AP735 68R J
AP735 68R J
    ARCOL(艾高)
    ARCOL - AP735 68R J - SMD Chip Resistor, TO-263 (D2PAK), 68 ohm, AP735 Series, 250 V, Thick Film, 35...
AP735 68R J 数据手册
AP735 35W TO-263 Power Resistor • Power Dissipation 35 watts with heat sink • Low inductance • D2PAK housing • Electrically isolated from backplate • TCR Options ±100 ppm/°C • RoHS Compliant Characteristics Tolerance (Code): ± 1% (F), ± 5% (J) Value range: R02 to 130K (with standard resistance values) Power rating: 35W at 25˚C case temperature Temperature coefficient: ±100ppm/˚C Thermal resistance: 3.7˚C/W Inductance: 0.1µH maximum Operating voltage: √P*R with a maximum of 250V Dielectric strength: 2kVac Insulation resistance: 10GΩ Operating temperature: -55˚C to 155˚C PWR263S-20 Series Power Resistor Re Product Dimensions 10.1 (0.398) 7.8 (0.307) 48 ° Electrical Specifications 4.5 (0.177) 1.6 (0.063) 1.3 (.051) 10.4 (0.409) REF. 1 (0 15.39 (0.606) 8.8 (0.347) Parameter Specification Short term overload (2x Pr for R < 2Ω, 1.6 x Pr for R ≥ 2Ω, V < 1.5x operating voltage) ∆R ±0.25% Load life ( 1000 hours at rated power) Thermal shock (-55˚C to 155˚C, 5 cycles) 1.4 (0.055) 5.08 (0.20) ∆R ±1.0% 1.92 (0.076) ∆R ±0.5% Resistance to soldering heat (10 sec at 270˚C) ∆R ±0.5% Vibration (20 G 10 - 2000Hz .06” D.A) ∆R ±0.25% Moisture sensitivity level 1 3.1 (0.122) 0.25 (0.010) MM (INCHES) ±0.38 TOLERANCE: UNLESS OTHERWISE NOTED (±0.015) DIMENSIONS: LEAD 0.102 MAX AT MOUNTING COPLANARITY: (0.004) SURFACE Soldering Profile 275 260 °C peak +245 °C and +260 °C Power dissipation is 3.5W at an ambient temperature of 25°C 245 °C 225 when mounted on a double sided copper using FR4, 70μm of H Temperature (°C) 220 °C 190 °C 175 60 - 90 seconds Ramp Down 6 °C/second 150 °C 125 Mod P Pack 2 60 - 120 seconds 10 seconds minimum Pin S S 75 Ramp Up 3 °C/second maximum 25 0 50 100 Pow 2 150 Time (seconds) 200 250 300 Power dissipation is 2.8 W at an ambient temperature of 25 ˚C when mounted on a double-sided copper board using FR4 standard, 70 µm of copper, 39 x 30 x 1.6 mm. ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com RESIS CODE MANU TRAD Soldering Profile Maximum of 20 seconds between copper 39x30x1.6mm Ty ≥ Abso J F Pack E B specifications may change. Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications. It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 1 of 2 Resi < 1/14.08 AP735 35W TO-263 Power Resistor PWR263S-20 Series Power Resistor PWR263S-20 Series Power Resistor Dimensions (mm) Recommended Padpad Layout layout Recommended Product Dimensions Product Dimensions 10.1 (0.398) 7.8 (0.307) Recommended Pad Layout 4.5 (0.177) 1.6 10.1 (0.398) (0.063) 7.8 (0.307) 48 ° 1.6 (0.063) 10.4 (0.409) REF. 48 ° 10.4 (0.409) REF. 8.8 (0.347) 11.0 (.433) 1.3 4.5 (.051) (0.177) 1.3 (.051) 15.39 (0.606) 4.02 (0.158) 15.39 (0.606) 4.02 (0.158) 10.52 (0.414) 10.52 (0.414) 2.25 (0.089) 8.8 (0.347) 2.25 (0.089) 4.23 (0.166) 1.92 (0.076) 1.4 (0.055) 20 Series Power Resistor 5.08 5.08 (0.20) 1.4 (0.055) 0.25 (0.010) (0.20) 3.1 (0.122) (0.076) 0.25 (0.010) 275 +245 °C and +260 °C 260 °C peak Maximum of 20 seconds between 245 °C 245 °C 220 °C 225 125 Temperature (°C) 190 °C 60 - 90 seconds Ramp Down 6 °C/second 25 25 50 6 °C/second (.315) Ramp Up MODEL NUMBER MODEL NUMBER TOLERANCE 263 20 DATE CODE XXXX X% COUNTRY OF ORIGIN YYY COSTA R ICA TOLERANCE DATE CODE COUNTRY OF ORIGIN How to Order 0 How PWR 100 263 S 115 -to20Order - 130 10R0 F 145E 85 155 RESISTANCE CODE Resistor Model PWR = Power Resistor Package 263 = D2PAK 60 - 120 seconds LEAD MAX AT MOUNTING 30.102 °C/second maximum COPLANARITY: (0.004) SURFACE 263 20 RESISTANCE XXXX CODE X% YYY COSTA R ICA MANUFACTURER'S TRADEMARK Backplate Temperature 263 S - 20 - 10R0 F E 2.4 Ambient TemperaturePWR (°C) Model (0.095) °C PWR = Power Ramp Down 8.0 60 - 120 seconds MM DIMENSIONS:10 seconds minimum (INCHES) Typical 10 seconds minimum ±0.38 Ramp TOLERANCE: Up UNLESS OTHERWISE NOTED 75 3 °C/second maximum(±0.015) 75 Marking Typical Part Marking 0.26 (0.10) 20 4.23 (0.166) 220 °C 3.1 (0.122) 0.25 (0.010) 150 °C 125 60 - 90 seconds 190 °C 1.92 (0.076) 175 8.0 (.315) 60 260 °C peak 40 +245 °C and +260 °C 225 150 °C1.4 (0.055) 2.25 (0.089) 80 % Soldering Profile 8.8 Maximum of 20 seconds between (0.347) 175 MANUFACTURER'S TRADEMARK 100 10.52 (0.414) 15.39 (0.606) Power Rated % 275 10.4 Profi(0.409) le REF. Power Rated Soldering 2.4 (0.095) Derating Curve 4.5 (0.177) 1.6 (0.063) 0.26 (0.10) 2.4 (0.095) 8.0 (.315) DIMENSIONS: 0.1 398) 7.8 307) 0.26 (0.10) 4.23 (0.166) MM Recommended Pad Layout (INCHES) Typical Part MM DIMENSIONS: ±0.38 (INCHES) 11.0 TOLERANCE: UNLESS OTHERWISE NOTED (±0.015) (.433) ±0.38 1.3 TOLERANCE: UNLESS OTHERWISE NOTED RESISTANCE LEAD 0.102 MAX AT MOUNTING (±0.015) (.051) CODE 4.02 COPLANARITY: (0.004) SURFACE LEAD 0.102(0.158) MAX AT MOUNTING COPLANARITY: (0.004) SURFACE ns Temperature (°C) 3.1 (0.122) 1.92 11.0 (.433) Package 2 Pin Style Part MarkingS = Surface Mount 263 = D PAK Ordering Procedure Pin Style Power S = Surface Mount 20 = 20 W Standard Resistor: Series, Resistance Value, Tolerance, Power MODEL Resistance Value 20 = 20- W NUMBER Packaging options T&R - TR or Tubes blank 263 20
AP735 68R J 价格&库存
很抱歉,暂时无法提供与“AP735 68R J”相匹配的价格&库存,您可以联系我们找货
