FPA100 4R7 J
FPA100 4R7 J
    ARCOL(艾高)
    SOT227
    ARCOL - FPA100 4R7 J - Resistor, Screw, 4.7 ohm, FPA100, 100 W, ± 5%, Screw, 1 kV
FPA100 4R7 J 数据手册
FPA100 Thick Film Power Resistors Due to a Non-Inductive design these elements are ideally suited for high frequency and pulse load applications. The FPA100 is available connected as 2 terminals or 4 terminals, in parallel or series. • SOT227 Style package • Competitively priced • 100 Watts dissipation in a small footprint • Very low inductance • Direct heatsink mounting Characteristics Ohmic value range: E24, contact ARCOL for values outside this series Tolerance (Code): Standard J (±5%). K (±10%) available for 1R to 10R values. F (±1%) also available on request. TCR: 100ppm (at +105°C ref to +25°C) Power rating at 25° C: 100W Max working voltage: 1kV rms Resistance range: 1R to 5M Voltage proof: Dielectric strength 4kVdc Partial discharge: Up to 2kV rms / 80 pC Capacitance/mass: ≤40pF Working temp range: -55°C to +155°C Max. torque for contacts (static): 1.3Nm Max. torque for base plate (static): 1.5Nm Inductance: ≤ 50nH Ordering Procedure Standard (Version 1) Resistor Specify Series, Watts, Ohmic Derating Curve 100 Value, Tolerance Code, e.g.: FPA100 2R2 J Rated Power % Versions 2, 3, 4 or 5 Specify Series, Watts, Ohmic Value or Values, Tolerance Code and then Version Number, e.g.: FPA100 2R2 2R2 J version 4. Refer to versions available on page 2. 75 50 25 0 0 25 50 100 125 155 Temperature ˚C ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 1 of 2 13 / 15.33 FPA100 Thick Film Power Resistors Dimensions (mm) A G 1 M M4 L 2 8.2 F D E A B C D min E F Min 38 30.1 11.5 4.1 4.0 24.4 Max 39 30.3 13.5 N/A 4.3 26.4 G J K L M N 7.8 14.5 0.75 1.9 9.5 11.5 C Min 3 K 4 J N B Versions Available 1 4 1 2 2 4 1 2 3 4 5 3 1 2 3 1 4 1 2 3 4 ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 2 of 2 13/ 15.33
FPA100 4R7 J 价格&库存
很抱歉,暂时无法提供与“FPA100 4R7 J”相匹配的价格&库存,您可以联系我们找货
