AZM161-B6
AZM161-B6
    SCHMERSAL
AZM161-B6 数据手册
Print - Create PDF - 21.04.2011 14:38:30h Create EXCEL file Datasheet - AZM 161-B6 Solenoid interlock / AZM 161 / Actuator • For very smal actuating radii (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZM 161-B6 Article number 1144420 EAN code 4030661283210 Global Properties Product name Beweglicher Betätiger AZM 161-B6 Weight 35 g Mechanical data Design of actuators flexible Minimum actuating radius 95 mm notice The axis of the hinge should be 11 mm above the top edge of the safety switch and in the same plane Similarly, minimum actuating radius 95 mm in line with the plane of the actuator, adjustable using an hexagonal key wrench 2,5 mm A/F (a) On hinged guards, minimum actuating radius 95 mm, at 90° to the plane of the actuator, adjustable using an hexogonal key wrench 2,5 mm A/F (b) Documents Mounting and wiring instructions (de, en, fr, it, es, jp) 203 kB, 08.07.2008 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/montage/m_zm1p02.pdf Images Dimensional drawing (miscellaneous) Actuating radius Actuating radius K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 14:38:30h Kasbase 1.4.7 DBI
AZM161-B6 价格&库存
很抱歉,暂时无法提供与“AZM161-B6”相匹配的价格&库存,您可以联系我们找货
