HS10 3R9 J
HS10 3R9 J
    ARCOL(艾高)
    ARCOL - HS10 3R9 J - Resistor, Axial Leaded, 3.9 ohm, HS Series, 10 W, ± 5%, Solder Lug, 160 V
HS10 3R9 J 数据手册
HS Aluminium Housed Resistors Manufactured in line with the requirements of MIL 18546 and IEC 115, designed for direct heatsink mounting with thermal compound to achieve maximum performance. • High Power to volume • Wound to maximise High Pulse Capability • Values from R005 to 100K • Custom designs welcome • RoHS Compliant Characteristics Tolerance (Code): Standard ±5% (J) and ±10% (K). Also available ±1% (F), ±2% (G) and ±3% (H) Tolerance for low Ω values: Typically ≥ R05 ±5% ≤ R047 ±10% Temperature coefficients: Typical values < 1K 100ppm Std. > 1K 25ppm Std. For lower TCR’s please contact Arcol Insulation resistance (Dry): 10,000 MΩ minimum Power dissipation: At high ambient temperature dissipation derates linearly to zero at 200°C Ohmic values: From R005 to 100K depending on wattage size Low inductive (NHS): Specify by adding N before HS Series code, e.g. NHS50 NHS ohmic value: Divide standard HS maximum value by 4 NHS working volts: Divide standard HS maximum working voltage by 1.414 Temp. Rise & Power Dissipation Heat Dissipation Surface temperature of resistor related to power dissipation. Heat dissipation: Whilst the use of proprietary heat sinks The resistor is standard heatsink mounted using a proprietary with lower thermal resistances is acceptable, uprating is not heatsink compound. recommended. For maximum heat transfer it is recommended that a heat sink compound be applied between the resistor S U RFACE T E M P E R ATU R E R I S E ( ˚ C) 200 HS300 HS150 HS50 100 the maximum hot spot temperature of 200°C is not exceeded, HS250 HS200 therefore, the resistor must be mounted on a heat sink of correct thermal resistance for the power being dissipated. HS25 HS100 HS75 HS15 HS10 Ordering Procedure 5 0 20 base and heat sink chassis mounting surface. It is essential that 50 75 100 150 200 P OW ER DISSI PATI ON (WATTS ) 250 300 Standard Resistor. To specify standard: Series, Watts, Ohmic Value, Tolerance Code, e.g.: HS25 2R2 J Non Inductive Resistor. To specify add N, e.g.: NHS100 10R J ARCOL UK Limited, The information contained herein does not form part of a Threemilestone Ind. Estate, contract and is subject to change without notice. ARCOL Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T +44 (0) 1872 277431 specifications may change. F +44 (0) 1872 222002 E sales@arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask ARCOL. For more information and ordering, please consult www.arcolresistors.com Page 1 of 2 12/14.08 HS