AZM161-B1E
AZM161-B1E
    SCHMERSAL
AZM161-B1E 数据手册
Print - Create PDF - 21.04.2011 14:36:03h Create EXCEL file Datasheet - AZM 161-B1E Solenoid interlock / AZM 161 / Actuator (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZM 161-B1E Article number 1144416 EAN code 4030661283203 Global Properties Product name Gerader Betätiger AZM 161-B1E Weight 30 g Mechanical data Design of actuators straight Minimum actuating radius 150 mm notice The axis of the hinge should be 5 mm above the top edge of the safety switch and in the same plane Minimum actuating radius on hinged guards 150 mm Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 203 kB, 08.07.2008 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/montage/m_zm1p02.pdf Images Dimensional drawing (miscellaneous) Actuating radius Actuating radius K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 14:36:04h Kasbase 1.4.7 DBI
AZM161-B1E 价格&库存
很抱歉,暂时无法提供与“AZM161-B1E”相匹配的价格&库存,您可以联系我们找货
