CRS1050 R0005 F 75PPM TR
    ARCOL(艾高)
    ARCOL - CRS1050 R0005 F 75PPM TR - SMD Current Sense Resistor, 500 µohm, CRS, 4120 [1050 Metric], 5 ...
CRS1050 R0005 F 75PPM TR 数据手册
【LRS Series】 CRS SMD Shunt Resistor Chip Sh Avaliable in two sizes ARCOL’s CRS utilises Electron Beam Welding technology to connect its Manganin or NiCr element to heavy copper connectors. Suitable for typical applications such as Solar Inverters, Frequency converters & current sensors for hybrid power sources. • Excellent long-term stability and low inductance • Suitable for mounting using re-flow soldering or welding on copper • Power rating upto 7 Watts ▓Construction Characteristics LRS1050 Tolerance (Code): ± 1% (F), ± 5% (J) Operating temperature: -55°C to +170°C Overload: 5 times rated power for 5 seconds Thermal shock: ±0.1%. -65°C,25°C,125°C,25°C, 25 cycles Load life: ±1%.   7.5±0.3 90min. “ON”, 30min “OFF” for 2000 hours 1.2 max ±0.2% 90~98%RH, +25°C, +65°C, -10°C, 10 cycles. ±0.2% 350°C for 30 seconds or 250°C for 10min. 0.5 High Temperture Exposure: ±0.2% 140°C for 250 hours Vibration, High frequency: ±0.2% 15g 10~2000Hz, 36 cycles Inductance
CRS1050 R0005 F 75PPM TR 价格&库存
很抱歉,暂时无法提供与“CRS1050 R0005 F 75PPM TR”相匹配的价格&库存,您可以联系我们找货
