AP101 18R J
AP101 18R J
    ARCOL(艾高)
    TO247-2
    ARCOL - AP101 18R J
AP101 18R J 数据手册
AP101 100W TO-247 High Power Resistors • 100 watts at 25°C case temperature heat sink mounted • TO- 247 style power package • Sin gle screw mounting to heat sink • Mou lded case for protection • Elec trically isolated case • Non -Inductive design • RoHS Compliant Characteristics Tolerance (Code): ± 1% (F), ± 5% (J), ± 10% (K) Operating temperature: -65°C to +175°C Temperature co ± 50ppm/°C to ± 300ppm/°C (re to ohmic values), referenced to 25°C, ∆R taken at +105°C Operating voltage: 700V max Dielectric strength: 1800Vac 60 seconds, ∆R±0.15% Insulation resistance: 10G min Maximum torque: 0.9 Nm Free air: 25°C, rated at 3.5W Load Life ∆R±1.0%, Rated power, 2,000 hours Solderability 90% min. coverage, 245±5°C for 3 seconds Momentary Overload ∆R±0.5%,1.5 times rated power and V (dc) ≤ 1.5VMax. for 5 seconds Moisture resistance ∆R±0.5%, -10°C - +65°C, RH>90%, cycle 240 hours Thermal Shock ∆R±0.5%, -65°C - 150°C, 100 cycles Terminal Strength ∆R±0.2%, (Pull Test) 2.4N Vibration, High Frequency ∆R±0.4%, 20g peak Derating Curve ations Value Range Tolerance Pref. Value Range R05 - 1R ± 1% (F) > 1R - 3R E12, E24, E96 ± 300ppm/°C ± 5% (J) ± 100ppm/°C (std.), ± 200ppm/°C > 10R - 10K E12, E24 ± 10% (K) E12 100 Power Rated % > 3R - 10R TCR (ppm/˚C) 80 60 40 20 ±50ppm/°C, ±100ppm/°C (std.), ± 200ppm/°C 0 0 25 50 75 100 125 150 175 Case Temperature (°C) The case temperature measurement must be made with a thermocouple contacting the centre of the component mounted on the designed heat sink Thermal grease should be applied properly For more information and ordering, please consult www.arcolresistors.com Page 1 of 2 AP101 100W TO-247 High Power Resistors Standard part numbers 15.49 - 16.01 AP101R05J AP101R1J AP101R2J AP101R5J AP1011RJ AP1011R2J AP1011R5J AP1011R8J AP1012R2J AP1012R7J AP1013RJ AP1013R3J AP1013R9J AP1014R3J AP1014R7J AP1015R6J AP1016R2J AP1016R8J 20.44 - 20.96 5.07 - 5.59 Dimensions (mm) 4.69 - 5.21 3.53 - 3.73 3.45 - 3.81 0.55 - 1.07 9.90 - 10.42 AP101100RJ AP101120RJ AP101150RJ AP101180RJ AP101200RJ AP101220RJ AP101270RJ AP101330RJ AP101390RJ AP101470RJ AP101560RJ AP101620RJ AP101680RJ AP101820RJ AP1011KJ AP1011K2J AP1011K5J AP1011K8J AP1012KJ AP1012K2J AP1012K7J AP1013KJ AP1013K3J AP8213K6J AP1013K9J AP1014K3J AP1014K7J AP1015K6J AP1016K8J AP1018K2J AP1017K5J AP10110KJ Ordering Information 2.15 - 2.67 AP101 10K JV 13.21 - 15.75 2.03 - 3.55 1.42 - 1.62 AP1017R5J AP1018R2J AP10110RJ AP10112RJ AP10115RJ AP10118RJ AP10122RJ AP10124RJ AP10127RJ AP10130RJ AP10133RJ AP10139RJ AP10147RJ AP10151RJ AP10156RJ AP10162RJ AP10168RJ AP10182RJ Series Resistance Tolerance F = 1% J = 5% K = 10% TCR N = 50ppm L = 200ppm Blank = standard ARCOL UK Limited, The information contained herein does not form part of Threemilestone Ind. Estate, a contract and is subject to change without notice. Arcol Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T +4 4 (0) 1872 277431 specifications may change. F +4 4 (0) 1872 222002 E s ales @ arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask Arcol. 3/12.10 Page 2 of 2
AP101 18R J 价格&库存
很抱歉,暂时无法提供与“AP101 18R J”相匹配的价格&库存,您可以联系我们找货
