AZM161SK-12/12RKA-024
    SCHMERSAL
AZM161SK-12/12RKA-024 数据手册
Print - Create PDF - Create EXCEL file - Hide system components Datasheet - AZM 161SK-12/12RK-024 Solenoid interlock / AZM 161 • thermoplastic enclosure • Double-insulated • Interlock with protection against incorrect locking. • 130 mm x 90 mm x 30 mm • 6 Contacts • Long life • Large wiring compartment • Manual release • cable entries 4 M 16 x 1.5 (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZM 161SK-12/12RK-024 Article number 1164207 EAN code 4030661205144 Approval Approval BG USA/CAN CCC Classification Standards EN ISO 13849-1 B10d Opener (NC) 2.000.000 Mission time 20 Years notice Global Properties Product name AZM 161 Standards EN 60947-5-1, BG-GS-ET-19 Compliance with the Directives (Y/N) Yes Number of actuating directions 3 piece 21.04.2011 14:21:41h Active principle electromechanical Duty cycle Magnet 100 % Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, self-extinguishing - Material of the contacts Silver Housing coating None Weight 500 g Mechanical data Actuating play in direction of actuation 5.5 mm Design of electrical connection Screw connection Cable section - Min. Cable section 1 x 0,75 mm² - Max. Cable section 1 x 1.5 mm² Mechanical life > 1.000.000 operations Emergency unlocking device (Y/N) No Manual release (Y/N) Yes Emergency release (Y/N) No Latching force 30 N Positive break force 20 N positive break travel 10 mm Clamping force Fmax 2000 N Max. Actuating speed 2 m/s Actuating frequency max. 1000 / h notice All indications about the cable section are including the conductor ferrules. Ambient conditions Ambient temperature - Min. environmental temperature - 25°C - Max. environmental temperature + 60°C Protection class IP67 to IEC/EN 60529 Electrical data Design of control element Normally open contact (NO), Opener (NC) Switching principle Creep circuit element Number of auxiliary contacts 2 piece Number of safety contacts 4 piece Power to unlock Yes Power to lock No Rated control voltage Us 24 VAC/DC Power consumption max. 10 W Rated impulse withstand voltage Uimp 4 kV Rated insulation voltage Ui 250 V Thermal test current Ithe 6A Utilisation category AC-15: 230 V / 4 A, DC-13: 24 V / 2,5 A Max. fuse rating 6 A gG D-fuse To DIN EN 60269-1 ATEX Explosion protection categories for gases None Explosion protected category for dusts None Miscellaneous data Applications sliding safety guard, removable guard, hinged safety guard Dimensions Dimensions of the sensor - Width of sensor 130 mm - Height of sensor 90 mm - Length of sensor 30 mm notice Manual release • For maintenance, installation, etc. • For manual release using M5 triangular key, available as accessory Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Switch travel diagram Notes Switch travel diagram Contact closed Contact open Setting range Break point Positive opening sequence/- angle VS adjustable range of NO contact VÖ adjustable range of NC contact N after travel Ordering suffix The applicable ordering suffix is added at the end of the part number of the safety switch. Order example: AZM 161SK-12/12RK-024G ...G Protected against incorrect polarity and voltage spikes. limited terminating space 0,75 mm² Diagram 14 guard open 13 +24 VDC 63 0 VDC 64 unlocked Ordering code AZM 161 (1)-(2)(3)K(4)-(5)-(6)(7) (1) SK Screw connection CC Cage clamps ST male connector M12, 8- and 4-poles (Only for Us: 24 VAC/DC) (2) 12/12 2 Normally open contact (NO) / 4 Opener (NC) 12/11 2 Normally open contact (NO) / 3 Opener (NC) (Plug-in connection) 11/12 2 Normally open contact (NO) / 3 Opener (NC) (Plug-in connection) (3) without Latching force 5 N R Latching force 30 N (4) without Power to unlock A (5) Power to lock without Manual release lateral ED Manual release cover-side EU Manual release rear T Emergency exit lateral TD Emergency exit cover-side TU Emergency exit rear N Emergency release (6) 024 Us: 24 VAC/DC 110/230 Us: 110/230 VAC (7) G with LED (Only for Us: 24 VAC/DC) Documents Operating instructions and Declaration of conformity (jp) 1 MB, 24.11.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/JP/mrl_azm161_jp.pdf Operating instructions and Declaration of conformity (fr) 752 kB, 16.12.2009 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/FR/mrl_azm161_fr.pdf Operating instructions and Declaration of conformity (es) 711 kB, 16.12.2009 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/ES/mrl_azm161_es.pdf Operating instructions and Declaration of conformity (en) 751 kB, 16.12.2009 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/EN/mrl_azm161_en.pdf Operating instructions and Declaration of conformity (nl) 659 kB, 16.12.2009 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/NL/mrl_azm161_nl.pdf Operating instructions and Declaration of conformity (de) 421 kB, 17.02.2011 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/DE/mrl_azm161_de.pdf Operating instructions and Declaration of conformity (it) 706 kB, 16.12.2009 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/bedien/AZM_161_12_12/IT/mrl_azm161_it.pdf BG-test certificate (de) 219 kB, 09.02.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/baumuste/z_m16p01.pdf BG-test certificate (en) 219 kB, 09.02.2010 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/baumuste/z_m16p02.pdf CCC certification (en) 747 kB, 12.12.2006 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/zertifikat/q_371p02.pdf CCC certification (cn) 725 kB, 12.12.2006 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/zertifikat/q_371p03.pdf notice (de, en) 88 kB, 27.09.2007 http://127.0.0.1/Bilddata/Azm/Pdf/Azm161/sonder/s_161p01.pdf Images Dimensional drawing (basic component) Dimensional drawing (basic component) Operating principle System components Actuator 1145117 - AZM 161-B1 1144416 - AZM 161-B1E 1171859 - AZM 161-B1ES 1175431 - AZM 161-B1F 1171125 - AZM 161-B1S 1173089 - AZM 161-B1-2053 WITH BALL LATCH 1164100 - AZM 161-B1-1747 WITH MAGNETIC LATCH 1178199 - AZM 161-B1-2024 1176642 - AZM 161-B1-2177 WITH CENTERING GUIDE 1174113 - AZM 161-B6-2177 WITH CENTERING GUIDE • For very smal actuating radii 1170375 - AZM 161-B6S 1144420 - AZM 161-B6 • For very smal actuating radii Door-handle system AZM 161-STS30 • Latching handle • Suitable for all types of guard Accessories 1100887 - TRIANGULAR KEY M5 • For manual release using M5 triangular key, available as accessory • For maintenance, installation, etc. K.A. Schmersal GmbH, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 21.04.2011 - 14:21:42h Kasbase 1.4.7 DBI
AZM161SK-12/12RKA-024 价格&库存
很抱歉,暂时无法提供与“AZM161SK-12/12RKA-024”相匹配的价格&库存,您可以联系我们找货
