AP101100W TO-247 High Power Resistors
• 100 watts at 25°C case temperature heat sink mounted
• TO-247 style power package
• Single screw mounting to heat sink
• Moulded case for protection
• Electrically isolated case
• Non-Inductive design
• RoHS Compliant
Characteristics
Tolerance (Code):
± 1% (F), ± 5% (J), ± 10% (K)
Operating temperature:
-65°C to +175°C
Temperature coefficient:
± 50ppm/°C to ± 300ppm/°C (re to ohmic values), referenced to 25°C, ∆R taken at +105°C
Operating voltage:
700V max
Dielectric strength:
1800Vac 60 seconds, ∆R±0.15%
Insulation resistance:
10G min
Maximum torque:
0.9 Nm
Free air:
25°C, rated at 3.5W
Load Life
∆R±1.0%, Rated power, 2,000 hours
Solderability
90% min. coverage, 245±5°C for 3 seconds
Momentary Overload
∆R±0.5%,1.5 times rated power and V (dc) ≤ 1.5VMax. for 5 seconds
Moisture resistance
∆R±0.5%, -10°C - +65°C, RH>90%, cycle 240 hours
Thermal Shock
∆R±0.5%, -65°C - 150°C, 100 cycles
Terminal Strength
∆R±0.2%, (Pull Test) 2.4N
Vibration, High Frequency
∆R±0.4%, 20g peak
Ordering Procedure
Derating Curve
Standard Resistor: Series, Resistance Value, Tolerance Code,
TCR
100
Power Rated %
eg: AP101 10K J 50ppm
Electrical Specifications
80
60
40
Value Range
Tolerance
Pref. Value Range
TCR (ppm/˚C)
R05 - 1R
± 1% (F)
Not specified
> 1R - 3R
E12, E24, E96
± 300ppm/°C
> 3R - 10R
± 5% (J)
± 100ppm/°C, ± 200ppm/°C
The case temperature measurement must be made with a thermocouple contacting
± 50ppm/°C, ± 100ppm/°C,
Thermal grease should be applied properly
E12, E24
> 10R - 100K
± 10% (K)
E12
50
75
100
125
150
175
Case Temperature (°C)
The case temperature is to be used for the definition of the applied power limit
the centre of the component mounted on the designed heat sink
± 200ppm/°C
ARCOL UK Limited,
The information contained herein does not form part of
Threemilestone Ind. Estate,
a contract and is subject to change without notice. Arcol
Truro, Cornwall, TR4 9LG, UK.
operate a policy of continual product development, therefore,
T +44 (0) 1872 277431
specifications may change.
F +44 (0) 1872 222002
E sales@arcolresistors.com
www.arcolresistors.com
It is the responsibility of the customer to ensure that the
component selected from our range is suitable for the intended
application. If in doubt please ask Arcol.
Page 1 of 2
4/14.39
15.49 - 16.01
20.44 - 20.96
5.07 - 5.59
Dimensions (mm)
4.69 - 5.21
3.53 - 3.73
3.45 - 3.81
0.55 - 1.07
2.15 - 2.67
13.21 - 15.75
1.42 - 1.62
2.03 - 3.55
9.90 - 10.42
ARCOL UK Limited,
Page 2 of 2
4/14.39
很抱歉,暂时无法提供与“AP101 R7 J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 13+142.94033
- 25+139.84742
- 国内价格
- 50+96.31550
- 100+93.90782
- 200+92.46342
- 国内价格
- 1+146.15821
- 13+142.94033
- 25+139.84742