Aluminium Housed Resistors Electrical Specifications Style MIL-R 18546 Power rating on std. heatsink @25°C Watts with no heatsink @25°C Resistance range Limiting element voltage Voltage proof AC Peak Voltage proof AC rms. Approx weight gms Typical surface rise HS mounted HS10 RE 60 10 5 R005-10K 160 1400 1000 4 5.8 Size Standard heatsink cm2 Thickness mm 415 1 HS15 RE 65 15 7 R005-10K 265 1400 1000 7 5.1 415 1 HS25 RE 70 25 9 R005-36K 550 3500 2500 14 4.2 535 1 HS50 RE 75 HS75 50 14 R01-86K 1250 3500 2500 32 3.0 535 1 75 24 R01-50K 1400 6363 4500 85 1.1 995 3 HS100 100 30 R01-70K 1900 6363 4500 115 1.0 995 3 HS150 150 45 R01-100K 2500 6363 4500 175 1.0 995 3 HS200 200 50 R01-50K 1900 7070 5000 475 0.7 3750 3 HS250 250 55 R01-50K 2200 7070 5000 600 0.6 4765 3 HS300 300 60 R01-68K 2500 7070 5000 700 0.6 5780 3 HS10-HS300 Standard Resistor Centre hole in 150 Watts only J L J L J L 6mm 3.0 ± 0.1 2.1 ± 0.1 G A HS 10, 15, 25, 50 G A HS 75, 100, 150 G A HS 200, 250, 300 Ø 3.2 max. Ø 2.0 ± 0.25 * = = = = F E F E B B F E M B D D D C C H C H K H K K Dimensions (mm) Size A Max B Max C Max D Max E Max F±0.3 G±0.3 H Max J Max K Max L ±0.25* M Max HS10 16.5 30.0 8.8 8.5 15.9 11.3 12.4 4.5 2.4 1.8 2.4 HS15 21.0 36.5 11.0 11.2 19.9 14.3 15.9 5.5 2.8 1.8 2.4 HS25 28.0 51.0 14.8 14.2 27.3 18.3 19.8 7.7 5.2 2.6 3.2 HS50 28.0 72.5 14.8 14.2 49.1 39.7 21.4 8.4 5.2 2.6 3.2 HS75 47.5 72.0 24.1 27.3 48.7 29.0 37.0 11.8 10.4 3.7 4.4 HS100 47.5 88.0 24.1 27.3 65.2 35.0 37.0 11.8 15.4 3.7 4.4 HS150 47.5 121.0 24.1 27.3 97.7 58.0 37.0 11.8 20.4 3.7 4.4 HS200 72.5 145.7 41.8 45.5 89.7 70.0 57.2 20.5 10.4 5.5 5.1 103.4 HS250 72.5 167.0 41.8 45.5 109.7 89.0 57.2 20.5 10.4 5.5 5.1 122.4 HS300 72.5 184.4 41.8 45.5 127.7 104.0 59.0 20.5 12.4 5.5 6.6 141.4 * HS200-HS300 Watts is ± 0.45 Page 2 of 2 12/14.08
HS10 3R9 J
物料型号:文档中没有明确指出具体的物料型号,但提到了HS系列电阻器,包括HS10至HS300。
器件简介:这些电阻器是按照MIL 18546和IEC 115的要求制造的,设计用于直接安装在散热器上,使用热导化合物以实现最大性能。它们具有高功率体积比,能够承受高脉冲能力,并且符合RoHS标准。
引脚分配:文档中没有提及引脚分配信息。
参数特性: - 公差:标准为±5%(J)和±10%(K),也提供±1%(F)、±2%(G)和±3%(H)。 - 低欧姆值的公差:通常≥ R05 ±5%,≤ R047 ±10%,典型值小于1K为100ppm标准,大于1K为25ppm标准。 - 温度系数:文档中未提供具体数值。 - 绝缘电阻(干态):文档中未提供具体数值。 - 功率耗散:在高温环境下,耗散能力会线性下降至200°C时为零。
功能详解:文档中没有提供详细的功能解释,但提到了电阻器的高脉冲能力,以及使用热导化合物以实现最大性能。
应用信息:文档中没有明确提供应用信息,但根据其设计和特性,可以推断这些电阻器适用于需要高功率和高脉冲能力的场合。
封装信息:文档提供了电阻器的尺寸和重量信息,以及标准散热器的规格。
订购流程:文档提供了标准电阻器的订购示例,以及如何指定非电感电阻器。
制造商信息:ARCOL UK Limited,提供了联系信息和网址。
HS10 3R9 J 价格&库存
很抱歉,暂时无法提供与“HS10 3R9 J”相匹配的价格&库存,您可以联系我们找货
HS10 3R9 J
  • 100+36.08291
  • 200+35.18003
  • 400+34.63851
库存:169
HS10 3R9 J
  • 25+23.13955
  • 50+22.63969
库存:169
HS10 3R9 J
  • 1+23.64983
  • 25+23.13955
  • 50+22.63969
库存:85
