FPA350 350W Thick Film Heatsink
Resistors
350 Watt resistor designed for various applications including traction;
power supplies; speed drives; power supplies;control devices and robotics.
• Power Rating
350 watts at 85°C bottom case temp
• Value Range
R2 to 1M
• Tolerance Options
±5% or ±10% standard
• TCR Options
±500ppm/ ºC (0.1 Ω ≤0.12 Ω) Standard
±150ppm/ ºC (>0.12 Ω≤1M Ω) Standard
• Maximum Voltage
5000Vdc
• Dielectric Strength
7k Vrms / 50 Hz / 500 VA test time 1 min.
Non-inductive design, high insulation & partial discharge performance
RoHS Compliant.
Characteristics
Power rating
350W at 85ºC bottom case temp
Partial discharge
4kV rms. 0.12 Ω≤1M Ω)
Short term overload
600W at 70ºC for 10 sec
5000 Vdc rms (50 Hz)
Mounting screw / max. torque
M5 standard , 1.8Nm
Contacts
(M4 on special request
Maximum working voltage
Working temperature range -55ºC to +150ºC
Dielectric strength
7kV rms/50Hz/500VA test time 1 min
connection screw thread max
Creepage distance
> 42mm std (higher on request)
7mm)
Test Specifications
Humidity 56 days / 40ºC / Steady state 95%
∆R ±0.25%
Temperature -55 / +125 / 5 cycles
∆R ±0.20%
Shock 40g / 4,000 times
∆R ±0.25%
Vibrations 2-500Hz / 10g
∆R ±0.25%
Load life 3000 cycle Pn 30 min. on / 30 min. off
∆R ±0.40%
ARCOL UK Limited,
The information contained herein does not form part of a
Threemilestone Ind. Estate,
contract and is subject to change without notice. ARCOL
Truro, Cornwall TR4 9LG, UK.
operate a policy of continual product development therefore,
T +44 (0) 1872 277431
specifications may change.
F +44 (0) 1872 222002
E sales@arcolresistors.com
www.arcolresistors.com
It is the responsibility of the customer to ensure that the
component selected from our range is suitable for the intended
application. If in doubt please ask ARCOL.
Page 1 of 2
1/17.36
FPA600 600W Thick Film Heatsink
Resistors
Ordering Procedure
120
420
Standard resistor: Specify series, watts, ohmic value,
100
350
tolerance code. e.g FPA350 10R K
80
280
60
210
40
140
50
75
100
125
150
Rated power (W)
Rated power %
Derating Curve
Case temperature (°C)
Dimensions
Other terminal dimensions available, contact ARCOL for more information
ARCOL UK Limited,
Page 2 of 2
1/17.36
很抱歉,暂时无法提供与“FPA350 220R J”相匹配的价格&库存,您可以联系我们找货
