AP101 100W TO-247 High Power Resistors
• 100 watts at 25°C case temperature heat sink mounted
• TO- 247 style power package
• Sin gle screw mounting to heat sink
• Mou lded case for protection
• Elec trically isolated case
• Non -Inductive design
• RoHS Compliant
Characteristics
Tolerance (Code):
± 1% (F), ± 5% (J), ± 10% (K)
Operating temperature:
-65°C to +175°C
Temperature co
± 50ppm/°C to ± 300ppm/°C (re to ohmic values), referenced to 25°C, ∆R taken at +105°C
Operating voltage:
700V max
Dielectric strength:
1800Vac 60 seconds, ∆R±0.15%
Insulation resistance:
10G min
Maximum torque:
0.9 Nm
Free air:
25°C, rated at 3.5W
Load Life
∆R±1.0%, Rated power, 2,000 hours
Solderability
90% min. coverage, 245±5°C for 3 seconds
Momentary Overload
∆R±0.5%,1.5 times rated power and V (dc) ≤ 1.5VMax. for 5 seconds
Moisture resistance
∆R±0.5%, -10°C - +65°C, RH>90%, cycle 240 hours
Thermal Shock
∆R±0.5%, -65°C - 150°C, 100 cycles
Terminal Strength
∆R±0.2%, (Pull Test) 2.4N
Vibration, High Frequency
∆R±0.4%, 20g peak
Derating Curve
ations
Value Range
Tolerance
Pref. Value Range
R05 - 1R
± 1% (F)
> 1R - 3R
E12, E24, E96
± 300ppm/°C
± 5% (J)
± 100ppm/°C (std.),
± 200ppm/°C
> 10R - 10K
E12, E24
± 10% (K)
E12
100
Power Rated %
> 3R - 10R
TCR (ppm/˚C)
80
60
40
±50ppm/°C, ±100ppm/°C (std.),
± 200ppm/°C
50
75
100
125
150
175
Case Temperature (°C)
The case temperature measurement must be made with a thermocouple contacting
the centre of the component mounted on the designed heat sink
Thermal grease should be applied properly
For more information and ordering, please consult
www.arcolresistors.com
Page 1 of 2
Standard part numbers
15.49 - 16.01
AP101R05J
AP101R1J
AP101R2J
AP101R5J
AP1011RJ
AP1011R2J
AP1011R5J
AP1011R8J
AP1012R2J
AP1012R7J
AP1013RJ
AP1013R3J
AP1013R9J
AP1014R3J
AP1014R7J
AP1015R6J
AP1016R2J
AP1016R8J
20.44 - 20.96
5.07 - 5.59
Dimensions (mm)
4.69 - 5.21
3.53 - 3.73
3.45 - 3.81
0.55 - 1.07
9.90 - 10.42
AP101100RJ
AP101120RJ
AP101150RJ
AP101180RJ
AP101200RJ
AP101220RJ
AP101270RJ
AP101330RJ
AP101390RJ
AP101470RJ
AP101560RJ
AP101620RJ
AP101680RJ
AP101820RJ
AP1011KJ
AP1011K2J
AP1011K5J
AP1011K8J
AP1012KJ
AP1012K2J
AP1012K7J
AP1013KJ
AP1013K3J
AP8213K6J
AP1013K9J
AP1014K3J
AP1014K7J
AP1015K6J
AP1016K8J
AP1018K2J
AP1017K5J
AP10110KJ
Ordering Information
2.15 - 2.67
AP101 10K JV
13.21 - 15.75
2.03 - 3.55
1.42 - 1.62
AP1017R5J
AP1018R2J
AP10110RJ
AP10112RJ
AP10115RJ
AP10118RJ
AP10122RJ
AP10124RJ
AP10127RJ
AP10130RJ
AP10133RJ
AP10139RJ
AP10147RJ
AP10151RJ
AP10156RJ
AP10162RJ
AP10168RJ
AP10182RJ
Series
Resistance
Tolerance
F = 1%
J = 5%
K = 10%
TCR
N = 50ppm
L = 200ppm
Blank = standard
ARCOL UK Limited,
The information contained herein does not form part of
Threemilestone Ind. Estate,
a contract and is subject to change without notice. Arcol
Truro, Cornwall, TR4 9LG, UK.
operate a policy of continual product development, therefore,
T +4 4 (0) 1872 277431
specifications may change.
F +4 4 (0) 1872 222002
E s ales @ arcolresistors.com
It is the responsibility of the customer to ensure that the
component selected from our range is suitable for the intended
application. If in doubt please ask Arcol.
3/12.10
Page 2 of 2
很抱歉,暂时无法提供与“AP101 56R J”相匹配的价格&库存,您可以联系我们找货
