AP725 10R J
AP725 10R J
    ARCOL(艾高)
    ARCOL - AP725 10R J - SMD Chip Resistor, 10 ohm, ± 5%, 20 W, TO-263 (D2PAK), Thick Film, High Power
AP725 10R J 数据手册
AP725 20W TO-263 Power Resistor • Power Dissipation 20 watts with h/s 2.25 watts no h/s • Value Range R02 - 130K • D2PAK housing • Tolerance Options ±1% or ±5% • TCR Options ±100 ppm/°C • Maximum Voltage √(P*R) • Dielectric Strength 2 kVac • RoHS Compliant Characteristics Tolerance (Code): ± 1% (F), ± 5% (J) Value range: R02 to 130K (with standard resistance values) Power rating: 20W at 25˚C case temperature Temperature coefficient: ±100ppm/˚C Thermal resistance: 6.5˚C/W Inductance: 0.1µH maximum Operating voltage: √P*R with a maximum of 250V Dielectric strength: 2kVac Insulation resistance: 10GΩ Operating temperature: -55˚C to 155˚C Electrical Specifications Parameter Specification Short term overload (2x Pr for R < 2Ω, 1.6 x Pr for R ≥ 2Ω, V < 1.5x operating voltage) ∆R ±0.25% Load life ( 1000 hours at rated power) ∆R ±1.0% Thermal shock (-55˚C to 155˚C, 5 cycles) ∆R ±0.5% Resistance to soldering heat (10 sec at 270˚C) ∆R ±0.5% Vibration (20 G 10 - 2000Hz .06” D.A) ∆R ±0.25% Moisture sensitivity level 1 Ordering Procedure Standard Resistor: Series, Resistance Value, Tolerance, Packaging (T&R or Tubes) e.g.: AP725 8R2 J T&R ARCOL UK Limited, The information contained herein does not form part of Threemilestone Ind. Estate, a contract and is subject to change without notice. Arcol Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask Arcol. Page 1 of 1 1/11.50 AP725 20W TO-263 Power Resistor Recommended Pad Layout Recommended pad layout Derating Curve 11.0 (.433) 100 Power Rated % 4.02 (0.158) 10.52 (0.414) 39 06) 2.25 (0.089) 80 60 40 20 0 25 0.26 (0.10) 50 85 100 115 130 145 155 Ambient Temperature (°C) 4.23 (0.166) 2.4 (0.095) 8.0 (.315) PWR263S-20 Typical PartSeries Marking Power Resistor RWISE NOTED UNTING Dimensions (mm/inches) RESISTANCE Product Dimensions CODE TOLERANCE DATE CODE XX X X X % YYY 1.6A C O S TA R IC 10.1 MANUFACTURER'S (0.398) TRADEMARK 7.8 COUNTRY OF ORIGIN (0.063) (0.307) Recommended Pad Layout MODEL NUMBER 263 20 48 ° 4.5 (0.177) 10.4 (0.409) REF. How to Order 11.0 (.433) 1.3 (.051) 4.02 (0.158) 10.52 (0.414) 15.39 (0.606) 8.8 (0.347) 2.25 (0.089) PWR 263 S - 20 - 10R0 F E Down cond 0.26 (0.10) Model PWR = Power Resistor Package 263 = D2PAK 4.23 (0.166) 1.92 (0.076) 1.4 (0.055) 5.08 Pin Style (0.20) 3.1 (0.122) 0.25 (0.010) S = Surface Mount 8.0 (.315) Power 20 = 20 W MM Resistance Value DIMENSIONS: (INCHES)
AP725 10R J 价格&库存
很抱歉,暂时无法提供与“AP725 10R J”相匹配的价格&库存,您可以联系我们找货
