AZ16-02ZVRK-M20
AZ16-02ZVRK-M20
    SCHMERSAL
AZ16-02ZVRK-M20 数据手册
24.05.2017 10:28:46h Datasheet - AZ 16-02ZVRK Safety switch with separate actuator / AZ 16 Preferred typ • Thermoplastic enclosure • Double-insulated • Large wiring compartment • 52 mm x 90 mm x 30 mm • Multiple coding • Long life • High level of contact reliability with low voltages and currents • Insensitive to soiling • Slotted holes for adjustment, circular holes for location • 3 cable entries M 16 x 1.5 (Minor differences between the printed image and the original product may exist!) Ordering details Product type description AZ 16-02ZVRK Article number 101147145 EAN code 4030661141671 eCl@ss 27-27-26-02 Approval Approval BG USA/CAN CCC Classification Standards EN ISO 13849-1 B10d Normally-closed contact (NC) 2.000.000 Mission time 20 Years notice Global Properties Product name AZ 16 Standards EN 60947-5-1, BG-GS-ET-15 Compliance with the Directives (Y/N) Yes Materials - Material of the housings Plastic, glass-fibre reinforced thermoplastic, self-extinguishing - Material of the contacts Silver Housing coating None Weight 115 g Mechanical data Design of electrical connection Screw connection Cable section - Min. Cable section 0,75 mm² - Max. Cable section 2.5 mm² Mechanical life > 1.000.000 operations notice All indications about the cable section are including the conductor ferrules. higher Latching force (Y/N) Yes Latching force 30 N With ejection force (Y/N) No Positive break force 20 N positive break travel 8 mm Actuating speed max. 2 m/s Ambient conditions Ambient temperature - Min. environmental temperature −30 °C - Max. environmental temperature +80 °C Protection class IP67 to IEC/EN 60529 Electrical data Design of control element Opener (NC) Switching principle Snap action with self-cleaning contact Number of auxiliary contacts 0 piece Number of safety contacts 2 piece Rated impulse withstand voltage Uimp 4 kV Rated insulation voltage Ui 500 V Thermal test current Ithe 10 A Utilisation category AC-15: 230 V / 4 A, DC-13: 24 V / 4 A Max. fuse rating 6 A gG D-fuse ATEX Explosion protection categories for gases None Explosion protected category for dusts None Dimensions Dimensions of the sensor - Width of sensor 52 mm - Height of sensor 90 mm - Length of sensor 30 mm Included in delivery Actuators must be ordered separately. Diagram Note Diagram positive break NC contact active no active Normally-open contact Normally-closed contact Switch travel diagram Notes Switch travel diagram Contact closed Contact open Setting range Break point Positive opening sequence/- angle VS adjustable range of NO contact VÖ adjustable range of NC contact N after travel Ordering suffix The applicable ordering suffix is added at the end of the part number of the safety switch. Order example: AZ 16-02ZVRK-2254 ...-2254 Latching force 5 N ...-M20 cable entries M20 Ordering code AZ 16-(1)ZV(2)K-(3)-(4)-(5) (1) without 1 Normally open contact (NO) / 1 Opener (NC) 02 2 Opener (NC) 03 3 Opener (NC) 12 Normally open contact (NO) 1 / Opener (NC) 2 (2) without Ejection force R Latching force 30 N (3) G24 with LED (only available for version with one NO and one NC contact.) (4) without Cable entry M16 M20 Cable entry M20 ST Connector M12, 4-pole, bottom STL Connector M12, 4-pole, left STR Connector M12, 4-pole, right (5) 2254 Latching force 5 N 1762 Front mounting 1637 gold-plated contacts Documents Operating instructions and Declaration of conformity (pt) 433 kB, 25.05.2010 Code: mrl_az15-16_pt Operating instructions and Declaration of conformity (pt) 287 kB, 08.07.2016 Code: mrl_az15-16_pt Operating instructions and Declaration of conformity (de) 267 kB, 04.03.2016 Code: mrl_az15-16_de Operating instructions and Declaration of conformity (fr) 284 kB, 27.04.2016 Code: mrl_az15-16_fr Operating instructions and Declaration of conformity (jp) 564 kB, 23.08.2016 Code: mrl_az15-16_jp Operating instructions and Declaration of conformity (cs) 400 kB, 11.10.2011 Code: mrl_az15-16_cs Operating instructions and Declaration of conformity (es) 281 kB, 09.03.2016 Code: mrl_az15-16_es Operating instructions and Declaration of conformity (pl) 313 kB, 15.04.2016 Code: mrl_az15-16_pl Operating instructions and Declaration of conformity (sv) 275 kB, 17.06.2015 Code: mrl_az15-16_sv Operating instructions and Declaration of conformity (da) 398 kB, 17.11.2011 Code: mrl_az15-16_da Operating instructions and Declaration of conformity (en) 283 kB, 04.03.2016 Code: mrl_az15-16_en Operating instructions and Declaration of conformity (nl) 266 kB, 02.07.2013 Code: mrl_az15-16_nl Operating instructions and Declaration of conformity (fi) 256 kB, 02.07.2015 Code: mrl_az15-16_fi Operating instructions and Declaration of conformity (it) 275 kB, 15.04.2016 Code: mrl_az15-16_it Mounting and wiring instructions (de, en, fr, it, es, jp) 181 kB, 12.06.2007 Code: m_mazp01 BG-test certificate (en) 135 kB, 18.11.2014 Code: z_z15p02 BG-test certificate (de) 138 kB, 18.11.2014 Code: z_z15p01 CCC certification (cn) 815 kB, 21.07.2016 Code: q_175p03 CCC certification (en) 847 kB, 21.07.2016 Code: q_175p02 EAC certification (ru) 844 kB, 05.10.2015 Code: q_6037p17_ru Images Dimensional drawing (basic component) System components Actuator 101083036 - AZ 15/16-B1 101092711 - AZ 15/16-B1-1747 • For play-free interlocking of light guards • Suitable for retrofitting 101093553 - AZ 15/16-B1-1747 • For play-free interlocking of light guards • The magnetic latch can be easily fitted in any actuating plane • Suitable for retrofitting 101108276 - AZ 15/16-B1-2024 101108278 - AZ 15/16-B1-2024 WITH SLOT SEALING PLUG • For protection against the ingress of course dirt K.A. Schmersal GmbH & Co. KG, Möddinghofe 30, D-42279 Wuppertal The data and values have been checked throroughly. Technical modifications and errors excepted. Generiert am 24.05.2017 - 10:28:47h Kasbase 3.2.6.F.64I
AZ16-02ZVRK-M20 价格&库存
很抱歉,暂时无法提供与“AZ16-02ZVRK-M20”相匹配的价格&库存,您可以联系我们找货
AZ16-02ZVRK-M20
  • 1+245.32918
库存:118
