HS Aluminium Housed Resistors
An extension to our popular HS range of resistors. These
resistors are suitable for power applications including braking
resistors for frequency converters. Designed to be heatsink
mounted to achieve full commercial wattage..
• Wound to maximise High Pulse Capability
• Values from 3R6 to 1K2
• RoHS Compliant
Characteristics
Tolerance (Code):
Standard ±5% (J),±10% (K) & ±20%(M)
Typical TCR:
≤ ±150ppm ºC
Insulation resistance at 500V
≥ 10 GΩ minimum
Power dissipation:
At high ambient temperature dissipation derates linearly to zero at 250°C
Ohmic values:
From 3R6 to 1K2 depending on wattage size
Overload Capability(single Pulse):
10 x Power, 5 seconds
Design Voltage:
√(PxR)
Specifications & Dimensions
Box body
WITHOUT HEATSINK
WATTS
WITH
HEATSINK
WATTS
OHMS
DIMENSIONS mm
WEIGHT
SERIES
30% DUTY
CYCLE
100% DUTY
CYCLE
100% DUTY
CYCLE
RESISTANCE
RANGE
MAX
VOLTAGE
L1
L2
L3
GRAMS
HS400
320
80
400
3R6 - 620r
2000 v
182
100
41
415
HS500
400
100
500
5R1 - 910r
2300 V
242
160
41
530
HS600
480
120
600
6R8 - 1K2
2800 V
302
220
41
670
ARCOL UK Limited,
The information contained herein does not form part of a
Threemilestone Ind. Estate,
contract and is subject to change without notice. ARCOL
Truro, Cornwall, TR4 9LG, UK.
operate a policy of continual product development, therefore,
T +44 (0) 1872 277431
specifications may change.
F +44 (0) 1872 222002
E sales@arcolresistors.com
www.arcolresistors.com
It is the responsibility of the customer to ensure that the
component selected from our range is suitable for the intended
application. If in doubt please ask ARCOL.
Page 1 of 2
01/31.19
Adiabatic Pulse x Ohmic Value
Derating Curve
Ordering Procedure
Standard Stocked Values
Standard Resistor: Series, Resistance Value, Tolerance
e.g: HS400 10R J
HS400
HS500
HS600
HS400 10R J
HS500 10R J
HS600 10R J
HS400 25R J
HS500 25R J
HS600 25R J
HS400 50R J
HS500 50R J
HS600 50R J
HS400 75R J
HS500 75R J
HS600 75R J
HS400 100R J
HS500 100R J
HS600 100R J
HS400 250R J
HS500 250R J
HS600 250R J
HS400 500R J
HS500 500R J
HS600 500R J
HS600 1K J
Page 2 of 2
01/31.01
很抱歉,暂时无法提供与“HS600 50R J”相匹配的价格&库存,您可以联系我们找货
