AZ15/16-B3-1747 MAGNET LATCH
    SCHMERSAL
    SCHMERSAL - AZ15/16-B3-1747 MAGNET LATCH - Switch Actuator, AZ 15 Series
AZ15/16-B3-1747 MAGNET LATCH 数据手册
Print - Create PDF - 21.04.2011 13:47:34h Create EXCEL file Datasheet - AZ 15/16-B3-1747 WITH MAGNETIC LATCH Safety switch with separate actuator / AZ 15 / Actuator • For very smal actuating radii at 90° to the plane of the actuator • Suitable for retrofitting • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 15/16-B3-1747 MIT HAFTMAGNET Article number 1096090 EAN code 4030661100005 Global Properties Product name Beweglicher Betätiger mit Haftmagnet AZ 15/16-B3-1747 Weight 43 g Mechanical data Design of actuators angled, flexible Latching force 30 N Minimum actuating radius 32 mm notice Actuating radius adjustable, minimum 32 mm, using an hexagonal key wrench 2,5 mm (b) A/F The axis of the hinge should be 11 mm above the top edge of the safety switch and in the same plane Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 267 kB, 29.08.2006 http://127.0.0.1/Bilddata/AZ/Pdf/Az15_16/montage/m_z15p02.pdf Images Dimensional drawing (miscellaneous) Dimensional drawing (miscellaneous) Operating principle K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 13:47:34h Kasbase 1.4.7 DBI
AZ15/16-B3-1747 MAGNET LATCH 价格&库存
很抱歉,暂时无法提供与“AZ15/16-B3-1747 MAGNET LATCH”相匹配的价格&库存,您可以联系我们找货
