ACPP080556RBE
ACPP080556RBE
    ARCOL(艾高)
    ARCOL - ACPP080556RBE - RES, 56R, 0.1%, 100V, 0805, THIN FILM
ACPP080556RBE 数据手册
ACPP Precision Surface Mount Passivated Resistors • Precision thin film technology • Extended ohmic range 10R – 1M5 • Precision to ±0.1% and 15ppm/ºC • Passivated range for superior humidity performance • RoHS Compliant Characteristics Tolerance (Code): ±0.1% (B), ± 0.25% (C) Operating temperature: -55°C to +155°C Temperature coefficient: ±15ppm/°C (A), ±25ppm/°C (E), ±50ppm/°C (F) Overload: ≤±0.2%, ≤±0.1% (ACPP0402), RCWV*2.5 or maximum overload voltage (whichever is lowest) for 2 seconds Thermal shock: ≤±0.02%, ≤±0.1% (ACPP0402), -55ºC +150ºC 100 cycles Endurance: ≤±0.05%, ≤±0.25% (ACPP0402), 70 ± 2ºC, RCWV for 1000 hours with 1.5 hours on and 0.5 hours off Humidity: ≤±0.05%, ≤±0.5% (ACPP0402), 1000 hours at 40±2ºC, 90-95% R.H with 1.5 hours on and 0.5 hours off Electrical Specifications Type Wattage Maximum operating voltage Maximum overload voltage ACPP0402 0.0625 25V 50V TCR ppm/°C Ohmic value range ±15 49R9 - 12K ±25 24R9 - 24K9 ±15 ACPP0603 0.0625 50V 100V ±25 24R9 - 332K ±50 ±15 ACPP0805 0.1 100V 200V ±25 10R - 1M ±50 ±15 ACPP1206 0.125 150V 300V ±25 10R - 1M ±50 ±15 ACPP2010 0.25 150V 300V ±25 ±50 ±15 ACPP2512 0.5 150V 300V ±25 ±50 24R9 - 1M 10R - 1M5 24R9 - 1M 10R - 1M5 ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 1 of 2 5/15.34 ACPP Precision Surface Mount Passivated Resistors Dimensions (mm) Series L W T D1 D2 1.00 ± 0.05 0.50 ± 0.05 0.30 ± 0.05 0.20 ± 0.10 0.20 ± 0.10 ACPP0603 1.55 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.30 ± 0.20 0.30 ± 0.20 ACPP0805 2.00 ± 0.15 1.25 ± 0.15 0.55 ± 0.10 0.30 ± 0.20 0.40 ± 0.20 ACPP0402 ACPP1206 3.05 ± 0.15 1.55 ± 0.15 0.55 ± 0.10 0.42 ± 0.20 0.35 ± 0.20 ACPP2010 4.90 ± 0.15 2.40 ± 0.15 0.55 ± 0.10 0.60 ± 0.30 0.50 ± 0.20 ACPP2512 6.30 ± 0.15 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.30 0.50 ± 0.20 Derating Curve Soldering Curve °C Pre-heating Ramp-up Power Rated % 100 250 80 60 200 Cooling Keep at 220°C max, 60 sec max 40 150 20 Reflow Peak 265°C max 260° for 10 sec Ramp-down 6°C/sec max 180°C max, 120 sec max 0 0 20 40 60 80 100 120 140 100 160 Ambient Temperature (°C) 50 0 Ramp-up 3°C/sec max 50 100 150 200 250 300 Sec ARCOL Ordering Procedure Ohmite Ordering Procedure Standard Resistor: Series, Size, Resistance Value, Tolerance, Standard Resistor: Series, Size, Resistance Value, Tolerance, TCR TCR Code, RoHS compliant eg: ACPP0603 100K B 15PPM .i.e: ACPP0603B100KAE series tol RoHS ohms size F = 50ppm E = 25ppm A = 15ppm ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. Page 2 of 2 5/15.34
ACPP080556RBE
物料型号:ACPP系列,包括ACPP0402、ACPP0603、ACPP0805、ACPP1206、ACPP2010和ACPP2512。
器件简介:这些电阻器采用精密薄膜技术制造,具有扩展的欧姆范围(10R至1M5),精度达到±0.1%,温度系数为±15ppm/°C,并且具有钝化范围以提供优越的湿度性能。它们符合RoHS标准。
引脚分配:文档没有提供具体的引脚分配图,但通常表面贴装电阻器的引脚分配是对称的。
参数特性:包括公差(B级±0.1%,C级±0.25%)、工作温度范围(-55°C至+155°C)、温度系数(A级±15ppm/°C,E级±25ppm/°C,F级±50ppm/°C)、过载能力、热冲击和耐久性。
功能详解:文档详细描述了电阻器的电气规格,包括功率、最大工作电压、最大过载电压、温度系数、欧姆值范围。
应用信息:文档指出,客户有责任确保从ARCOL产品系列中选择的组件适合其预期应用。如果有疑问,应咨询ARCOL。
封装信息:提供了ACPP系列电阻器的尺寸数据,包括长度、宽度、厚度、D1和D2。
ACPP080556RBE 价格&库存
很抱歉,暂时无法提供与“ACPP080556RBE”相匹配的价格&库存,您可以联系我们找货
