 = 5 mm Actuating magnet Ensured switch distance OFF 15 mm / 18 mm - BPS 33 = 15 mm Actuating magnet - BPS 33-2326 = 18 mm Actuating magnet Repeat accuracy R ≤ 0,1 x Type of actuation Magnet Direction of motion head-on with regard to the active surface restistance to shock 30 g / 11 ms Resistance to vibration 10 ... 55 Hz, Amplitude 1 mm Ambient conditions Ambient temperature - Min. environmental temperature −25 °C - Max. environmental temperature +70 °C Storage and transport temperature - Min. Storage and transport temperature −25 °C - Max. Storage and transport temperature +70 °C Protection class IP67 Electrical data Integrated Safety monitoring module available (Y/N) No Cross circuit/short circuit recognition possible (Y/N) Yes Voltage type VAC/DC Switch frequency max. 5 Hz Switching voltage max. 100 VAC/DC Switching current max. 250 mA Switching capacity max. 3 W Outputs Design of control output Other, Reed contakts Number of shutters 0 piece Number of openers 2 piece Electrical data - Safety outputs Number of secure semi-conductor outputs 0 piece Number of secure outputs with contact 0 piece Electrical data - Diagnostic output Number of semi-conductor outputs with signaling function 0 piece Number of outputs with signaling function that already have a contact 0 piece LED switching conditions display LED switching conditions display (Y/N) No ATEX Explosion protection categories for gases None Explosion protected category for dusts None Dimensions Dimensions of the sensor - Width of sensor 88 mm - Height of sensor 25 mm - Length of sensor 13 mm notice Contact symbols shown for the closed condition of the guard device. The contact configuration for versions with or without LED is identical. Included in delivery Actuators must be ordered separately. Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Ordering code BNS 33-(1)Z(2)-(3)-(4) (1) 02 2 Opener (NC) 11 1 Normally open contact (NO) / 1 Opener (NC) 12 1 Normally open contact (NO) / 2 Opener (NC) (2) without without LED switching conditions display G (3) with LED switching conditions display without with cable ST with connector M8 (4) 2187 Individual contact outlet 2187-10 Individual contact outlet, with LED 2237 Actuation from cable direction Documents Operating instructions and Declaration of conformity (fr) 418 kB, 05.11.2009 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/fr/mrl_bns33-2187-2363_fr.pdf Operating instructions and Declaration of conformity (jp) 1 MB, 23.11.2010 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/jp/mrl_bns33-2187-2363_jp.pdf Operating instructions and Declaration of conformity (nl) 424 kB, 05.11.2009 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/nl/mrl_bns33-2187-2363_nl.pdf Operating instructions and Declaration of conformity (en) 698 kB, 21.01.2010 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/en/mrl_bns33-2187-2363_en.pdf Operating instructions and Declaration of conformity (de) 617 kB, 21.01.2010 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/de/mrl_bns33-2187-2363_de.pdf Operating instructions and Declaration of conformity (es) 417 kB, 11.11.2009 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/es/mrl_bns33-2187-2363_es.pdf Operating instructions and Declaration of conformity (it) 791 kB, 16.11.2009 http://127.0.0.1/Bilddata/Si_senso/Pdf/bns33-2187-2363/bedien/it/mrl_bns33-2187-2363_it.pdf Images Dimensional drawing (basic component) Characteristic curve System components Actuator 1107771 - BPS 33 1148482 - BPS 33-2326 • higher switching distance Sao 8 mm Accessories 1158893 - SPACER BN 31/33 • to mount the magnetic safety sensor and actuator on ferromagnetic material K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 15:58:17h Kasbase 1.4.7 DBI
BNS33-12Z-2187-2M 价格&库存
很抱歉,暂时无法提供与“BNS33-12Z-2187-2M”相匹配的价格&库存,您可以联系我们找货
BNS33-12Z-2187-2M
    • 1+684.47333
    库存:6
