AP101 1K5 J 100PPM
AP101 1K5 J 100PPM
    ARCOL(艾高)
    ARCOL - AP101 1K5 J 100PPM - Through Hole Resistor, 1.5 kohm, AP101 Series, 100 W, ± 5%, TO-247, 700...
AP101 1K5 J 100PPM 数据手册
AP101100W TO-247 High Power Resistors • 100 watts at 25°C case temperature heat sink mounted • TO-247 style power package • Single screw mounting to heat sink • Moulded case for protection • Electrically isolated case • Non-Inductive design • RoHS Compliant Characteristics Tolerance (Code): ± 1% (F), ± 5% (J), ± 10% (K) Operating temperature: -65°C to +175°C Temperature coefficient: ± 50ppm/°C to ± 300ppm/°C (re to ohmic values), referenced to 25°C, ∆R taken at +105°C Operating voltage: 700V max Dielectric strength: 1800Vac 60 seconds, ∆R±0.15% Insulation resistance: 10G min Maximum torque: 0.9 Nm Free air: 25°C, rated at 3.5W Load Life ∆R±1.0%, Rated power, 2,000 hours Solderability 90% min. coverage, 245±5°C for 3 seconds Momentary Overload ∆R±0.5%,1.5 times rated power and V (dc) ≤ 1.5VMax. for 5 seconds Moisture resistance ∆R±0.5%, -10°C - +65°C, RH>90%, cycle 240 hours Thermal Shock ∆R±0.5%, -65°C - 150°C, 100 cycles Terminal Strength ∆R±0.2%, (Pull Test) 2.4N Vibration, High Frequency ∆R±0.4%, 20g peak Ordering Procedure Derating Curve Standard Resistor: Series, Resistance Value, Tolerance Code, TCR 100 Power Rated % eg: AP101 10K J 50ppm Electrical Specifications 80 60 40 20 Value Range Tolerance Pref. Value Range TCR (ppm/˚C) R05 - 1R ± 1% (F) Not specified > 1R - 3R E12, E24, E96 ± 300ppm/°C > 3R - 10R ± 5% (J) ± 100ppm/°C, ± 200ppm/°C The case temperature measurement must be made with a thermocouple contacting ± 50ppm/°C, ± 100ppm/°C, Thermal grease should be applied properly E12, E24 > 10R - 100K ± 10% (K) E12 0 0 25 50 75 100 125 150 175 Case Temperature (°C) The case temperature is to be used for the definition of the applied power limit the centre of the component mounted on the designed heat sink ± 200ppm/°C ARCOL UK Limited, The information contained herein does not form part of Threemilestone Ind. Estate, a contract and is subject to change without notice. Arcol Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask Arcol. Page 1 of 2 4/14.39 AP101100W TO-247 High Power Resistors 15.49 - 16.01 20.44 - 20.96 5.07 - 5.59 Dimensions (mm) 4.69 - 5.21 3.53 - 3.73 3.45 - 3.81 0.55 - 1.07 2.15 - 2.67 13.21 - 15.75 1.42 - 1.62 2.03 - 3.55 9.90 - 10.42 ARCOL UK Limited, The information contained herein does not form part of Threemilestone Ind. Estate, a contract and is subject to change without notice. Arcol Truro, Cornwall, TR4 9LG, UK. operate a policy of continual product development, therefore, T  +44 (0) 1872 277431  specifications may change. F  +44 (0) 1872 222002  E sales@arcolresistors.com www.arcolresistors.com It is the responsibility of the customer to ensure that the component selected from our range is suitable for the intended application. If in doubt please ask Arcol. Page 2 of 2 4/14.39
AP101 1K5 J 100PPM 价格&库存
很抱歉,暂时无法提供与“AP101 1K5 J 100PPM”相匹配的价格&库存,您可以联系我们找货
