FFLB-5KW 110V
FFLB-5KW 110V
    ARCOL(艾高)
    ARCOL - FFLB-5KW 110V - Resistor, Load Bank, 500 Mohm, 5 kW, 110 V
FFLB-5KW 110V 数据手册
FFLB- 19”RACK MOUNTABLE RESISTIVE LOAD BANKS • Resistive test loads suitable for 19” rack mounting or table top use • 1, 3 & 5 KW versions available. • 230VAC & 110VAC test voltage options available • 240V & 115V Aux supply options available • Forced Air cooling • Built in over current & thermal protection. Characteristics Rated Power: 1KW, 3KW, 5KW Rated Test Voltages 230VAC & 110VAC Insulation Resistance: >500MΩ @500V DC Dielectric Strength : 2500V AC for 1 minute Dimensions (mm) Series W W” D H FFLB-1KW 482(19”) 432(19”) 375 178 FFLB-3KW 482(19”) 432(19”) 375 311 FFLB-5KW 482(19”) 432(19”) 375 355 ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 1 of 1 1/19.34 FFLB- 19”RACK MOUNTABLE RESISTIVE LOAD BANKS RESISTIVE Ordering Procedure Standard Resistor: Series, A to be added for 115V aux models e.g. FFLB-1KW 230V - For 240V Aux model FFLB-1KW 230V A - For 115V Aux models Electrical Specifications Type Wattage Current Range Load Step Resolution FFLB-1KW 230V FLLB-1KW 110V 1KW 1KW 1.08A- 4.3A 2.3A - 9.1A 0.25KW x 4 0.25KW x 4 FFLB-3KW 230V 3KW 1.08A -13A 0.25kw X 2 , 0.5KW X1 , 1KW X2 FFLB-3KW 110V 3KW 2.3A - 27.3A 0.25kw X 2 , 0.5KW X1 , 1KW X2 FFLB-5KW 230V 5KW 1.08A - 21.7A 0.25kw X 2 , 0.5KW X1 , 1KW X2 2KW X 1 FFLB-5KW 110V 5KW 2.3A-45.5A 0.25kw X 2 , 0.5KW X1 , 1KW X2 2KW X 1 Standard Stocked Parts 240V AUX SUPPLY PART No 115V AUX SUPPLY PART No • • • • • • • • FFLB-1KW 230V FFLB-1KW 110V FFLB-1KW 230V A FFLB-1KW 110V A FFLB-3KW 230V FFLB-3KW 110V FFLB-3KW 230V A FFLB-3KW 110V A FFLB-5KW 230V FFLB-5KW 110V FFLB-5KW 230V A FFLB-5KW 110V A ARCOL UK Limited, The information contained herein does not form part of Threemilestone Ind. Estate, a contract and is subject to change without notice. Arcol Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask Arcol. Page 2 of 2 1 / 19.34
FFLB-5KW 110V 价格&库存
很抱歉,暂时无法提供与“FFLB-5KW 110V”相匹配的价格&库存,您可以联系我们找货
